Drag Racing and a 36hp unlimited class
Page: Previous  1, 2, 3 ... 22, 23, 24, 25  Next
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Sun Jun 07, 2009 10:40 pm    Post subject: Reply with quote
Roadcow wrote:
Maxton Update
Bruce Cook DSS new Record on first pass 99.8 mph on a 1493cc engine
Tom Bruch SSS new Record 90 mph and change on a 1415cc engine using stock carb and intake manifold.
Pictures
Also a question; Can you run a dry sump in the DSS class? Planning the 36 type 2 land speed DSS engine and the question was brought up
"no more hacking my sig line"
36hplandspeedracer
36hplandspeedracer is offline
PostPosted: Mon Jun 08, 2009 6:15 am    Post subject: Dry sump ? Reply with quote
A dry sump oil system would pass the "guidelines" if the components utilized were availalble prior to 1965 since it could improve performance. A "full flow" oil system is acceptable since it only contributes to reliability, not performance.
Burly
spookymulder
Samba Proletariat
Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
spookymulder is offline
PostPosted: Thu Jun 11, 2009 7:36 pm    Post subject: Reply with quote
Ronnie you must be the "Cybil" of the bus world! You have one lowered, one raised , one stock, one racer, one original paint, one restored, yep you truly are a multi personality bus owner Twisted Evil
Unkl Ian
Unkl Ian is offline
PostPosted: Thu Jul 30, 2009 1:57 pm    Post subject: Re: BruKrasa 36hp singleport heads Reply with quote
Tom have you got some comparison numbers for the exhaust flow ?
bvilletom wrote:
After about a year and a half of work, ... I have worked out a whole system from combustion chamber to carburetor entrance that out flows the Okrasa set.
bvilletom
bvilletom is offline
PostPosted: Thu Aug 06, 2009 4:05 pm    Post subject: Exhaust Airflow Numbers Reply with quote
Yes, Uncle Ian. I will post a bunch of 36hp exhaust flow numbers soon.
Also I will describe some interesting facts & observations between the Okrasa heads, stock heads, and modified heads. At first I didn’t work much with the exhaust flow on the 36 head because the stock exhaust valve flows are very close to the same as the intake. This bothered me so I concentrated on the intake only. Now the intake side of things are going pretty well with the Cook, Blackline, and Brukrasa modified single port heads. The exhaust flow numbers are very similar to late 1600 heads.
BvilleTom
bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
Unkl Ian
Unkl Ian is offline
PostPosted: Thu Aug 06, 2009 6:52 pm    Post subject: Re: Exhaust Airflow Numbers Reply with quote
Yes, modern race heads are typically ported so the exhaust flows
60-80% of intake. Depends on the application, and builder.
Looking forward to it.
Unkl Ian
Unkl Ian is offline
PostPosted: Thu Aug 06, 2009 6:54 pm    Post subject: Re: Exhaust Airflow Numbers Reply with quote
What class are you guys running this year ?
Going to take another run at NA36 ?
bvilletom
PostPosted: Tue Aug 11, 2009 4:58 pm    Post subject: 36 HP Air Flow worksheet Reply with quote
Posted are air flow summary sheets for two different 36 HP engines both with stock size valves and stock intake flanges. These both would be much better with big ports and bigger valves but this is just baseline information. The left side shows the average flow of 8 stock 36 heads. The far right side shows stock Okrasa flows, which has been my goal to equal or exceed. The center section shows a port by port intake and exhaust flow of a pair of heads identified to each port by the castings number and the date code. You will notice that all of the heads vary a little inflow from port to port because of valve head shape. Some are tulip shaped, some are flat, etc. The seat and throat shape, as well as the slight differences in port shapes and where the porting tool may have slipped a bit. On the modified intake sheet (4-27-09) the intake flows look better since I cut the guides off slightly to get more lift because of the use of high lift rockers and cam. The sheet from 04-27-09 is of the heads I ran at Maxton, NC in May, 2009 in the SSS (super stock single) class at 90.2 MPH.
Back to the exhaust, the Okrasa head slants the intake seat side of the exhaust port toward the exhaust flange quickly and the long side (top) of the port is raised toward the valve cover 1-2 mm. The best part of the exhaust port is that the short side port radius is about 5 mm higher into the port, causing less flow separation. Also the port just out from the valve guide boss widens out to about 35-36 mm and then blends into the long side radius. It is just about a “D” shaped port in the middle.
I measure all the ports with an inside caliper on the X & Y axis to plot out these diameters and shapes. I now flow all the ports without valves and actually get a before, during and after flow to get the port shape right. The whole key to getting flow is the right internal shape of the port. Bigger is not always better! Velocity works wonders. After that I get the valve shape, back cuts or whatever to make it work. With every set of heads that I’m doing now, I’m learning and improving the flow.
