Fuel injection muffler bracket. Do you still have it?
zoti
zoti is offline
PostPosted: Mon Jun 01, 2009 8:42 pm    Post subject: Fuel injection muffler bracket. Do you still have it? Reply with quote
The fuel injection heater boxes bolt on at the back to the pipes that come from the 2 cylinders on each side of the engine. The muffler hangs from the heater boxes and is supported by those 2 brackets that attach to the exhaust port of the rear cylinders.
Mine broke in half at one point and were welded back together but with the replacement Italian muffler I have it is hard to fit them.
Do you still have the brackets in your car? Did you remove them? Do you use another solution to support the heater boxes and muffler?
DrDarby
DrDarby is offline
PostPosted: Tue Jun 02, 2009 6:54 am    Post subject: Reply with quote
While in theory you need them as without them all the stress is on the flanges I have run my 78 & 79 for 15+ years without.
Midwest Autosavers, Inc. Crystal Lake, IL
raygreenwood
raygreenwood is offline
PostPosted: Tue Jun 02, 2009 2:55 pm    Post subject: Reply with quote
Depending on how ugly your roads are (lots of up and down bumps)...and how heavy your muffler is.....a nice heavy german OEM or a lighter aftermarket......you get a lot of loose exhaust studs sometimes. Ray.
Bruce
Bruce is offline
PostPosted: Tue Jun 02, 2009 11:59 pm    Post subject: Reply with quote
I custom made some from flat steel I just gave it a zig-zag bend.
zadieman
zadieman is offline
PostPosted: Tue Dec 04, 2012 3:43 pm    Post subject: Reply with quote
I am putting together my 79 FI exhaust, and I have the two brackets you are talking about. I just have them welded back together, but can only find where one of them goes. I searched for a diagram for the 79, but can't find it. ANYONE????
zadieman
zadieman is offline
PostPosted: Tue Dec 04, 2012 4:57 pm    Post subject: Reply with quote
Got it, goes from exhaust flange to heater box to support the weight of the heater box.
Yehan73
Yehan73 is offline
PostPosted: Tue Dec 04, 2012 9:57 pm    Post subject: Reply with quote
Can someone post a photo of this part. Can't picture it, and my car doesn't have one.
zadieman
zadieman is offline
PostPosted: Fri Dec 07, 2012 11:22 am    Post subject: Reply with quote
Actually there are two, there is one for each Heater Box. Mine are being fixed -welded- but they are brakets in a Z shape. They are for helping to suspend the weight of the FI exhaust. They are different in shape because of the different diameter of the bends of the cast iron elbows of the exhaust. They attach to the outside of the front exhaust flange. And then they go down to the heater box and hold up the weight of the exhaust system. Send me your email and i can send you pics soon. KYLE in Erie CO
zadieman
zadieman is offline
PostPosted: Tue Dec 18, 2012 11:00 pm    Post subject: Reply with quote
Now for the next question. My FI heater boxxes have a tab on them with a nut. It's on the side towards the engine, and I have no idea what attaches. Both boxxes has one. Anybody???
too_many_projects
too_many_projects is offline
PostPosted: Thu Apr 11, 2013 10:18 am    Post subject: Reply with quote
Ever get an answer?
Also photos would be nice
