What's your MPG (miles per gallon) fuel gas mileage FAQ
Page: 1, 2, 3 ... 33, 34, 35  Next
shkdwnstrt
shkdwnstrt is offline
PostPosted: Sat Mar 31, 2007 10:12 pm    Post subject: What's your MPG (miles per gallon) fuel gas mileage FAQ Reply with quote
Please post your Engine info, whether it's a camper or not, and MPG. I'm trying to see what's ABOUT average for what setup. I know I am getting miserable mileage, and maybe with help from other people with the same setup, those of us with bad mileage can find a solution.
Westy
1700
Single Weber Carb
12 MPG city/ ? Highway
casey79westfalia
casey79westfalia is offline
PostPosted: Sat Mar 31, 2007 10:38 pm    Post subject: Reply with quote
I get between 23-25 in my 79 westfalia with camper special. I think with some more tweaking (possibly running a megasquirt setup, or CIS) I could probably get 25-27, I may be pushing it however we will see.
66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it"
View user's profile Send private message Send e-mail Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
stupidsongs2
stupidsongs2 is offline
PostPosted: Sat Mar 31, 2007 11:31 pm    Post subject: Reply with quote
11 MPG, 78 Westy, Fuel Injected
I think my poor gas mileage is due to a leaky gas cap. (fixed today)
---edit---
Fix the gas cap, still have crap mileage, about 15mpg.
I'm running cheapo passenger tires, electronic ignition, about 20% highway 80% city, i live right in the middle of the Texas hill country, so there is TONS of slowing down and speeding up.
When I'm cruising on the highway, there are several hills that i need to drop down to 3rd to get up, even if I'm pushing 70 at the bottom of the hill.
deronmoped
deronmoped is offline
PostPosted: Sat Mar 31, 2007 11:57 pm    Post subject: Reply with quote
There also should be a little more information on driving habits, tire size, tire pressure, how you arrived at your MPG figure...
Some people will drive at 55 MPH and quote a mileage figure while others will quote a figure they get while driving 70 MPH.
Tire pressure is important too, some will run the pressure for gas mileage and some will run the pressure for a smoother ride.
Is the figure for combined city and freeway, what percentage is city and freeway. Do you drive in rush hour traffic, hilly terrain, windy areas...
No guessing either, top the tank off, write the mileage down, drive the Bus how you normally drive, at the next fill up top it off to the same point, write the number of gallons down, write the mileage down, do this a few times and you should get a pretty good figure.
I have heard too many people saying they get such and such mileage without ever even knowing how to figure it out, they just take a guess.
In my Bus when I had a mild 1835 with dual Kadrons and 205 70/R15's @ 32 PSI, I would drive at 70-75 MPH on the freeway, no hot rodding around the streets, I would get a combined 16 MPG. My city/freeway driving was about 50% for each.
Have not had a chance to see what my 231 CI V6 will get Very Happy
Deron.
shkdwnstrt
PostPosted: Sun Apr 01, 2007 2:21 am    Post subject: Reply with quote
Good thinking.
I drive the bus pretty slow and easy. I AM riding on passenger tires. (I know. I know.) Haven't checked my tire pressure. (I guess I just kinda eyeball it.) I figured my MPG, by letting the needle get all the way to the empty line, then I put in $15 (Which was 5.5... gallons). Then I checked my odometer, and checked it again when it got back to the empty line. I am driving in town. A town with a decent population, so alot of traffic lights and stop signs. Really flat. Hardly a hill in site where I live. I still think even with these conditions I should get more than 12 MPG. Maybe I'm wrong though.
shkdwnstrt
PostPosted: Sun Apr 01, 2007 2:25 am    Post subject: Reply with quote
New format.
Automatic Westy
1700
Single Weber
Tire pressure: ?
Tire size: Passenger (can't remember the numbers)
Driving style: slow and steady
Traffic Congestion: Lots of traffic lights and stop signs.
Terrain: Flat
MPG: 12 city/ ? highway.
Hows that? Smile
Joey
Joey is offline
PostPosted: Sun Apr 01, 2007 4:02 am    Post subject: Reply with quote
In my 74 Bus with a 2L fuel infected.. i mean injected engine (& tranny) from a 79 Westy I get aprox. 18mpg in the city and aprox. 23 hwy. I drive it slow & easy in the city and on the hwy I keep it steady at 60mph ..well, except going down steep hills Laughing
In my 79 panel with a 2L FI, I get slightly lower (-2 or 3mpg) probably because I have snow tires (softer rubber) on and it only get driven in the cold snowy season.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Apr 01, 2007 4:32 am    Post subject: Reply with quote
shkdwnstrt wrote:
New format.
Automatic Westy
1700
Single Weber
Tire pressure: ?
Terrain: Flat
Hows that? Smile
Still no good. Fill up the tank to when the pump shuts off. Drive it a couple of hundred miles. Fill up tank to when the pump shuts off. Miles divided by gallons used = mpg.
