graeme Samba Member
Joined: March 17, 2006 Posts: 133 Location: sheffield england
Posted: Wed Apr 05, 2006 3:36 am Post subject: blaupunkt koln din socket |
Hi, i have a blaupunkt koln radio, it has a 6 pin din to connect a tape player, i want to use this socket to connect an ipod.
Does anyone know how i can go from mini jack to 6 pin din?
Or does anyone know what pins are the signal input pins so i can make something up?
I have the circuit diagrams.
Thanx. |
Hong Kong Syndicate Samba Member
Posted: Wed Apr 05, 2006 4:19 am Post subject: |
For a Blaupunkt radio in mono mode:
For a Blaupunkt radio, but in stereo mode:
You can found more infos in ANTIQUE AUTORADIO MADNESS
It's in french, but, whit the pics you can do it! |
graeme Samba Member
Posted: Wed Apr 05, 2006 4:49 am Post subject: |
Its a mono radio, they help but im still confused.
I assume i can link the left and right outputs together as the radio is mono, so i need to connect one positive input and one negative input.
In radio mode pins 1 and 2 are bridged, do i need to keep them bridged when using the ipod?
I think you need to break the bridge to stop the radio working, so you just here the alternative input. |
graeme Samba Member
Posted: Wed Apr 05, 2006 4:58 am Post subject: |
does that mean the speaker possitives are linked and go to both 1 and 2 pins
and the speaker earths are linked and go to number 5 pin?
Are they resistors on the speaker positives? 4.7 kohm?
I dont understand electronics.
If 1 and 2 are bridged, doesnt that mean the radio will also work?
The manual says the radio wont work unless they are bridged.
You remove that bridge when you connect a tape player.
Thanx for your help. |
graeme Samba Member
Posted: Wed Apr 05, 2006 5:06 am Post subject: |
Ok, i translated the sight with babel fish, makes sense now.
Not sure about how you listen to the ipod withput hearingthe radio, but im sure ill work it out when its all installed.
Thanx. |
graeme Samba Member
Posted: Wed Apr 05, 2006 7:17 am Post subject: |
one last thing, whats is the din socket?
It doesnt seem to be a normal din socket.
I need to get a connector so i can modify it.
Thanx |
Posted: Wed Apr 05, 2006 8:36 am Post subject: |
Hi Graeme! For the electronic SOS, I can not help you, in this domain I'm a total Nono! My capacaties in this domain are worth than my english! Sorryyyyyyyyy I know how to use a iron...engraving (well, almost) not more!
=> For that, you have to found the frequency where the IPOD send the audio signal. In this case the IPOD (or the Mp3 Player works like a slave, like the old time whit a tape player). I do one some time ago for my Koln and it's woks grat whit my Denver Mp3 Player. The problem is more more whit the poor power of the amplicator
One last thing, whats is the din socket?
=> DIN: deutch industry norm
=> For the Old Europe it's a normal socket, and almost universal. In States? I dont know...sorry |
graeme Samba Member
Posted: Wed Apr 05, 2006 8:57 am Post subject: |
| thanx alot, very helpfull. |
wimkever Samba Member
Joined: July 16, 2004 Posts: 437 Location: Holland (the Netherlands)
Posted: Wed Apr 05, 2006 11:54 am Post subject: |
The six pin "DIN" plug at the back of the radio is not really DIN, it's a "Blaupunkt special". You can get a complete cable + connector at :
http://www.koenigs-klassik.de/Zusatzgerate/zusatzgerate.html
You'll have to remove the plastic "Bridge" that is inserted at the "Din" plug, and your radio will stop to allow you to listen to your Ipod without the radio playing at the same time. You'll need as switch to be able to toggle between radio and Ipod : a kind of replacement for the original "bridge" . I think it is included in the set you can buy at Rainer Koenigs (link) shop.
greetings from Holland _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Wed Apr 05, 2006 9:27 pm Post subject: |
| wimkever wrote: |
| The six pin "DIN" plug at the back of the radio is not really DIN, it's a "Blaupunkt special". |
All the mono Blau's I've seen use a standard 6-pin DIN plug. There are 2 versions of a 5-pin but I only know of 1 version for 6-pin. If you want to make your own cable, you can get just the plug from Cablestogo.com or universal-radio.com in the U.S., or in the U.K you can try Maplin Electronics at
http://www.maplin.co.uk/Search.aspx?criteria=HH29G&DOY=6m4
graeme Samba Member
Posted: Thu Apr 06, 2006 2:56 am Post subject: |
thanx folks, im going to order the cable from wimkever's link.
Its easier and probably cheaper than making one.
The blaupunkt radios dont have a selector.
the switches behind the knobs are tone controll and radio reception sensitivity.
the lead im buying has a jack socket so you need a mini jack to mini jack.
If jack is plugged in the radio stops, unplug it and radio starts again.
I foung out there are different types of din, different degrees.
But ill just buy that cable, its easier.
Thanx again. |
Posted: Thu Apr 06, 2006 11:31 am Post subject: |
You're right. I have a lot of Blaupunkts (most Frankfurts) standing behind me this very moment. None of them have a switch behind the tuning knob.
succes
Wim _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
tomf2 Samba Member
Joined: April 10, 2006 Posts: 2 Location: Massachusetts
Posted: Mon Apr 10, 2006 1:34 pm Post subject: |
| So, which pins do I use to activate an electric antenna from a Blaupunkt Frankfurt mono, vintage 1973, without an connection for an antenna? No. 2? |
graeme Samba Member
Posted: Mon Apr 10, 2006 1:50 pm Post subject: |
| dont know about the frankfurt, but the koln has a seperate amp. Above the power input there is a little connector, that is the power ariel feed. |
Howard66 Samba Member
Joined: September 15, 2005 Posts: 138 Location: London, UK
Posted: Tue Apr 11, 2006 3:24 am Post subject: |
let me know how it works with that cable. I made my own (just a straight cable, no switch or anything) but while it was plugged in my radio did not work. I had to remove the cable from the radio to listen to it. _________________ 1966 Volkswagen 1300
1978 Triumph Dolomite Sprint
1962 MGA 1600 MKII
1962 Austin Mini Seven
1970 Triumph Spitfire IV
1965 Mobylette SP50
1985 Sinclair C5 |
graeme Samba Member
Posted: Tue Apr 11, 2006 4:04 am Post subject: |
The cable they sell has a mini jack socket, so you need a minijack to mini jack lead.
Have the socket in the glove box.
Apparantly the radio cuts out when the mini jack is removed so no need to remove the cable from the radio. |
rickycox Samba Member
Joined: April 14, 2008 Posts: 21 Location: London, England
Posted: Mon May 19, 2008 8:30 am Post subject: help............. |
Please help someone... I followed the diagram below for wiring lead for mono Emden radio to i pod etc...
But when I plugged it in it cut out the radio ( good ) but the ipod sound wont come out of the speakers and now the radio has no sound either.. !!
The illumination light still shows there's power to the unit but when you try and tune you get no sound / crackle or anything ... any ideas ..
R |
Posted: Mon May 19, 2008 10:23 am Post subject: Re: help............. |
| rickycox wrote: |
R |
Does the radio still work if you put the original jumper plug back in? If so, you've just got something wired wrong on your new plug. If not, the radio is dead. There is usually power on pin 4 of the mono plug so if you mixed up the connections you could have fried something in the radio. |
Posted: Tue Jun 03, 2008 7:49 am Post subject: ...... |
No sound at all...... I've triple checked the wiring and is as the diagram shows... so still stumped
