Rattakus Samba Member
Joined: December 17, 2004 Posts: 17 Location: Gresham
Posted: Tue Feb 21, 2006 6:53 pm Post subject: Passenger Mirror Instalation |
Howdy. I have a 66 Baja that I am putting together for my wife. I bought her mirrors for both sides. The problem I am having is that the drivers side had a place to screw the mirror into and the passenger side does not. How do I make it so that it will instal. I assume I need the same screw set up from the drivers side. Can I just take one from another bug and once I have it do I have to take the door off to get it on. Thanks.  _________________ 70Bug
04 Jetta |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
markm Samba Member
Joined: July 21, 2003 Posts: 986 Location: Seattle, Via Beautiful El Sereno CA.
Posted: Wed Feb 22, 2006 5:55 am Post subject: |
RareAir wrote: |
You'll need an air hammer to remove you old hinge pin. Then replace it with a threaded hinge pin to accept the mirror. Part #111857514
You make it sound so easy. The hinge pin is a bitch to get off, even with an air hammer. I had to take my door off to get the hinge pin off. Good luck. |
Posted: Wed Feb 22, 2006 7:55 am Post subject: |
markm wrote: |
RareAir wrote: |
You'll need an air hammer to remove you old hinge pin. |
I've replaced 6-10 hinge pins in the last year. Never a problem as long as you've got the right tool. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
banana split Samba Member
Joined: January 22, 2002 Posts: 1126 Location: Beautiful British Columbia Canada
Posted: Wed Feb 22, 2006 1:16 pm Post subject: |
Maybe those nice dry and rust free California Beetle hinges are easier to take apart. The last 2 I had done had to be heated up until they were glowing red with a torch. Only then would they come out. |
Posted: Wed Feb 22, 2006 2:57 pm Post subject: |
So is there a special tool that can be used to remove the hinge fairly easy besides an air hammer which I do not have? and where and how much does it cost?
P.S. or is it easier to just get a new hinge with the correct pin already in it? _________________ 70Bug
04 Jetta |
Posted: Wed Feb 22, 2006 3:17 pm Post subject: |
Rattakus wrote: |
So is there a special tool that can be used to remove the hinge fairly easy besides an air hammer which I do not have? and where and how much does it cost? |
www.eastwood.com has a specialty tool made for this purpose (Part #31139) for only $24.99 But if your pin is seized inside the hinge, you'll need an impact hammer.
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
markm Samba Member
Posted: Wed Feb 22, 2006 3:18 pm Post subject: |
RareAir wrote: |
Rattakus wrote: |
Save your money, that tool will not work on a bug hinge. I think there is a thread on that hinge pin remover somewhere. |
markm Samba Member
markm Samba Member
Posted: Wed Feb 22, 2006 10:02 pm Post subject: |
I don't think so. They say in the add hollow hinge pins, and the vw hinge pins are definately not hollow. |
Posted: Wed Feb 22, 2006 10:15 pm Post subject: |
Thanks for all the help. I guess I will just have to have a shop do it. _________________ 70Bug
04 Jetta |
