radioman Samba Member
Posted: Mon Jan 10, 2005 8:55 am Post subject: engine compartment insulation |
Anyone insulated the firewall...for sound suppression? JCW has a bulk material that glues on (after cutting to fit). Any thought as to whether such material would help the noise? Beetles used it. Bill _________________ It's a Southern Thing, 73, stock.
Bill |
Miguel Arroyo Samba Member
Joined: April 02, 2004 Posts: 3122 Location: Miami Beach, Florida
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Mon Jan 10, 2005 11:03 am Post subject: |
I would think that the Thing is not insulated there to prevent rust as they are designed to be used in very wet conditions. If you use screws to hold on the insulation they will poke up through the rear storage area. |
Big Luni Samba Member
Joined: December 29, 2003 Posts: 427 Location: Hartford, CT
Posted: Tue Jan 11, 2005 9:20 am Post subject: |
"I would think that the Thing is not insulated there to prevent rust as they are designed to be used in very wet conditions."
The guys who built mine must have not have gotten the memo! |
TimGud Samba Member
Posted: Tue Jan 11, 2005 8:40 pm Post subject: |
I bet it would be easier to put carpet and some padding topside rather than insulating the engine compartment. |
edgy Samba Member
Joined: January 22, 2003 Posts: 424 Location: Bel Air, Maryland
Posted: Fri Jan 14, 2005 6:00 pm Post subject: |
Unless you never take your car out in the rain, you may be asking for rust due to condensation under the padding/insulation. _________________ 62 Single Cab (Work Truck)
63 Bungartz Tractor VW powered |
Posted: Fri Jan 14, 2005 7:14 pm Post subject: |
I have owned three Beetles...all with firewall insulation...never had a "rust" problem in that area. Drove them everywhere. Why should I expect "rust" in the Thing???? BTW, I don't drive it in bad weather....I got too much money in it. I may soon start keeping it in my dining room
Bill |
Posted: Sat Jan 15, 2005 8:14 pm Post subject: |
I wouldn't expect it to be a problem if you don't drive in bad weather. I've been known to leave the top down for weeks at a time, and forget to put her in the garage before an unexpected rainstorm. That's why I don't deal with insulation or carpeting, but if your firewall isn't going to get wet, knock yourself out! |
TimGud Samba Member
Posted: Mon Jan 17, 2005 8:49 am Post subject: |
Most offroad vehicles don't have carpeting and insulation because they get very muddy and wet from crossing streams and the insulation and carpet will rust out the metal below it. I have had water in mine a couple of times so carpet and insulation isn't a smart option for me. I have always assumed that is the reson there is no firewall insulation or carpet on the thing. I realize (and most others do to) that most people don't actually use their thing this way and alot have put this stuff in it and it will not rust when kept dry. |
edgy Samba Member
Posted: Mon Jan 17, 2005 6:43 pm Post subject: |
I've owned several Beetles, a couple I bought new. When it rained, the interior stayed dry. In the Thing, unless you have some custom top and closed all the holes, it will leak in the rain. At Kuebeltreffen East 2003, one returned from the scavenger hunt and had to bail the water out of the front floorboards. All the Thing driver's could relate. Are you new to this? _________________ 62 Single Cab (Work Truck)
Posted: Mon Jan 17, 2005 9:28 pm Post subject: |
The Thing has drain holes in the floorpan. You gotta drive up a hill to drain it, but it should drain. If you have the original floors, pull out the rubber plugs. If the floorpans have been replaced with Ghia pans (as most pans have been by this point), new holes should be drilled. |
Posted: Mon Jan 17, 2005 9:30 pm Post subject: |
Oh yeah- and keep a towel handy for the area behind the seats, since water will collect in the corrogations.
-Luni Loc |
Cattywompus Samba Member
Joined: October 20, 2004 Posts: 15 Location: Erlensee, DE
Posted: Wed Jan 19, 2005 10:38 am Post subject: |
I'm getting ponding around the pedals...any solution? |
Posted: Wed Jan 19, 2005 1:29 pm Post subject: |
My origianl post had to do only with the firewall in the engine compartment. Not everywhere this thread has gone. _________________ It's a Southern Thing, 73, stock.
Bill |
edgy Samba Member
Posted: Thu Jan 20, 2005 12:57 am Post subject: |
You should be able to figure out the common theme. Things leak like all hell. Do you really want to add a sponge to hold the water in an odd place. Insulation works by having dead air spaces, same as a sponge. Only a sponge holds water. Now back to the main point, if you never go out in the rain, go for it. If you do, you'll be sorry. _________________ 62 Single Cab (Work Truck)
