info needed on Porsche 2 liter wheels
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
JonF
JonF is offline
PostPosted: Sat Aug 18, 2007 1:07 am    Post subject: info needed on Porsche 2 liter wheels Reply with quote
i need some info on Porsche 2 liter wheels. i found a 914 that has 2 liter wheels that i can get for cheap
how to tell real 2 liters from copies?
what sizes did the wheels come in?
who made them for Porsche? Fuchs?
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Aug 18, 2007 3:56 am    Post subject: Re: info needed on Porsche 2 liter wheels Reply with quote
Real with have a Porsche part number 914 361 011 01 on the back
5.5x15J
Fuchs
Real are forged, repro are cast.
Get the lug bolts also.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JonF
JonF is offline
PostPosted: Sat Aug 18, 2007 3:54 pm    Post subject: Reply with quote
thanks glenn.
should i have any problems with them fitting my bug?
68 beetle long axle with type 3 rear brakes and ghia disc on the front
68 bug 1600sp 30/31
Mr. 010
Glenn is offline
PostPosted: Sat Aug 18, 2007 5:14 pm    Post subject: Reply with quote
The correct lug bolts might hit the brake shoe springs on the rear drums.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bugnut68
bugnut68 is offline
PostPosted: Sun Aug 19, 2007 10:25 am    Post subject: Reply with quote
I learned that one the hard way Wink The solution of course is to have the bolts ground down a smidge.
Another thing to consider is your front end, and the method you've used to lower it (assuming you've lowered it). Since I used CB dropped spindles, I had an issue with the inside of the rim hitting the bottom ball joint. If you have an adjustable front beam, you should be okay, but in my case, I can't run my set on my '70 Bug due to the clearance issue. I had numerous suggestions to grind on the ball joint, but that's not a solution that I'm too fond of utilizing.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
JonF
JonF is offline
PostPosted: Sun Aug 19, 2007 3:39 pm    Post subject: Reply with quote
whelps i went and looked at them today. they are real fuchs. i ended up not getting them. he only had 2 of them and both was beat up beyond fixing. the car was parked 20 years ago and shared the field with goats at sometime in its life. d'oh! the goats had the porsche dinner.
68 bug 1600sp 30/31
bugnut68
bugnut68 is offline
PostPosted: Mon Aug 20, 2007 12:40 pm    Post subject: Reply with quote
I've got a set I'm likely to be looking to sell pretty soon (rims and lug bolts) Feel free to drop me an email and I'll keep you posted.
John M.
John M. is offline
PostPosted: Wed Aug 22, 2007 7:38 pm    Post subject: Reply with quote
I have real 2 Liter Fuchs on my 74 Beetle. It's lowered 3 1/2" in front and does not rub at all with 195/65's. The rear is stock-ish height with 205/65's. I have the correct lug bolts and they do not interfere with the rear brake components.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Mike951
Mike951 is offline
PostPosted: Wed Sep 15, 2010 7:18 am    Post subject: 914 2L fuchs Reply with quote
How much are a set of these wheels worth?
Can someone post pic of one of these?
Thanks
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Sep 15, 2010 7:49 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=4834445#4834445 Rolling Eyes
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
70coupyel
70coupyel is offline
PostPosted: Thu Sep 16, 2010 4:19 pm    Post subject: 2 liter Bolt Length Reply with quote
Heres my thread on what I went through to get my 2 liters mounted up.
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
TheAndante wrote:
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc.
70 KG Coup
83 Westy Waterboxer
oly29
oly29 is offline
PostPosted: Thu Sep 16, 2010 6:25 pm    Post subject: Reply with quote
Bugnut68, I had the same problem using CB dropped spindles and running polished Pedrinni's on my car. Someone said to have the taper opened up on the lower part of the dropped spindle so the lower ball joint extends futher into the lower spindle. I had to use a larger washer under the nut but now I have over 0.125 clearance between the bottom of the ball joint and the inside of the wheel. Someone also said to get a tapered reamer and run that thru the lower spindle opening but trying to find a tapered reamer that size is not fun or cheep.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
