andy 64 Samba Member
Joined: July 18, 2005 Posts: 160 Location: SOUTH LONDON ENGLAND
Posted: Sat Aug 01, 2009 3:41 am Post subject: Which truss bar/kaffer bar to buy |
Hi iam looking a getting a truss bar/kaffer bar can anyone recomend one appart from the csp one.as even here in the uk they are big money to buy
thanks for looking
Andy |
Bad bug Samba Member
gonebuggy Samba Member
Posted: Sat Aug 01, 2009 6:13 am Post subject: |
^ Agreed. Awesome piece.
Alex |
mharney Samba Member
Posted: Sat Aug 01, 2009 7:12 am Post subject: |
| I think that the ones Aircooled.net sells are very good. Mine was the weld in version he was selling previous, but the bolt in version he has now looks just as good. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5320 Location: Southern AB
Posted: Sat Aug 01, 2009 8:10 am Post subject: |
I bought mine from VDub Engineering too.
_________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
Scott13 Samba Member
Joined: February 17, 2004 Posts: 76 Location: Hartland, WI
Posted: Sat Aug 01, 2009 8:21 am Post subject: |
| I bought mine from eyeball-engineering.net. I haven't installed it yet, but it looks good just sitting on my shelf. |
tpnuckels Samba Member
Joined: February 16, 2007 Posts: 62 Location: Auburn, CA
Posted: Sat Aug 01, 2009 11:23 am Post subject: |
Wow thanks for the info.those bars don't seem to
be useing rose joints is that a bad thing or not
Cheers andy |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1873 Location: Grass Pants, Orygun
Hotrodvw Samba Member
Posted: Sat Aug 01, 2009 7:13 pm Post subject: |
I built my own......and saved a LOT of money doing it. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17643 Location: Left coast, Canada
Posted: Sat Aug 01, 2009 9:13 pm Post subject: |
That may be true, but from an engineering perspective, it is a poor design. The horizontal cross bar will flex down when power is applied because the down links are attached in the middle.
The others (CSP, VDub Engineering) are better designs, with the attachments at the end of the horizontal cross bar. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sat Aug 01, 2009 10:53 pm Post subject: |
Thanks for the info.was not sure about the cross bar being in 2
pices on the eyeball one.does anyone know what the diffrence are in the ends like on the fast fab one to the eyeball one still not sure
Thanks andy |
Posted: Sun Aug 02, 2009 9:14 am Post subject: |
Bruce,
You're probably right that there will be a bit more flex with the Eyeball design.
However, I have noticed a remarkable improvement over stock with a more rigid feel. There's no welding needed so installation is much easier.
I don't use my car for drag racing. I was looking to have a better tracking car on the twisties. The truss bar, along with a rear stabilizer and front beam braces have made a significant improvement. Oh, no wheel hop as well.
I felt, for the money and the usage, Eyeball Engineering delivered. |
W1K1 Samba Member
Posted: Sun Aug 02, 2009 9:34 am Post subject: |
| Quote: |
| does anyone know what the difference are in the ends like on the fast fab one to the eyeball one |
With vibration and time the rod ends on the fast fab one will become loose and sloppy. Basically they are a steel ball with a steel ring bent to capture the ball. Some use teflon/brass others use brass liners for the ball to ride on which can get hammered out in a short time. The end result is the same loose ring and a ball flopping around. _________________ 1973 super 2110cc
Posted: Sun Aug 02, 2009 9:50 am Post subject: |
| W1K1 wrote: |
| Quote: |
ring and a ball flopping around. |
cool thanks for that.looks like it's between the eyeball one or the Vw eng one as they don't seem to use the ball type ends
Thanks Andy |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Sun Aug 02, 2009 6:07 pm Post subject: |
I welded my roll cage into the horns. I don't think it's going anywhere  _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
Posted: Sun Aug 02, 2009 8:01 pm Post subject: |
This is the point where you start thinking about what is going on at the nose cone, and not what is happening at the frame horns, Tbird.  |
Posted: Sun Aug 02, 2009 9:03 pm Post subject: |
Then you get ya a mid-mount.  _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Speedy Samba Member
Joined: January 05, 2005 Posts: 166 Location: Cape Fort St. Port River Inlet Bay Coast Canal Beach, the median on Hurricane Highway, Florida.
Posted: Sun Aug 02, 2009 9:39 pm Post subject: |
Two locals installed the Bugpack kafer bar, both cars were street driven. One has a 1776 and occasionally does burnouts, the other had an awesome VW Paradise built 2276 with a geared trans to handle the motor. On both of these cars the Bugpack truss bar performed well. _________________ pimp
_________________________________
Wanted:
A.J. Pierson VW Tag Frame - Orlando FL.
Original Solid Ragtop or Convertible Beetle In Central Florida!
(O\ ! /O) |
Posted: Mon Aug 03, 2009 12:04 pm Post subject: |
| W1K1 wrote: |
where did you get that gearbox strap/cradle from looks like a nice pice
cheers andy |
