tommiebsmith Samba Member
Posted: Wed May 18, 2011 9:32 am Post subject: Looking for specs on HOW to O-RING Oil pump? |
I am looking for specs on correct part # or size and make of the Oring
to purchase and the correct depth and width of the groove to cut in the pump..
what kind of groove works best V-U- square.. ?
groove location distance from back of pump also?
Thanks in advance!
I'm running into the common loose fitment of the oil pump into a case..
so I would like to know how to address this..
I have gone through everypump around me and it is the case opening that is out of spec or usuable spec.. by about .008
craigman Samba Member
Posted: Wed May 18, 2011 9:35 am Post subject: |
The best way to address it is, get another pump. The problem is well known.
And FYI, you can buy a O ring oil pump from Wolfgang. They do the procedure their inhouse.
But if you want to do it yourself, you'll have to measure the case, the oil pump, and then chuck it up in a lathe.
Good luck! |
Posted: Wed May 18, 2011 9:47 am Post subject: |
Yes... I will be doing this myself..
I have found all the places that sale them..
but I would like specific information on the Oring and groove..
It seems that the general what to do has been covered but I have not found
any specifics on doing it say "properly"
all the companies that that sale them must have a program used
that locates the groove and cuts to specific depth and width.. and they use a specific or even general Oring.. so this information should be obatinable..
and if case and Pump play a factor in the end result then selling them or even buying them in bulk is a waste of time?? IMHO.. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4219 Location: San Diego
Posted: Wed May 18, 2011 10:16 am Post subject: |
| Its not likely companies that provide this service, will give you the info for free. You could buy one and reverse engineer it, but you may not need more than 1 |
Posted: Wed May 18, 2011 1:55 pm Post subject: |
Of course those companies don't share..
but are you telling me not one of these awesome samba guru's know
this information and are not up for sharing?
If that is the case it makes me sad that the world acts like this.. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1781 Location: Niagara Region, CANADA
Posted: Wed May 18, 2011 2:02 pm Post subject: |
| Any competent machinist should be able to figure this out. |
Posted: Wed May 18, 2011 2:08 pm Post subject: |
Yes.... and I can figure it out also..
I have a Lathe and plenty of brain power to figure it out..
but I ask to save some time and possibly money.
It can't be that everyone is only general knowledge smart
round here..
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Wed May 18, 2011 2:09 pm Post subject: |
| hmm measure your case,& o ring & then put it where it needs to be.I have seen some cases that the oil galley is so close to the edge there might not be much room for error. also the hardness (durrometer)of the o ring might be an issue. I would use an silocone or soft o ring if possiable. but installing may only be done with case split. I had thought about a lip seal from an auto trans drum.but never did it.good luck |
Posted: Wed May 18, 2011 2:19 pm Post subject: |
I tend to think half the distance of the oil hole and out side edge of the oil pump / or half the distance of oil outlet and inside of the case..
or a combo of both to insure the Oring sets properly in that little available area.. infact if the pump sticks out behind the case then the half distance
on the case of oil outlet and the inside of case seems to be the better location to align the groove in the oil pump..
and then depth of cut may be based on how thick the O ring is .. so you'd be looking to have X exposed.. this would be the sealing of your oil pump OD and case opening ID difference..
then the choice of O ring is made based on heat and oil resistance..
then thoughts of how deep the groove is to keep it from being sucked in on the inlet set.. so a large OD Oring and deeper groove would be a good choice.
also chamfer the oil pump hole on the case a bit... and both the oil in and outlets on the case.. because when istalling even heavily lubed up you wouldn't want them to tear the Oring on insertion??
or would installing the pump with the case halves apart be suggested?
and then making sure you get a good sealant on the lip side so as to not
have a leak at the pump...
Maybe someone else can aid in the thought process..
Thanks! |
Posted: Wed May 18, 2011 2:37 pm Post subject: |
You may be correct ....
Still looking for eduction via Samba from this board..
so the quest continues..  |
Posted: Wed May 18, 2011 4:08 pm Post subject: |
| tommiebsmith wrote: |
round here..
Then just do it..  |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3452 Location: Calgary, Canada
Posted: Wed May 18, 2011 6:01 pm Post subject: Re: HOW to O-RING Oil pump |
to purchase |
I went to my local industrial O-ring supplier and found a replacement...my original Berg O-ring had ripped. However, I had the original to use as a sample. I'll try to find the PN for you. IIRC, I was able to get a Viton replacement. Let me look in the garage and I'll post back here later. _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
AlteWagen Troll
Posted: Wed May 18, 2011 7:29 pm Post subject: |
| It can't be that everyone is only general knowledge smart round here.. |
Its funny you say than then mark responds
Your quest shall continue for a LONG time.
You have to ask REALLY specific questions around here, then filter out all the old drunk fuc#er responses, go spend some money responses and why do it yourself if someone else can do it for you responses and MAYBE you will get a bit of an answer that helps you figure it out your self.
You may want to re title your thread to something like:
Need measurement for O ring pump
or something along those lines. Your current title sounds like you already know how to do it and are posting a how to thread.
I need to find the measurements myself otherwise I would give them to you.
Here is the pic I was going to use, hope it helps
Posted: Wed May 18, 2011 8:18 pm Post subject: |
| hmm by the gap between the oil pump and the case the "o" ring will not be sealing any thing but your thoughts as it will be too far in to seal agnist the case.or you are using more smoke & mirrors. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Wed May 18, 2011 8:45 pm Post subject: |
| That's called a shadow. |
2manybugs Samba Member
Joined: October 25, 2003 Posts: 129 Location: Vancouver, WA
Posted: Wed May 18, 2011 10:24 pm Post subject: |
| As far as the groove size and depth for the ring you choose , you can get a "O" ring catalog at a bearing or hydraulic shop and all of the groove specs will be in there for you. Follow their specs and you will probably not go wrong. You might even find the catalog info online. |
Posted: Wed May 18, 2011 10:31 pm Post subject: |
| Also the case has to be split to install a O ring oil pump or you will tear the O ring "pushing" it in. |
Posted: Thu May 19, 2011 5:55 am Post subject: |
[/quote]
This 30mm pump looks to be deep and extends past the case inside..
looks easy enough with this pump.. not sure I want to do a 30mm pump.
My whole question started off based on the idea of location..
My 26mm pump has a body depth of .970 and in the case the openings
for the inlet and outlets are .846 to the edge of the hole and 1.00
to the edge of the case opening into the cam chamber.
so if you try to center the line basically where the O ring would work best your want the groove at about .920/.921 back from the mounting lip
of the oil pump to center on the case which get's it extremely close to the lip of the oil pump and chucking it up in the lathe not to easy..
then goes the thickness of the Oring.. as a portion of it will be inlet/outlet
holes...depending on how thick it is.
This all before gaskets or sealants play any factor with the end o RING final location result. |
Posted: Thu May 19, 2011 8:06 am Post subject: |
| Just use a 4 jaw chuck and hold on the square end. Indicate the oil pump in and you can put the ring groove anywhere you want. |
