Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Sun Feb 25, 2018 11:20 am Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
xzener wrote: |
ROTFL!! I needed that, thanks Evil_fiz.
Ok... If you must know, I'm sure anyone who has installed one of these sway bars can attest, I only had enough strength in my hand for one side |
Nope, there are upsides to habitual self stimulation, I could put a dozen of those things on. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Thu Jul 12, 2018 8:05 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Decided to go back to air ride after finding a used Accuair E-Level management system for half the price of MSRP. Bought a VIAIR 20008 and surprisingly, it fits in the spare tire well... So, I think I will go ahead and do a custom install there. Going back and forth with which rear bag system to go with. Either JJVintage, or Airkewld (my previous suspension builder won't return my texts).
Anyone here install JJVintage air shock setup??
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
hazmatty3614 Samba Member
Joined: June 07, 2016 Posts: 252 Location: Wanaque, New Jersey
Posted: Sat Sep 22, 2018 1:17 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
I know this has been covered, but nothing I see helps me.
Stock 69 Ghia.
Stock 15" rims.
165R15 Cooper Sportmaster GLTs.
Can I run 2.5" drop spindles without a narrowed beam? What about with just a thinner tire?
Thanks |
Onceler Samba Member
Posted: Sat Sep 22, 2018 4:47 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
My 72 has 165/80-15's on stock rims with 2.5" lowered spindles and it rubs terribly with 1 rotation of the steering wheel and won't drive it tell I switch to 4.5" Fuchs with a smaller tire _________________ 1972 Karmann Ghia |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Sat Sep 22, 2018 7:52 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
hazmatty3614 wrote: |
Stock 69 Ghia.
Stock 15" rims.
Thanks |
My experience: Stock '68 with 165/80/R15 tyres no rubbing until I put 2.5" drp spindles on. I then put adjusters in the beam and went for smaller tyres - 165/65/R15. No rubbing now.
Based on my experience, I would say you are going to have rubbing issues even with narrower tyres. Thus either narrowed beam or adjusters to solve the problem. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
xzener Samba Member
Posted: Thu Sep 27, 2018 5:02 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
After working for 20 minutes on a post that was deleted before I could click submit... I've decided to simply post the fruits of my labor here. 2 inch narrowed (adjustable, but using through rods), stock spindles and short axles conversion in the rear. Front air ride using Accuair E-Level. I plan on bagging the rear too. Perhaps using the shocks I posted above.
Peter D. Samba Member
Joined: February 25, 2004 Posts: 718 Location: Stamford, CT
Posted: Thu Sep 27, 2018 7:02 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Looks great! And those headlights are wild. _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Thu Sep 27, 2018 7:20 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Stock 69 Ghia.
Stock 15" rims.
Thanks |
From my experience with my Ghia:
Drop Spindles push the hub out 3/8 to 1/2 inch each side depending on who made them welded or not. Back in the day we used dropped spindles and 135SR15 tires with stock rims. Not a very meaty look but didn’t rub. You could still use 165SR15 on the rear though if the car has been hit or reworked there’s no telling.
Since I was kafer barring, ball jointing and bushing doing I was able to test fit my current set up and move the wheels and tires through their full motion.
I ended up with 15x5.5 wheels with 5” backspace. 195/50/15 in the rear, 195/45/15 in the front. 70 IRS with ball joint front |
Larmo63 Samba Member
Posted: Thu Sep 27, 2018 8:25 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Who can lower my car in SoCal? Reputable shop? I want to go adjustable, just to level the car and get rid of the 'speedboat' look.
Suggestions? _________________ Lawrence
‘61 Mango Green Single Cab
'62 Pearl White Ragtop sedan
'66 Ruby Red Cabriolet
'86 Porsche 911 Carrera |
xzener Samba Member
Posted: Thu Sep 27, 2018 8:39 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Why not do it yourself? Minus the narrowing of the beam... That requires some welding. Which is a dying profession, but seems as though it may bounce back thanks to you know who. But for what it's worth, with basic tools, it's not very difficult to do. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Thu Sep 27, 2018 8:48 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
I'd like to lower it 1 1/2"
Not dumped, but level. I'm running wide whites 5.60 - 15
No rubbing issues. _________________ Lawrence
Posted: Thu Sep 27, 2018 8:49 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
I know 914 Porsche suspensions like the back of my hand, but I'm not yet up to speed on VWs. _________________ Lawrence
c21darrel Samba Member
Chuck67 Samba Member
Posted: Sun Oct 28, 2018 9:29 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Looking around and very hard to find the info I need
We have a 74 Ghia put dropped spindles on it. Tires rub, have 145's and don't want to go any smaller so narrowed beam it is. Bentley manual states must cut bumper tubes to get front beam out of car. Question --How much needs to be removed? Do tubes really have to be welded back when new beam installed?
Thanks,
Chuck 67 |
Posted: Mon Oct 29, 2018 1:17 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
You don’t need to cut anything to remove the front beam. It’s really just a few bolts and it basically falls on your face.
Narrowing the front is a lot more the just the beam. You need narrower springs, sway bar and tie rods too.
I too put drop spindles and Kleber 145’s on my Ghia (1970) and had a rub too.
I put my stock spindles back in.
Fast forward, I bought new wheels (15x5.5) with a 5 inch offset and skinned the fronts with 195/45/15 tires and put the drop spindles back on.
Since I was redoing the ball joints and such anyway I assembled everything without the torsion springs and moved the wheel through its range of motion and no rub.
The same wheels with 195/50/15 are in the rear and they don’t rub either.
This story has been shortened for context. _________________ Volkswagen!
(Compression 8.7:1) |
xzener Samba Member
Posted: Mon Oct 29, 2018 2:10 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
And, unfortunately, no 2 Ghia's are the same. Its a matter of form fit and function... Trial and error... it can be rather expensive. I have a 2 inch narrowed beam, stock spindles, and 205/45/17s. It will rub... But have air ride. I can easily lift the car to clear the fenders when driving up and into the driveway. Good luck with the beam. Don't let it fall on your face. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Mon Oct 29, 2018 8:30 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Yup, I heard of a lot of trial and error happening. This is actually the third tire and wheel combo on this car. I consider myself lucky that this combo worked out at all. I still haven't seen it on the ground so I can't say if I'll like it or not. I'm concerned the front wheels will look too small. Oh well. I better like them. I already custom painted them! _________________ Volkswagen!
xzener Samba Member
Posted: Mon Oct 29, 2018 8:44 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
Pictures? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Oct 29, 2018 9:47 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
jeffrey8164 wrote: |
Yup, I heard of a lot of trial and error happening. This is actually the third tire and wheel combo on this car. I consider myself lucky that this combo worked out at all. I still haven't seen it on the ground so I can't say if I'll like it or not. I'm concerned the front wheels will look too small. Oh well. I better like them. I already custom painted them! |
I'd encourage you to swap out the blue urethane steering Rag joint for a standard VW rubber version. The urethane have a tendency to split/break.
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Sat Nov 03, 2018 8:48 pm Post subject: Re: Ghia Suspension:Lower, Narrow, Adjust - Custom & Stock |
You don’t need to cut anything to remove the front beam. It’s really just a few bolts and it basically falls on your face. |
Unfortunately not true. To get the beam out of my 74 ghia I had to cut about 2 inches off of the collapsible front bumper tubes. Only took a few minutes with the ole sawzall but it had to be done to get the beam off of the car. |