This assumes that the drivers side front tire that runs the odometer is the correct diameter of about 25.65" and turns about 811 revs in a mile when using a 185R14 inflated correctly for your bus as per VW. Tires taller or shorter change how accurate the odometer is. ASSUMING it was accurate from the factory. YMMV.
But you are correct, even with a centermounted single carb you should be closer to 18 or so, but they are a "needy set up" at best and you really have to be a better tuner than me to get them right. Most of the ones I have seen tend to run really rich and the oil always smells like gas. I am not a carb guy though.
deronmoped
PostPosted: Sun Apr 01, 2007 6:32 am    Post subject: Reply with quote
Is not the odometer portion of a speedo direct drive? If the tire size is correct then it should be accurate.
Deron.
Mark
Mark is offline
PostPosted: Sun Apr 01, 2007 8:17 am    Post subject: Reply with quote
A big part of the calculation is making sure your odometer is working properly. My 76 transporter would 'skip' every few miles until I cracked it open & repaired it,. In the meantime, it gave a false indication of poor mileage.
Trying to push a vehicle with aerodynamic properties of a fridge at highway speeds has some limits.
www.zwerks.ca
Redd73
Redd73 is offline
PostPosted: Sun Apr 01, 2007 8:29 am    Post subject: Reply with quote
my odometer doesnt work but according to rough guess of miles vs rough guess of distance traveled from chicago the other day i got 19-21 mpg. it did a lot better the last part of the trip when i took a side road home and did 55 most of the way instead of 70.
"...theres nowhere to go but everywhere." - Kerouac
73 Westy 2000cc w/dual solex (engine code GE) + aftermarket AC
BusBerd
BusBerd is offline
PostPosted: Sun Apr 01, 2007 8:34 am    Post subject: Reply with quote
on a 3-day highway road trip:
at 65mph: 14mpg
at 55mph: 21mpg
I couldn't believe the difference. made me slow down and just enjoy the ride.
"The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission
Redd73
Redd73 is offline
PostPosted: Sun Apr 01, 2007 8:47 am    Post subject: Reply with quote
at 65mph: 14mpg
at 55mph: 21mpg
seriously man. and besides that, once i got off the highway there werent any trucks trying to blow me off it when they passed me. Wink im pretty sure future road trips will be spent 99% on back roads.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Apr 01, 2007 9:07 am    Post subject: Reply with quote
Manual Transmission
2.0 L, Fuel injected
Tire Pressure: 35 in the front, 45 in the rear
Tires: Properly sized, load range C, Yokohama 356's
Driving Style: Mixed city/highway
Traffic: Usually 'Rush Hour'
Terrain: Mild hills
MPG: 17
I have a record of the MPG of every tank since I bought the bus. Sometimes I get 20, sometimes I get 15, but the overall average over the years is 17.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Bay74
Bay74 is offline
PostPosted: Sun Apr 01, 2007 9:39 am    Post subject: Reply with quote
Year: 1974
Type: Automatic
Terrain: Small hills
Road Type: Town and some highway
Average mpg: 16
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Sun Apr 01, 2007 9:42 am    Post subject: Reply with quote
with points and timing adjusted properly i get around 20MPG in my 78 2.0L FI
geoffreybill
geoffreybill is offline
PostPosted: Sun Apr 01, 2007 12:07 pm    Post subject: What's your MPG (please post) Reply with quote
Last summer, travelling over 4300 miles to Italy and back, (doing the Mille Miglia route) we did 21 MPG on the way out. This was avoiding motorways, and included lots of slow stuff, steep stuff and bendy stuff, especially crossing the Alps. Coming home I used mostly motorways (autostrada/ autoroutes) and got 22 MPG. This is of course Imperial gallons not US.
The van is a 1977 Campmobile, 2 litres with twin Dellorto carbs. I don't dare check MPG for daily driving, I suspect it's a lot less!
slammedresto
slammedresto is offline
PostPosted: Sun Apr 01, 2007 3:59 pm    Post subject: Reply with quote
69 westy tintop
1641 with 34icts
running firestone fuel saver car tyres(dont go there)
mixed road types, ave 55-60 on motorway(highway)
getting approx 20-22mpg(uk gallons)
Wildthings
Wildthings is offline
PostPosted: Sun Apr 01, 2007 4:01 pm    Post subject: Reply with quote
Okay you guys suckered me in.
1977 7 passenger
1800cid engine with very high miles from my old 1974
4 speed
205/75R14 tires
Single Weber with no power valve, heated manifold
22-24 highway at speeds up to 65
Gas mileage drops noticably above 65mph, therefore don't go there often
Driving style: lots of hills and wind
busbasher
busbasher is offline
PostPosted: Sun Apr 01, 2007 5:26 pm    Post subject: Reply with quote
78 2.0l fi
electronic ignition
205/75/14 tires
recent trip thru ny state with five guys and gear
70mph hwy
averaged bettween 23.6 and 27.6mpg
Page 1 of 35
