bchbumm Samba Member
Joined: December 16, 2002 Posts: 174 Location: Mohave Valley, AZ
Posted: Tue Dec 12, 2006 7:48 pm Post subject: New Mexican Longblock? |
Anyone have any comments on these? As I understand it they are fresh from the factory? Pros and Cons? 1600dp
I did a search and came up empty.
Thanks all. |
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
Posted: Tue Dec 12, 2006 8:22 pm Post subject: |
They work great for a stock replacement. I've put together a few with Kadrons, 1.25 rockers and a 1 3/8" header, and they have held up well.
If I where considering performance upgrades beyond the few items listed, I'd go another route.
HB |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2191 Location: Behind the wheel
Posted: Wed Dec 13, 2006 7:23 am Post subject: |
I've installed about a dozen of them in customers' cars. They run very smooth. No problems at all.Make sure you adjust the valves before firing it up. They are not adjusted from the factory. They also don't come with the distributor drive installed. I've got a new Mexi-longblock,still in the crate if anyone near Florida needs to pick one up. I won't ship it.
Paul _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Vayabroder Samba Member
Joined: April 04, 2006 Posts: 998 Location: Hollywood, FL
Posted: Wed Dec 13, 2006 1:33 pm Post subject: Mexi |
| I have one in my car which has been upgraded with a few things like ported CB 044 big valve heads, 94 mm cylinders and pistons, Gene Berg chromoly pushrods, valve adjusters and rigid rocker shafts, OEM VW 1.25 ratio rockers, Gene Berg sump, breather and Achiever pulley, SVDA dsitributor from Aircooled.net, dual 40 Dellortos, Tri-Mil dual tailpipe exhaust and 1-1/2" heater boxes with German doghouse fan and tin (including the Hoover bit) and thermostat/flap system retrofit. It performs well but from what I've heard the cranks are cast instead of forged like on German engines and I've also heard of a case in which the camshaft rivets failed (of course on the stock cam) at around 4,000 rpm's and took the whole engine with it. Of course for mild applications they'll work fine; there's been millions of those Mexican engines built with few failures on daily driver "Vochos" (as they call Bugs in Mexico). |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Thu Dec 14, 2006 9:11 am Post subject: |
Over 60 sold/installed in the last 7 years, only 2 failures. These were the cam gear breaking at the thrust bearing. Highest mileage one I have records on is over 80k in a 21 window bus with a 3.88 r/p trans. Duel Kadrons and 1.25 ratio rockers. Daily L A driver now in Santa Cruz.
Best bang for the buck, CIP1 has the lowest price (I cannot compete against their price) _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
