Engine Painting
Lester
Lester is offline
PostPosted: Wed Jun 13, 2007 8:30 pm    Post subject: Engine Painting Reply with quote
Help! I pulled my first engine & I have it all apart so I would like to dress it up! Should I paint the engine case & the heads? Ive heard pros & cons. If I should would you recommend matching the engine to my car color. If you recomend not to paint is there anything out there that will make the aluminum shine. What type of paint should I use? Primer? PS 1978 Vert.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed Jun 13, 2007 9:51 pm    Post subject: Reply with quote
I wouldn't paint the heads or the case. In fact, don't even polish the case! Its rough surface lets it cool better than a smooth surface would.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Bashr52
Bashr52 is offline
PostPosted: Thu Jun 14, 2007 7:13 am    Post subject: Reply with quote
A THIN coat of hi-temp flat black paint (such as BBQ grill paint) on the cylinder barrels and heads will help the eninge to dissapate heat better. I saw an article somewhere where painting these parts lowered temps by like 20 degrees.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jun 14, 2007 7:38 am    Post subject: Reply with quote
Cylinders are OK, but not the head or case.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