I could write a thread, if there is enough interest, of step by step instruction on how to port 36 heads, where to grind and where not to touch it.
Sheet #2 is coming soon.
Bville Tom
bvilletom
Shorrock
Shorrock is offline
PostPosted: Tue Aug 11, 2009 5:12 pm    Post subject: Re: 36 HP Air Flow worksheet Reply with quote
Bville Tom
Tom,
Better yet would be to find an interested shop that would follow your directions, map and document your heads so that I can send my set of NOS heads for Brukrasa setup preferably with bigger valves. The shop should cut you a check, small or otherwise, for each Brukrasa head made. Heck tell me where to send them and I'll cut you the check. I sincerely appreciate all your research and more importantly you willingness to freely share it.
I have given up on finding one more Denzel head so am ready to start working on my NOS 36hp heads. I also need to get the chambers/piston tops (pre-a supers) matched. One thing at a time. Heads!
Please
Unkl Ian
Unkl Ian is offline
PostPosted: Tue Aug 11, 2009 5:59 pm    Post subject: Reply with quote
Tom: Are you flow testing with a straight pipe on the exhaust,
and a radius on the intake port ?
Unkl Ian
Unkl Ian is offline
PostPosted: Tue Aug 11, 2009 6:00 pm    Post subject: Re: 36 HP Air Flow worksheet Reply with quote
Maybe Tom would be interested in flow testing the Denzel head.
Some people think they are superior to the Okrasa.
bvilletom
PostPosted: Tue Aug 11, 2009 6:45 pm    Post subject: Flow bench Reply with quote
U Ian
I am flowing the exhaust right out of the flange, you can make the numbers better with a pipe i know. On the intake I Just break the sharp edge with some sandpaper. I am interested in the basic numbers without all the B S fluff.
Bvilletom
bvilletom
Shorrock
Shorrock is offline
PostPosted: Tue Aug 11, 2009 7:43 pm    Post subject: Re: 36 HP Air Flow worksheet Reply with quote
Tom,
I would be more than happy to send you the Denzel head for flow testing, if you want to take the time to do it.
Just let me know and it is on the way.
Maybe all the hype about the Denzel head is just that!
Howard
TomSimon
TomSimon is offline
PostPosted: Tue Aug 11, 2009 9:55 pm    Post subject: Re: 36 HP Air Flow worksheet Reply with quote
[quote="Shorrock"][quote="Unkl Ian"]
Howard
I have looked at many drag race heads over the years, have two sets myself of type 1 heads that support 300hp on a 2.5 liter naturally aspirated... I had a chance to look at 36hp single, Okrasa 36hp DP, and Denzel 36hp DP... my educated eye would bet big money that if all things are equal, the stock Denzel head and manifold will outflow stock Judson by 20-30%.
Having made a bold statement, which I am not in the habit of doing, the flowbench will tell you for sure... dynoing an engine with those heads will tell the tail.
grueni
grueni is offline
PostPosted: Wed Aug 12, 2009 1:42 am    Post subject: Re: 36 HP Air Flow worksheet Reply with quote
there is big interest tom,...your work and your instruction will make you the mr. okrasa of single port for me.
you and the work from oval56 here in germany inspired me to build my singleports that will tested soon.
you have PM
Art Thraen
Art Thraen is offline
PostPosted: Sat Aug 15, 2009 6:29 am    Post subject: Blackline 57 Engines lower end, Look at Reply with quote
Blackline 57 Engines lower end, Look at cam clearence, or lack of
Look at the installed 1500cc barrels, clearenced for pushrod tubes
TomSimon
TomSimon is offline
PostPosted: Sat Aug 15, 2009 7:19 am    Post subject: Reply with quote
Hey Art, looking at the picture of the rod cap to cam lobe...
if a 36hp engine uses the same cam gear as a 1600, why the clearence issue with only a 74 stroke? You and I have both built big stroker T1 engines
Art Thraen
PostPosted: Sat Aug 15, 2009 9:30 am    Post subject: Reply with quote
Because the engine is smaller, but the cam/crank spred is the same.. But this is just how it worked out.. Close!
grueni
grueni is offline
PostPosted: Sat Aug 15, 2009 9:39 am    Post subject: Reply with quote
because the cam's from the camshaft sit on different places than typ1.
hold a typ1 cam next to a 36hp cam than you can see why (crankshafts also have other dimensions)
Art Thraen
PostPosted: Sun Aug 16, 2009 8:43 am    Post subject: Reply with quote
Yes the lobes are closer together.. closer to the rods, not so much between them.
Page 23 of 25
