Dehne gauge info. needed please
restojohnny
restojohnny is offline
PostPosted: Wed Nov 24, 2010 6:37 pm    Post subject: Dehne gauge info. needed please Reply with quote
Can you use a regular VDO/stock fuel sending unit for the dehne fuel gauge pictured below ?? If not what can I use ??
$$$ HUSTL'N AIN'T EAZEE $$$
** HELL YEAH I'LL SELL IT TO YOU**
O.G. POMONA VULTURE
MAGNESIUM BRM HOARDING BASTARD !!!!
$$ SWAPMEET MAFIA $$
48 split $$$$
53 LHD, LH cargo door standard kombi
54 Pre-A Porsche
55 oval ribbed door non-semiphore
56 semiphore ragtop
63 notchback (work in progress)
67 original Empi GTV beetle convertible !!
67 deluxe walkthru (work in progress)
67 convertible ghia (work in progress)
"STAY OUTTA MY BACKYARD !!! "
vw7266
vw7266 is offline
PostPosted: Wed Nov 24, 2010 9:02 pm    Post subject: Reply with quote
you much have barely beat me to that...I was the 7th person to look at that ad..
and I think that the sending unit is repo'd by the guy in Mass.
restojohnny
PostPosted: Wed Nov 24, 2010 10:36 pm    Post subject: Reply with quote
Wink
O.G. POMONA VULTURE
48 split $$$$
54 Pre-A Porsche
56 semiphore ragtop
Jake Martinez
The VW Kid
Jake Martinez is offline
PostPosted: Wed Nov 24, 2010 10:42 pm    Post subject: Reply with quote
..When was this ad posted? Never saw it... Shocked ...I'm assuming it was a good deal?
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote:
buslife wrote:
10 inch narrowed beam
Congrats, that's going to look like shit.
vw7266
vw7266 is offline
PostPosted: Wed Nov 24, 2010 11:08 pm    Post subject: Reply with quote
about 1:30 am east coast time...I would have spent the 50 bucks
oval56
oval56 is offline
PostPosted: Thu Nov 25, 2010 12:43 am    Post subject: Reply with quote
nope, the vdo unit is not working, brezelwerks does a modification to the arm and housing, it will work, but it looks a bit strange.
i do rebuild the gauges also (orignal metal version) and in the near future i might be able to made some sending units.... but we will see...
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
restojohnny
PostPosted: Thu Nov 25, 2010 9:26 am    Post subject: Reply with quote
Yeah that's the one for $50.00 I had an extra sending unit but a buddy needed it so I let him have it then this one pop's up Crying or Very sad Oh well I'm pretty good at finding stuff I guess I'll find another one in time. This one will go on my 57 ghia I just scored Wink
O.G. POMONA VULTURE
48 split $$$$
54 Pre-A Porsche
56 semiphore ragtop
restojohnny
PostPosted: Thu Nov 25, 2010 9:27 am    Post subject: Reply with quote
Please keep me informed when / if ever you get to making/rebuilding sending units buddy Cool
O.G. POMONA VULTURE
48 split $$$$
54 Pre-A Porsche
56 semiphore ragtop
oval56
oval56 is offline
PostPosted: Thu Nov 25, 2010 11:07 pm    Post subject: Reply with quote
we ar on it Smile
www.oval56.com
www.dbkvw.com
Brezelwerks
Brezelwerks is offline
PostPosted: Tue Dec 07, 2010 7:40 am    Post subject: Reply with quote
Its great others are working on these gauges also!
The standard mechanical VDO sending units do work well. The main modification is reverse bending the float arm, basically so it pulls the cable as the float sinks in the tank, thats the easy part. Doesn't look too strange otherwise, and once its in the tank no one can see the float.
From there the question is just how original looking do you want your VDO sending unit to mount, and also look from the outside? If you want to install and have it look the same as the Dehne (with one hole in the tank), we custom cut the split washer nut (the inside the tank piece which secures the sending unit housing to the tank). This nut rotates into the tank exactly same as the Dehne sender does.
