BMW power windows in a 74 Westy
Westy Racer
Westy Racer is offline
PostPosted: Fri Jan 07, 2005 12:41 am    Post subject: Reply with quote
Thanks. I'm installing two switches on the drivers door and one on the passenger door, along with the BMW armrest & pocket. Wink
That's the project for the weekend. Need to go buy some 1/8" hardboard to fab the panels from.
If it don't werk, mess with it!
If it breaks, it needed replacing anyway...
74 Westy Custom werk in progress!!
Bus #10 - VW #27 I'm a freak... so are U!
Westy Racer
PostPosted: Thu Jan 13, 2005 12:46 am    Post subject: Reply with quote
OK a little update here. That little crimp in the tube that holds it in place...
...well that isn't enough to hold up to the stress. (had my doubts but that's prototyping)
I'm going to take it back apart, pull the motor, pull the cable from the regulator tube and weld two locators to the tube. That way the motor will have something to push/pull against... other than only bent metal.
It's got torque baby! Wink
mikeoldcars
mikeoldcars is offline
PostPosted: Thu Jan 13, 2005 10:39 am    Post subject: Reply with quote
is there a part number on the window motors?
excellant conversion btw Smile
dub dub dub
Daisythedevonmoonraker
View user's profile Send private message MSN Messenger Classifieds Feedback
Westy Racer
PostPosted: Sat Jan 15, 2005 10:30 am    Post subject: Reply with quote
Sorry but the tags with that info are gone. Crying or Very sad
Try these guys. Plenty BMW parts, great reference for part numbers for Bimmers.
Here is the motor you're looking for. Models it fits are listed with it so you can cross reference at your local parts yard. Wink
vw-traveller
vw-traveller is offline
PostPosted: Thu Jun 02, 2005 9:08 pm    Post subject: great idea got mine today!!!! question on the bending though Reply with quote
Hi
I love your idea, and i got some motors today at the local pick'n'pull! I got mine out of a 84 coupe bmw. Sure was wierd working on a non-vw.
I still have a question on where to bend the tube. Did you bend it on the ends that touch the drive motor? The picture isn't so clear.
thanx
tom
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
vw-traveller
PostPosted: Sat Oct 07, 2006 9:24 pm    Post subject: okay, time to answer my own question.... Reply with quote
All right, it didn't take me this long to put them in, actually it only took me a week-end, put i just wanted to post my experience.
A) The little backing plate, definatly weld that onto the regulator tube. Bending doesn't work vey long.
B) Make sure the tube is in the perfect position when you weld on the plate. On my driver side window it is and the window stops when it reaches the top, on the passanger side yiou can hear the motor still running once the window is up.
next project: making the rear lovered windows powered, since I always forget those when camping, and then realize it when they are flapping on the highway.
chrisradioman
chrisradioman is offline
PostPosted: Wed Sep 26, 2007 3:24 pm    Post subject: Reply with quote
Very Happy You are a genius I like it.
http://www.vintagevwweddings.co.uk/contact.html
mad.macs
mad.macs is offline
PostPosted: Fri Sep 28, 2007 8:00 pm    Post subject: Reply with quote
So, I haven't had much luck with this install.
The regulator tube is Very difficult to weld to (and I'm TIG welding).
There is no tolerance in the tube for any weld slag or deformation.
I tried a couple of hose clamps on it first, but those eventually gave way.
I had to order my motors from 2 different Junkyards and got 2 of the same motors, So now I need to figure out how to order the correct motor.
The first one I got was for the Driver door, but fit on the bus only on the Passenger side, So I ordered a Passenger side motor, but got another of the same.
Ugh- wish I had tried a SPAL window kit instead, By the time I get done with this it might have saved me time and money.
Opossum
Opossum is offline
PostPosted: Sat Sep 29, 2007 8:53 am    Post subject: Reply with quote
I MiG welded on the outside of the tube, piling up metal to prevent slippage. The windows have been fine for several years. They do take a little bit of tweaking to get right. I used the rear BMW motors as stated. Good luck.
"You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner
GfunkBus76
GfunkBus76 is offline
PostPosted: Sat Sep 29, 2007 12:13 pm    Post subject: Reply with quote
I used motors from Maserati, same style motor though. I didn't weld though, so I'm not sure how sturdy it will be over long periods of use(bus not yet operational).
Fun upgrade though Smile.
Gavin
1976 Westy - Customzation in slow-progress.
-8V TD swap
It Runs! -- http://youtu.be/kT5hOtwiOgk
And drives! - https://youtu.be/rVkoAgeOop0
mad.macs
mad.macs is offline
PostPosted: Mon Oct 01, 2007 10:56 am    Post subject: Reply with quote
I'm pretty sure The Fronts and Rears are the same. There is also a righty and a lefty as you state. When you look at the pics you can see the gear is on the RH side of the regulator on one of the motors photo'd and on the LH side on the other. I got 2 of the ones with the gear on the RH side.
