rear hatch lock: will a central locking lock work?
maco70
maco70 is offline
PostPosted: Sat Jun 28, 2014 8:56 am    Post subject: rear hatch lock: will a central locking lock work? Reply with quote
Hi,
I have a vanagon 86 on which don't have central locking system.
The rear hatch lock is broken.
Can i replace it by the ones sell a Van-Cafe which is for vanagon with central locking system?
http://www.van-cafe.com/home/van/page_1386_850/rear-hatch-lock-with-keys.html
Thanks in advance,
Martin
Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior)
Steelhead
Steelhead is offline
PostPosted: Sat Jun 28, 2014 9:05 am    Post subject: Reply with quote
have you asked van-cafe? they know their stuff.
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
maco70
maco70 is offline
PostPosted: Sat Jun 28, 2014 9:09 am    Post subject: Reply with quote
Yes and Peter wasn't sure. I will try it soon, but not now.
My opinion is it should work, but i am not sure and the model without locking central system part is very rare and hard to find.
16CVs
16CVs is offline
PostPosted: Sat Jun 28, 2014 9:22 am    Post subject: Reply with quote
It should work ,you just have to "Park" it in the correct position ,as the actuator just moves it into and out position to allow the button to push it .
That lock has 3 positions where a non power has 2 and the 3rd is an override to open the door from the back when the powers are locked .
Stacy
Samba member # 14980
maco70
maco70 is offline
PostPosted: Sat Jun 28, 2014 9:40 am    Post subject: Reply with quote
Is this tricky, or an easy task, Stacy, to put the actuator in the right position?
jmranger
jmranger is offline
PostPosted: Sat Jun 28, 2014 11:30 am    Post subject: Reply with quote
Salut Martin,
I hope it works, because I have a whole original power lock kit in my basement waiting to be installed. I haven't pulled the panel on the van, so no picture of the non-power-lock version, but here are some of the power-lock version:
The whited-out parts are where the key number is located
My understanding:
- the lock is pictured with the top up, with the key in the "locked" position (Edit: wrong. It is upside down).
- in the "unlocked" position, the metal part where the whited-out part is located would be turned 1/4 turn clockwise. In the top picture (which I guess is the "power-door-lock locked position", pressing the button would do nothing. In the bottom picture, it would allows the latch to operate.
- in the "special, power-door-lock-only position" (1/8th turn counterclockwise), the latch would operate in both "states".
Switching from the 1st to the 2nd position is just pushing the part on the rod. Actually, the little white connector on the bottom is where the power door rod is attached.
Don't forget to switch the tumblers from your old latch to the new one. It only required removing the roll ping that is barely visible in the picture).
Good luck,
Jean-Marc
maco70
maco70 is offline
PostPosted: Sat Jun 28, 2014 3:06 pm    Post subject: Reply with quote
thanks / Merci beaucoup Jean-Marc.
it is very helpful.
jmranger
jmranger is offline
PostPosted: Sun Jun 29, 2014 12:45 pm    Post subject: Reply with quote
So a few more notes now that I made the switch (and fixed some errors in my previous post):
- The non-power-door-lock part
Installed (again, with the key code whited-out):
And be aware that you have to switch the tumblers to regain your original keying. You can't just switch the lock cylinders whole. One place where the difference between the cylinders is obvious is at their end: one is half round, half square, the other is square with a cut corner (sorry for the bad picture).
See also http://www.thesamba.com/vw/forum/viewtopic.php?t=553954
Also, it doesn't impact functionality, but be aware that the power door lock part extends roughly 1/4" more outside the hatch than the non-PDL part.
Jean-Marc