Without this split nut washer alot of work would be needed in able to modify your tank with nuts welded on the inside of the tank which match the screw pattern of the VDO sending unit. You can't tap nearly enough machine screw M5 threads into the thin gas tank metal. Instead, making the split nut washer would take a tenth of the time to do, plus it looks like the Dehne. Now, I've once seen someone fastening down a VDO sender to an oval tank with #10 sheet metal screws (through undersized holes drilled into the tank), and that will work and be rather fast to install it that way, but its nowhere as reliable as machine screws, and there is no way to get a nice concentric seal on the top to minimize gas fumes.
Mechanically the original style underside washer nut squeezes completely around the hole cut in the tank, so it squeezes from top and bottom. Sheet metal screws only give you that seal in one direction and its not even, so if someone decides to go with sheet metal screws you would want to use a generous amount of silicone or better yet a gas resistant epoxy all around the bottom of the sender and on the cork gasket you make/use. You need the best seal you can possibly make. You don't need a sealant with the split washer nut.
Other than the split washer nut all there is needed is @1/8" thick cork gasket, and neither of these parts are too difficult to make on your own, but the split washer nut should be 1/8" steel with all the M5 tapped holes for the top sender screws to fit through, in case anyone is interested in the DIY route.
What might look strange to some though once you have your VDO sending unit installed, would be seeing a VDO cap on top of the sending unit when it comes to looking at the gas tank. Our reproduction Dehne sending unit cap though is die stamped to fit specifically over the VDO sender, plus we put our perfect copy of Dehne water slide decal on top. So when you are done, no one would ever guess the internal mechanism is VDO.
Just mentioning the above to help others make the most appropriate decision for them, as not everyone is particular about all the details. We're also booked solid here for the next few months, and not planning to do any Dehne work until at least mid/late March.
But would definitely love to know more what Dehne sending unit Oval56 might be working on, would be good for others to know and have some other options to consider.
oval56
oval56 is offline
PostPosted: Sat Feb 19, 2011 6:35 am    Post subject: Reply with quote
so time is going on, first samples are made and the process is going on.
to sender styles will be availible in limited quantity.
i will not reproduce stuff to make original cheaper, first mission is to complete original ones.
the floaters are in progress in the moment.
some pictures ...
www.oval56.com
www.dbkvw.com
oval56
oval56 is offline
PostPosted: Mon May 23, 2011 10:38 am    Post subject: Reply with quote
slow but step by step...
www.oval56.com
www.dbkvw.com
Mike Fisher
Mike Fisher is offline
PostPosted: Tue May 24, 2011 7:50 am    Post subject: Reply with quote
Nice work! I hope your fellow Bug owners don't Whine about paying you for all your time/trouble! Twisted Evil
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Sat May 28, 2011 5:55 am    Post subject: Reply with quote
Beautiful work! if love to get one! Do you make the square style dehne with the metal back to replace the original brittle plastic? I'd like to get one!
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
oval56
oval56 is offline
PostPosted: Mon May 30, 2011 2:32 am    Post subject: Reply with quote
got my casted sending housing yesterday, they go to machining this week, so the end of line is in sight.....
3-4 weeks and i'm ready for sale
for the square dehne (57 and up) i can replace the plastic gauge with my metal version.
www.oval56.com
www.dbkvw.com
oval56
oval56 is offline
PostPosted: Mon May 30, 2011 12:56 pm    Post subject: Reply with quote
one step more..... next zinc plate
www.oval56.com
www.dbkvw.com
jurgen272
jurgen272 is offline
PostPosted: Wed Jun 01, 2011 11:48 am    Post subject: Reply with quote
Any idea when it will be completely finished and available?
Price?
67 type 2 (walkthru - sliding door)
57 oval ragtop (in restoration)
63 Karmann Ghia coupe
58 Karmann Ghia coupe
oval56
oval56 is offline
PostPosted: Thu Jun 02, 2011 12:53 am    Post subject: Reply with quote
Price?
jep we will have it ready for sale finaly end of june... last steps are in progress
for price, PM me
thanks
www.oval56.com
www.dbkvw.com
oval56
oval56 is offline
PostPosted: Wed Jun 15, 2011 1:45 pm    Post subject: Reply with quote
some steps closer to an end...
www.oval56.com
www.dbkvw.com
Not Safari Izzy
Not Safari Izzy is offline
PostPosted: Thu Jun 16, 2011 3:29 pm    Post subject: Reply with quote
Wow Andi, really nice!!
DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151
