65Busstop Samba Member
Joined: January 06, 2004 Posts: 312 Location: Akron Ohio
Posted: Thu Jan 22, 2004 6:34 pm Post subject: Installing a dual master cylinder |
I was thinking about putting a dual master cylinder in my 65 Bus for safety reasons. Has anyone done it? And is there much invovled in doing it?
TIA |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Thu Jan 22, 2004 6:58 pm Post subject: |
go to www.type2.com
click on library
click on brakes
there is an article by eric and barb on how to do the conversion at the bottom of the page. _________________ I'd rather be a free man in my grave, than living as a puppet or a slave.
_____________________
http://www.rideable.org/
http://www.oslp.org/ |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Jan 23, 2004 2:34 am Post subject: |
Just did it following Eric & Barbs article. Cut my own spacer out of 3/8" phenolic instead of paying Wolfgang $40 for their aluminum one. http://www.wolfgangint.com/html/SinglePartDisplay....1472958219
Used a 70's Rabbit reservoir ($4 from PickNPull) to match a new 70's bay M/C, had to get a new T-fitting and an extra 6" line for the front lines, and a couple longer bolts. Bent existing lines slightly to get everything to fit, and made a new shaft from a new metric bolt to connect to the pedal. Haven't tested it yet as the brakes still need to be adjusted and bled. All in all pretty easy to install, took several hours including parts fabrication time. The main problem locally is nobody stocks metric brake lines, T-fittings, etc. so I had to order them. _________________ ~~~~~~~~
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus |
Mr Tim Samba Member
Joined: December 26, 2003 Posts: 41 Location: Rugeley, England
Posted: Wed Feb 18, 2004 4:39 pm Post subject: Duel master cylinder |
You mention in this thread using a "rabbit" master cylinder resevoir, would that be what we in the uk know as a "golf" and you say from the 70`s is that correct.  _________________ Do Your Bit Save A Split
"Lifestyle is the art of discovering how to live uniquely" --- Jim Rohn |
Posted: Wed Feb 18, 2004 7:31 pm Post subject: |
Over here Golf & Scirocco came out in '74 and Rabbit in '75. I'll bet they're all pretty much the same reservoir. Even a 70's and maybe 80's Volvo reservoir will fit. Just make sure the distance between the nipples on the reservoir match the master cylinder. And buy new rubber seals for the top of the master cylinder where the reservoir plugs into it. And a 1/2" or maybe even 5/8" spacer would be better than the 3/8" one I made. Then the filler on the reservoir will be that much closer to actually being under the hole in the floor. _________________ ~~~~~~~~
62 SC & 66 Bus |
