Dual Circuit Master Cylinder: Why NOT a 67?
doc hopper
doc hopper is offline
PostPosted: Wed Sep 12, 2007 3:06 pm    Post subject: Dual Circuit Master Cylinder: Why NOT a 67? Reply with quote
I've read the technical articles for the conversion of an early bus to a dual circuit master cylinder using the 71 MC, but the one question I never found an answer to is: why not just install a 1967 dual circuit MC in my 1964 bus? Is there a mounting problem? Something I'm not considering?(since I don't have one of each in front of me for comparison).
VWAdam
VWAdam is offline
PostPosted: Wed Sep 12, 2007 3:09 pm    Post subject: Reply with quote
It's not so much a mounting problem as it is that the '67 master cylinders are crazy expensive
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
Culito
11010101
Culito is offline
PostPosted: Wed Sep 12, 2007 6:44 pm    Post subject: Reply with quote
Yep -- one year only part. Also the pushrod is also '67 only, I think.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Andrew
Andrew is offline
PostPosted: Wed Sep 12, 2007 8:54 pm    Post subject: Reply with quote
Yep, it is. It's longer than the earlier ones.
-Andrew
ajitaw
ajitaw is offline
PostPosted: Thu Sep 13, 2007 3:35 am    Post subject: Reply with quote
The 71's are newer. Wink
o_0
doc hopper
PostPosted: Thu Sep 13, 2007 5:25 am    Post subject: 67 Master Cylinder Reply with quote
I found a source for the 67 master cylinders (Old Volks) at $240. They are "ATE Germany" although it is unknown if they were actually made in Germany. Is ATE a reliable manufacturer?
runderwood
runderwood is offline
PostPosted: Thu Sep 13, 2007 7:07 am    Post subject: Reply with quote
I'm also looking to do the dual circuit MC swap... has anyone located a source for those old volvo MC reserviors that fit so nice?
Andrew
Andrew is offline
PostPosted: Thu Sep 13, 2007 10:14 am    Post subject: Re: 67 Master Cylinder Reply with quote
Wolfsburg West carries them for $225
-Andrew
Culito
11010101
Culito is offline
PostPosted: Thu Sep 13, 2007 10:17 am    Post subject: Reply with quote
Any year Rabbit MC reservoirs work perfectly on the '71 and up MC. Your local junkyard or VW dealer probably has a few used ones. I got mine with a low brake fluid sensor in the cap.
'62 bug
johnnypan wrote:
cdennisg
cdennisg is offline
PostPosted: Thu Sep 13, 2007 9:15 pm    Post subject: Reply with quote
I thought that the rabbit reservoir sat at a funky angle on the bus MC and the fill hole did not line up with the access hole on the bus floor. The pics I have seen of the Volvo reservoir made it looked like it was meant to fit the bus.
BarryL Premium Member
BarryL is offline
PostPosted: Fri Sep 14, 2007 8:27 am    Post subject: Reply with quote
doc hopper
Yes they are the best and OE. They will last a looooooooooog time if you bleed them through every 2 or 3 years. They also come with 2 new brake light switches already installed.
runderwood
PostPosted: Fri Sep 14, 2007 8:29 am    Post subject: Reply with quote
I found new master cylinder reservior's made for the 71-79 MC (cheap $20)... but looks like it doesn't have a cap - maybe a tube attaches to the top for a remote fill elsewhere... has anyone used one of these?
OR - what about using a beetle MC reservior? would the little hose flanges that attach to the MC fit the bus MC? and use a beetle remote tank?
OR - can someone post a photo of their rabbit reservior mounted up and in place? I'm just wondering how much fluid it holds since the top will be at an angle...
Krustybus
Krustybus is offline
PostPosted: Fri Sep 14, 2007 12:51 pm    Post subject: Reply with quote
I don't know where you could mount a remote resevior high enough in a split bus to gravity feed the cylinder. I'm sure if it was easy a lot of people would have done it. I ran a Rabbit resevior for a while without problems. Was lucky enough to find a 67 later.
Tim
Culito
11010101
Culito is offline
PostPosted: Fri Sep 14, 2007 4:15 pm    Post subject: Reply with quote
The rabbit reservoir does sit a little funky, but it works fine and the filler cap does line up with the hole in the floor.
'62 bug
BarryL is offline
PostPosted: Fri Sep 14, 2007 6:50 pm    Post subject: Reply with quote
Wonder why no one's making the '67 reservoir. Sheesh. ATE should make it.
spiderjames
spiderjames is offline
PostPosted: Sat Sep 15, 2007 5:09 am    Post subject: Reply with quote
Don't some Volvo reservoirs mate up?
Krustybus
PostPosted: Sat Sep 15, 2007 7:41 am    Post subject: Reply with quote
Volvo 140 resevior's from the late 60's. I'd bet they're as hard or harder to find than 67 only bus.
From the gallery with a good link to more photos:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=378430
A good how-to from the Split Bus Forum FAQ:
http://type2.com/library/brakes/dualmas.htm
Tim
Peter - Belgium
Peter - Belgium is offline
PostPosted: Wed Sep 26, 2007 11:25 am    Post subject: dual circuit Reply with quote
I finally found a source from where I can get a new reservoir for the dual circuit conversion!
compared with a volvo reservoir
NICE!
356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Wed Sep 26, 2007 11:33 am    Post subject: Re: dual circuit Reply with quote
NICE!
[img]
http://blogsimages.skynet.be/images_v2/002/538/859....jpg[/img]
That's excellent. Where?
Peter - Belgium
PostPosted: Wed Sep 26, 2007 11:21 pm    Post subject: Reply with quote
I got it via a friend of mine.
I requested the Volvo reservoir (part# 678091) and this is what he came up with...
Page 1 of 7