The junkyard was kind enough to send me the other motor and offered to to P/U the return shipping too! Along with the regulator plate they didn't send with the first motor. The lesson here is if you get the chance order both from the same yard if possible.
The Passenger side works GREAT. I have the drivers side regulator all modded so it should drop in once the correct motor arrives.
mad.macs
mad.macs is offline
PostPosted: Fri Oct 05, 2007 9:31 pm    Post subject: http://web.mac.com/mad.macs/iWeb/Home/%2777%20Westy%20Blog/8 Reply with quote
Stuff I Wish I had known.
Extracting the regulators from the Bus does require removing the wing window. Doing this requires you to; undo the 10mm Bolt at location 1, remove the sheet metal screw under the weather stripping, and move the weatherstripping out of the way at location 2, and then swing the window to the rear to location 3.
I found that by enlarging the Regulator holes in the door the Bimmer motor can be mounted with 2 bolts.
The regulators do need to have something welded onto them to hold the motors in place.
Here is how the Bavarians did it.
Here is one of mine.
davis911s
davis911s is offline
PostPosted: Mon Nov 19, 2007 5:45 pm    Post subject: Reply with quote
I am half way through the install
What amp fuse did you use? I am thinking of using a 25Amp in line fuse
Shawn
"I choose to use CAA on old cars with character...instead of car payments on a new car Smile "
1973 Westfalia, Camper Special with 75 FI. Automatic 003 . Non-pop top
1977 Porsche 911S Targa, 2.7 L with 5spd
1992 Passat G60 Syncro Wagon (SOLD)
1975 Westfalia (SOLD)
1979 Westfalia (SOLD)
mad.macs
mad.macs is offline
PostPosted: Mon Nov 19, 2007 8:36 pm    Post subject: Reply with quote
25A Circuit breaker.
I kept poppin' fuses while trying to figure out the wiring for the SPAL window switches I installed.
I haven't tripped the breaker since I got the wiring correct.
autiger78
autiger78 is offline
PostPosted: Tue Nov 20, 2007 4:19 am    Post subject: Reply with quote
This one just got bookmarked...I love mods that don't seem more like hackjobs!
By the way, Gfunk, I like my odds of finding an 86 Bimmer better than the odds of stumbling on an 86 Maserati in the auto yards here in Alabama! Laughing
Wanted - Dormobile Roof Parts!
chrisradioman
PostPosted: Tue Nov 20, 2007 2:33 pm    Post subject: Reply with quote
Didn't know you could book mark, how do yo do it? Embarassed
davis911s
PostPosted: Tue Nov 20, 2007 5:00 pm    Post subject: Reply with quote
Ok drivers side is in. Laughing The vent window is a pain. Twisted Evil
Anyways the window is slow when going up. It is from the front felt window channel. I ended up bending this when I removed it during the install (dummy) Rolling Eyes
Anyways what is the CORRECT way to reinstall this felt?
When the regulator was out I cleaned an re-lubed it. I also bench tested the motor and regulator prior to installation and it was awesome. But now that there is tension it is way slower.
When I removed the front felt it is perfect so now I just need to get this installed RIGHT
Thoughts?
Shawn
davis911s
PostPosted: Tue Nov 20, 2007 5:03 pm    Post subject: Reply with quote
I think he just put this particular topic as a "favorite" on his computer. That is what I do
But also when you post a reply you can click the botton box
"Notify me when a reply is posted" that works well too
Shawn
Dudder
Dudder is offline
PostPosted: Wed Nov 21, 2007 1:35 pm    Post subject: Reply with quote
Sweet
You're Mr. Lebowski. I'm the Dude, so that's what you call me. Or maybe His Dudeness, or Duder, or El Duderino if you're not into the whole brevity thing.
Wild Bill
Wild Bill is offline
PostPosted: Thu Jan 21, 2010 12:51 pm    Post subject: Reply with quote
Thought I would revive this old thread to see if anyone has done this upgrade lately?
I plan on doing the same upgrade except rig the up and down switch to work with the original window winder.
You know it looks like the old manual system but a slight up or down on the handle makes the electric motor work. (Saw it like that on Barrett Jackson Auction 55 Chevy)
Any thoughts on the easiest and most effective way to make it work properly? (Other than just leaving stock).
Thanks
"Life in the Fast Lane ?....What the Hell does that feel Like?"
"Wild" Bill Tucker
Pensacola, Fl
1978 Champagne Edition (High Top Camper Converstion.) 2.0L FI
1969 Squareback 2.0L
www.rareairvw.com
Page 2 of 4
