-Alex77- Samba Member
Joined: December 09, 2008 Posts: 514 Location: Finland
Posted: Mon Jan 21, 2013 3:41 am Post subject: Porsche oilsquirters, type 4 journals and bearings |
I am going to have Porsche oilsquirters on a type 1 TF-1 case engine. Crank is scat flanged all t4 mains.
From watching the pictures, it looks like i need type 4 bearings that have OD groove, ok?
_________________ Lasercut parts and CAD design |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1213 Location: Melbourne Australia
Posted: Mon Jan 21, 2013 5:33 am Post subject: |
Yes, and a little 'carving' on the bearing to line up the oil supply. I used a dremmel with a small burr.
i can't remember if it I got it from the instructions with the pic you have, but I used a tapered drill so I could tap the squirter in firmly |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Mon Jan 21, 2013 8:16 am Post subject: |
If your oil channel is located at the bearing ID, merely drill four small holes outward lining up with each squirter. A tapered 1/4" drill is the way to do it .. but use a small end mill first to start the hole straight. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Mon Jan 21, 2013 2:39 pm Post subject: |
Bearing options are then:
-Silverline T4 bearings and alignboring to T4 size
-BMW style T1/T4 bearings and modifying them for oilsquirters
-Scat bearings? Do they have bearing kits with T1 OD and T4 ID for flanged cranks? _________________ Lasercut parts and CAD design |
flyboat Samba Member
Posted: Mon Jan 21, 2013 5:23 pm Post subject: |
Trying to learn something here. I see the hole for the dowel pin and another hole for what I think is the oil to the main bearing. Where is the oil squirter. It looks like the oil supply has been tapped for an orifice of some sort. Or is that the squirter squirting out the backside of the web to the piston. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Mon Jan 21, 2013 5:26 pm Post subject: |
| flyboat wrote: |
| Trying to learn something here. I see the hole for the dowel pin and another hole for what I think is the oil to the main bearing. Where is the oil squirter. It looks like the oil supply has been tapped for an orifice of some sort. Or is that the squirter squirting out the backside of the web to the piston. |
the first pic shows the squirter in the hand next to the hole it will be placed in _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Jan 21, 2013 5:27 pm Post subject: |
Yes _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1173 Location: Las Vegas, Nevada
Posted: Mon Jan 21, 2013 6:26 pm Post subject: |
| flyboat wrote: |
You are looking at the right side of the case only in these pics. The left side is the oil supply side, but its not shown in these pics, Notice its only showing the center main pin. The left side has 3 of them and an oil supply hole on every main. Hope that helps.  _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
esde Samba Member
Joined: October 20, 2007 Posts: 6392 Location: central rust belt
Posted: Mon Jan 21, 2013 7:32 pm Post subject: |
| flyboat wrote: |
Yes, the nozzle is a Porsche 911 nozzle, and squirts from the back of the bearing web. They have a small check valve, so they only operate at pressures above idle. A very nice design, but they are now over $30 each, used to be under $10 from what I've read. It's that damned P-word that makes the $ go $$$. |
Posted: Mon Jan 21, 2013 7:40 pm Post subject: |
I better understand now. Thanks _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Tue Jan 22, 2013 4:53 am Post subject: |
Yeah the price is a shame  _________________
| Alstrup wrote: |
| I like 5,5inchers in the rear at least. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2377 Location: Mount Airy, Maryland
Posted: Tue Jan 22, 2013 3:54 pm Post subject: |
Alex you could have just PM'ed me since you found my pics. Brothers does the Mod for about $225. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Tue Jan 29, 2013 11:42 am Post subject: |
Sorry about that, John I found a T1/T4 adapterbearing pic from my old post at cal-look.no, looks like this might fit with squirters.
gears Samba Member
Posted: Tue Jan 29, 2013 1:48 pm Post subject: |
I can't imagine why so much material would be removed from those bearings. Only a small connecting hole is required. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Tue Jan 29, 2013 2:00 pm Post subject: |
Is that particular BMW shell the right dimension both out, and inside? Or is lineboring/grinding necessary? _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
58Dub Samba Member
Posted: Tue Jan 29, 2013 2:02 pm Post subject: |
| Boolean wrote: |
| Is that particular BMW shell the right dimension both out, and inside? Or is lineboring/grinding necessary? |
that looks like the adapter that JayCee sells. I believe it fits a standard bore type 1 case and standard type 4 journal _________________ 58 Beetle (now just a pile of parts in the corner)
Posted: Tue Jan 29, 2013 3:12 pm Post subject: |
Those adapter bearings have such big holes from the package.
vwsb74 Samba Member
Posted: Tue May 21, 2013 10:51 pm Post subject: |
go to aj sims his oil squirter will work at low rpm and above. the Porsche style will only work at 45psi. the draw back is your oil will be hot like mine 240* ps. I have dtm shroud and type4 oil cooler. _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Wed May 22, 2013 6:29 am Post subject: |
| vwsb74 wrote: |
go to aj sims his oil squirter will work at low rpm and above. the Porsche style will only work at 45psi. the draw back is your oil will be hot like mine 240* ps. I have dtm shroud and type4 oil cooler. |
Your oil being hot likely has something to do with AJ Sims being in your case - Note - He's been banned for a reason. Enough said. _________________ -John Cox
Posted: Tue Jun 04, 2013 4:04 am Post subject: |
Roger Crawford said that the Porsche pistons had a pocket under the piston that the oil went into and the idea worked but with standard pistons it causes oil problems.
But i havent seen on most porsche pistons any pockets, stock or aftermarket. _________________ Lasercut parts and CAD design |
