Mexican Engines
51577 is offline
PostPosted: Wed Oct 18, 2006 9:18 pm    Post subject: Mexican Engines Reply with quote
Are there any fundamental differences between my '73 Ghia engine and the engines used in the last of the beetles? I mean, I know about EFI, but what about the maintanence regemine? Do those engines still need things like the 6000 mile valve adjustments?
vwdmc16
vwdmc16 is offline
PostPosted: Wed Oct 18, 2006 9:40 pm    Post subject: Reply with quote
they have hyd. lifters so they go much father before needing valve work. i don't know how long though. they are the quietest running one made too, I believe they have paper air filters, so less oil to change. and they have a external oil filter, i put one on my ghia. otherwise they really probably only need the 3k oil and filter change i think. ive always been real curious about the EFI set up and the power it makes
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed Oct 18, 2006 9:56 pm    Post subject: Reply with quote
The oil filter is the only thing I see that's an improvement.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Teeroy Premium Member
Teeroy is offline
PostPosted: Wed Oct 18, 2006 10:18 pm    Post subject: Mexican Engines Reply with quote
They came with solid lifters too . TROY
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
HBRag
HBRag is offline
PostPosted: Wed Oct 18, 2006 11:49 pm    Post subject: Reply with quote
They also have a cast crankshaft, and different rods. Ok for stock, but I wouldn't use them for HP. At most a set of Kadrons, 1.25 rockers and a single quiet pack header.
They also have a fully electronic distributor.
HB
51577
51577 is offline
PostPosted: Thu Oct 19, 2006 10:26 am    Post subject: Reply with quote
I was thinking about trying to get one for a good reliable daily driver. I want to build it so that I don't have to spend half of my saturdays doing maintanence. What's the maintainance schedule for these engines?
Teeroy is offline
PostPosted: Thu Oct 19, 2006 10:55 am    Post subject: Mexican Engines Reply with quote
It only takes 15min to adjust your valves , you can have them done before you oil is done draining (make sure engine is cold) . TROY
PS , we put a new Mexican longblock (solid lifter) in my neighbors car last year , no problems so far .
ARR #3
HBRag
HBRag is offline
PostPosted: Thu Oct 19, 2006 11:30 am    Post subject: Reply with quote
Valves and oil every 3000 miles. If you get the silicone valve cover gaskets from aircooled, you will not have to change the gasket often. Adjust the carb twice a year, fuel lines once a year, air filter every 15,000 miles, plugs every 30,000...
Doesn't sound to bad to me.
Bruce
Bruce is offline
PostPosted: Thu Oct 19, 2006 12:44 pm    Post subject: Re: Mexican Engines Reply with quote
vwdevotee wrote:
.... Do those engines still need things like the 6000 mile valve adjustments?
Valve adjustments are not necessary, that's the point of hydraulic lifters. I've got 42,000 km on mine and the valve covers have never been off.
51577
51577 is offline
PostPosted: Thu Oct 19, 2006 1:31 pm    Post subject: Reply with quote
I don't recall having seen advertisements for them, but can I get hydraulic lifters for my original engine?
Vayabroder
Vayabroder is offline
PostPosted: Thu Oct 19, 2006 4:35 pm    Post subject: Motor Reply with quote
Some people badmouth those engines but if you figure how many Mexican Beetles have been built and how many are on the road vs. the failures you'll see that it's a good idea to use them for daily drivers. Of course the quality isn't the same as a German engine but they're good enough for daily drivers.
derv
derv is offline
PostPosted: Thu Oct 19, 2006 4:47 pm    Post subject: Re: Motor Reply with quote
I was just in Mexico this week and I was amazed at the amount of Mex Beetles I saw cruising happily down the road at x-way speeds in 95+ heat.
Jack
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth.
Yellowbeard
Yellowbeard is offline
PostPosted: Thu Oct 19, 2006 5:21 pm    Post subject: Reply with quote
Yep. Call Mofoco.
Lohe wrote:
Thanks. Thread went from me not being able to understand what Ipis was saying because English is obviously not his first language to me not being able to understand it because English is my first language Laughing
Fuel pumps galore:
http://www.thesamba.com/vw/classifieds/detail.php?id=845378
HBRag
HBRag is offline
PostPosted: Thu Oct 19, 2006 5:35 pm    Post subject: Reply with quote
The Mexican fuel injected engines had hydraulic lifters. This engines where made for the Mexican market. In all Mexico made/makes six different cases. The case for the hydraulic lifter has a different size lifter bore. Most of the long blocks available in the states are for a carburetor setup that uses manual lifters. I know that both FI and carbureted complete engines have been imported, as well and long block only for a US Type I replacement. I guess the question is which one did you get, or are you planning on getting.
HB
Vayabroder
PostPosted: Thu Oct 19, 2006 5:50 pm    Post subject: Re: Motor Reply with quote
That's what I'm talking about. Derv; I notice that you live in Oak Park. That's a beautiful area; I visited in 2005 and loved it. The hometown of my favorite architect of all time Frank Lloyd Wright.....
51577
51577 is offline
PostPosted: Thu Oct 19, 2006 8:01 pm    Post subject: Re: Motor Reply with quote
I think that it doesn't matter if the engines are up to the standard set by the German engines. I think that it only matters if the quality of the engine is suffucuent for the application.
Vayabroder
PostPosted: Thu Oct 19, 2006 9:10 pm    Post subject: Motor Reply with quote
And it is....
oibovveroi
oibovveroi is offline
PostPosted: Fri Oct 20, 2006 5:29 pm    Post subject: Reply with quote
i have a mexican engine....
so far its been fine..
though i dont have the hydro valves
