jberger Samba Member
Posted: Thu Jan 13, 2005 2:00 pm Post subject: Total dist advance |
Howdy,
So, does anyone know the total advance of a dual canister 79 distributor? Mine will go to about the end of the scale while operating the butterfly with timing light connected. I am getting the correct amount of vacuum advance as when I disconnect the retard side timing jumps about 7d or so. I keep reading that people are cruising at 70-75mph @20mpg, mine will get up there on flats with quite a bit of throttle input but head temps jump really high. Could be not enough advance under load? I have plenty of power around town in the first three gears but 4th on the highway my head temps go up and it likes to cruise at 60mph. This is a high top, so I have nothing to compare it to.
Thanks. |
Randy in Maine Samba Member
Posted: Thu Jan 13, 2005 2:16 pm Post subject: |
Advance/Retard Range: Vacuum: 11-13deg Adv @ 9.4 In. Hg, 11-13deg Ret @ 9.4 In. Hg; Centrifugal: 9-13deg @ 1600 rpm, 12-16deg @ 2800 rpm, 21-25deg @ 3600 rpm
Well I am calling it a vacuum advance of 11-13* + the centrifical total of 21-25* at 3600 = 32-38* total. Maybe I am not calculating that correctly though.
With your vacuum gauge, tach, and timing light you should be able to check each one to see if you are in the zone.
See if it helps to pull off the vacuum retard (and put a golf tee in that hose) and set the timing to 7.5* BTDC at correct idle. Check you temps as you go on a familiar road.
Also when timed to 5* ATDC, when I pull off the retard line, the timing immediately goes to the 7.5*BTDC |
Posted: Thu Jan 13, 2005 2:29 pm Post subject: |
Sorry, 11 deg vacuum advance is right. I have done the pencil in the retard trick and it doesn't change anything. I think I am ok, just don't have anything to compare it to for drivability. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Thu Jan 13, 2005 3:15 pm Post subject: Re: Total dist advance |
jberger wrote: |
Howdy,
So, does anyone know the total advance of a dual canister 79 distributor? Mine will go to about the end of the scale while operating the butterfly with timing light connected. |
38 is correct. The scale only goes to 40 right and there is going to be some error in the distributor even with it operating corectly.
Quote: |
I keep reading that people are cruising at 70-75mph @20mpg, mine will get up there on flats with quite a bit of throttle input but head temps jump really high. |
How high?
Quote: |
Could be not enough advance under load? I have plenty of power around town in the first three gears but 4th on the highway my head temps go up and it likes to cruise at 60mph. This is a high top, so I have nothing to compare it to. |
With today's temperatures my around town head temps are 300-330F. If I go out on the highway and hit 70mph they almost hit 400F. At 60mph the temperatures are closer to 340F.
Just for reference I'm using thermocouple with cold junction compensation so these temps are exact. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Thu Jan 13, 2005 3:29 pm Post subject: Re: Total dist advance |
ratwell wrote: |
jberger wrote: |
Howdy,
How high?
Just for reference I'm using thermocouple with cold junction compensation so these temps are exact. |
On a dry day at 55deg outside temp my gage reads about 150 before running. On a wet day about 200. Around town I am about 300 corrected. Highway at 65mph about 400. As soon as I go uphill they go to 425 or so (always shift at that point if not before). 3rd gear at 45-50 mph up a steep incline the temps rise slowly, in second at 30mph up any grade the temps drop and hover around 375. It is just that by reading the posts it sound like people are doing 70-75 with ease. That just doesn't sound right to me, 67hp with a 3500lb wind break. 60-65 seams more like norm. |
Posted: Thu Jan 13, 2005 3:43 pm Post subject: |
Your bus seems normal to me.
