What transmission oil to use in bus tranny?
robot909
robot909 is offline
PostPosted: Fri Sep 09, 2005 1:37 am    Post subject: What transmission oil to use in bus tranny? Reply with quote
Any recommendations of what transmission oil to use in a bus tranny?
I have been recommended 90 weight hypoid oil from a reputable source but all I could find at a local auto store is a valvoline 80W-90 high performance gear oil.
My source said that was OK, and I trust his word. Any word of advice? What exactly is "hypnoid gear oil"?
Also, the transmission case takes (if dry) 6.3 pints and reduction boxes .5 pints each. After filling and driving for a few miles, refill center transmission till the oil spill over. Right?
Thanks and look forward to being back on the road!
-Pete
View user's profile Send private message AIM Address Facebook Twitter Gallery Classifieds Feedback
Flipseat
Flipseat is offline
PostPosted: Fri Sep 09, 2005 4:14 am    Post subject: Reply with quote
Sta-Lube GL4 available at NAPA. I believe its 85W-90. Its in a white and turquoise jug. Its about 12-13 bucks a gallon. Fill the boxes, then fill the center section. Drive for a little bit and re-check the center section. Fill it till it starts dribbling out the fill hole on level ground.
Other bottles will say GL5, GL4, etc "compatible". Don't get the one that says anything about GL5 on it.
Insert random important looking club initials here.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Sep 09, 2005 4:29 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=130623
This has been beaten to death.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
frijole73b
frijole73b is offline
PostPosted: Fri Sep 09, 2005 5:15 am    Post subject: Reply with quote
sythetic, yeah
http://www.type2vw.com
http://www.countrymacquack.com
"everthing is always for sale for the right price"
Stocknazi
Stocknazi is offline
PostPosted: Fri Sep 09, 2005 5:06 pm    Post subject: Reply with quote
make sure you use gl-4 and avoid anything that says gl-5
sta-lub works well and is what i run
check your bently for technical info on trans oil!
WANTED:
Thomas Jefferson
MrPolak
MrPolak is offline
PostPosted: Sat Apr 25, 2015 5:01 pm    Post subject: Reply with quote
I just picked up GL-4 Sta-Lube gear oil from Napa. It's the correct old school stuff. Not cheap, either. I could have filled it with synthetic for that money.
Mr. 010
Glenn is offline
PostPosted: Sat Apr 25, 2015 5:07 pm    Post subject: Reply with quote
Please use the existing topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=276529
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Split Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