I have no trouble going 70-75mph but the engine is clearly working hard to keep that speed. _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Thu Jan 13, 2005 3:47 pm Post subject: |
Yeah, I think so too. Sometimes I am like an old dog, every once in a while I like to chase my own tail around in circles. |
Posted: Thu Jan 13, 2005 4:02 pm Post subject: |
It's amazing to me that the car runs well when you first start it and the exhaust is cold but as the engine heats the exhaust becomes hot. Stupid cast iron. _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Thu Jan 13, 2005 4:06 pm Post subject: |
quoi |
nemobuscaptain Samba Member
Posted: Thu Jan 13, 2005 4:35 pm Post subject: |
Then you have a problem, either with the vacuum leak, malfunctioning retard, or your vac hoses improperly connected. Throw a vacuum guage on the engine. You should have around 15 inches. If not, you have a leak (or your at altitude). If you have a vacuum leak, you must find it or your engine won't be long for this world. (While you're at it, the port that has vacuum at idle should be connected to the retard and the one that has vacuum as you open the throttle is for the advance.)
I have a cheap vac guage that also allows me to pull vacuum (and bleed brakes). Hook one of those up to the retard nipple (the one pointing inwards toward the dizzy) and see if it actually retards your timing (by using the strobe). If it's a bad retard mechanism, I'd be happy with capping off the dizzy and the carb and forget it. However, |
Posted: Thu Jan 13, 2005 4:41 pm Post subject: |
nemobuscaptain wrote: |
Sorry, I thought it was clear that I was referring to it not changing head temp readings. I have no vacuum leaks. |
Posted: Thu Jan 13, 2005 4:53 pm Post subject: |
So does the vacuum retard work correctly? |
Posted: Thu Jan 13, 2005 5:07 pm Post subject: |
Yes it does. My concern was that I am not getting enough total advance under load at highway speeds causing high head temps. In the end it seams I am a little sensitive about pushing my beloved bus too hard. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Jan 13, 2005 5:21 pm Post subject: |
jberger, please note that over-advanced timing can cause head temperature problems as well, actually, air-cooled engines are much more sensitive to over-advance than the other way around. Your maximum advance under load, where it really counts, does not involve the vacuum advance unit which deactivates under full load anyway. Try adjusting your timing at 3,000 rpm, no more than 25* to start with no hoses on the distributor. Then test-drive with everything plugged back in. Any change? Now try 28* at 3,000 rpm. Any change in head temps? Which direction? That will be your trend, follow it a little further to see if you can get into your proper zone, but don't leave the general specifications window. If you can't fix head temps with a little timing adjustment, and a little mixture richening, then you have something else to look at..
Colin _________________ www.itinerant-air-cooled.com |
Posted: Thu Jan 13, 2005 5:52 pm Post subject: |
Amskeptic wrote: |
Your maximum advance under load, where it really counts, does not involve the vacuum advance unit which deactivates under full load anyway. |
How do you figure that?
Looking at the oldvolks.com specs that Randy posted (11-13deg Adv @ 9.4 In. Hg) what are you saying the vacuum level should be under full load? _________________ '78 Westfalia CDN
'76 Doublecab
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu Jan 13, 2005 9:38 pm Post subject: |
As hard as it is to grasp, ported vacuum to the vacuum advance goes away on full throttle. Best way to show it is with a vacuum gauge and a long hose and a test drive. |
Posted: Fri Jan 14, 2005 8:45 am Post subject: |
ratwell wrote: |
It's amazing to me that the car runs well when you first start it and the exhaust is cold but as the engine heats the exhaust becomes hot. Stupid cast iron. |
It hit me in the shower this morn. Sometimes its gonna do what its gonna do. |
Duncwarw Samba Member
Posted: Fri Jan 14, 2005 11:14 am Post subject: |
Not to hijack the thread, but Richard, where did you get your compensator?
TIA |
Posted: Fri Jan 14, 2005 11:53 am Post subject: |
Karl wrote: |
It makes sense. _________________ '78 Westfalia CDN
'76 Doublecab
