Pros and Cons of Different Crankshaft Pulleys
Page: 1, 2, 3, 4, 5  Next
Boonies
Boonies is offline
PostPosted: Sun May 21, 2006 11:23 am    Post subject: Pros and Cons of Different Crankshaft Pulleys Reply with quote
alright ive looked around the forums and have seen some opinions on different pulleys. So now im wondering what are the actual pros and cons of different pulleys. We are talking stock size here no power or oversized pulleys.
1.Aluminum pulley
Ya know emip, scat, ect with the degree rings on them
2.Berg Achiever
3.Berg Equalizer
4.Fisher Damper
or other damper pulleys
5.Stock vw pulley
6.Any other v belt pulley
7.Serpentine belt systems
Ive read what different sites have to say about them. Some of this may be true, all of it may be true, but im looking for people with first hand knowledge and experience with these. Also think it would be good to have a discussion that covers all of these for future use.
thanks
Alan_U
Alan_U is offline
PostPosted: Sun May 21, 2006 11:37 am    Post subject: Reply with quote
FISHER pulleys have been known to reduce harmonics and save conrod bearings amongst other things. Friend of mine found a harmonic damper pulley extend his conrod bearing life ALOT compared to using a "normal" aluminum one.
Some aftermarket aluminum pulleys are shorter so you need to put a spacer to shim out the pulley. CB's santana clone and the scat ones are known to require a spacer and some people get annoyed since theres no mention of a spacer requirement.
Heavy pulleys have no harmonic reduction effects. I wont ever use a heavy pulley. There are people noticing thier balanced rotating parts (crank, flywheel etc) to get out of balance significantly using a heavy pulley.
No idea how the serps work but would be neat for the track when you pull them off quickly.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
Boonies
Boonies is offline
PostPosted: Mon May 22, 2006 11:17 am    Post subject: Reply with quote
no one else has an thing to say... thats a first.
Vayabroder
Vayabroder is offline
PostPosted: Mon May 22, 2006 3:38 pm    Post subject: Pulleys Reply with quote
I've read in different places that for street use it's better to stick with a steel pulley such as a stock one or a Berg Achiever. The Berg Equalizer is meant more for race cars and cars that will see lots of rpm's. As the other posts said, it has to deal with harmonics on the crankshaft and its effect on the engine case.
Boonies
Boonies is offline
PostPosted: Tue May 23, 2006 9:05 pm    Post subject: Reply with quote
Is there any advantage to running a aluminum pulley over a stock one on a daliy driver. What would be the disadvantage?
Alan_U
Alan_U is offline
PostPosted: Tue May 23, 2006 9:15 pm    Post subject: Reply with quote
After talking to Bob at DMS I'd stick with an aluminum pulley if your not gonna dynamically balance the crank and flywheel all together.
He's seen heavy pulleys thow off the balance on units that are "balanced"
If I wanted a plulley that would help eliminate harmonics I'd buy a fisher. Putting a heavy pulley at the end of the crank does squat especially if its not balanced with the rotating mass.
Aluminum pulleys have timing ring/marks throughout the pulley usually. I guess thats a cosmetic but useful tool. If you like the look of a stock pulley stick with it.
mighty-manx
mighty-manx is offline
PostPosted: Tue May 23, 2006 10:38 pm    Post subject: Reply with quote
We interupt this thread for an important hijacking...
I've looked and can't find a fisher listed anywere anybody got a link???
This hijacking is now over we return you to your origional thread programing Wink
TWD
TWD is offline
PostPosted: Wed May 24, 2006 5:38 am    Post subject: Reply with quote
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=ESM0037&cartid=0524200693430323
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Wed May 24, 2006 7:52 am    Post subject: Reply with quote
For years I loved my Berg pulley... until the plating started to flake and it started to rust like crazy. I was diappointed as I thought I would buy one once and that would be it!
Looking for aluminum single port Kadron manifolds.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 24, 2006 7:56 am    Post subject: Reply with quote
Mine's 20 years old and still looks new. Maybe 300k on it since new.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
TinCanFab
TinCanFab is offline
PostPosted: Wed May 24, 2006 8:02 am    Post subject: Reply with quote
I was under the impression that the heavy pulleys were designed to put weight back onto the crank after removing in from the flywheel side? My friend had one sent out to be balanced with his other parts, I agree it was out of balance-it runs smooth though
glandnut
40 horses of Fury
glandnut is offline
Yeah, I expected mine to do the same Glenn. It started flaking near the hub and just kept going...
Mr. 010
Glenn is offline
PostPosted: Wed May 24, 2006 8:06 am    Post subject: Reply with quote
Weird... I thought they were natural and I just use some Nevr Dull to clean it up.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Steve Arndt
Steve Arndt is offline
PostPosted: Wed May 24, 2006 10:40 am    Post subject: Reply with quote
I like my Fisher. Sorry it is a little rusty. It is installed in a baja (no engine cover).
Steve
[email protected]
john@aircooled.net is offline
PostPosted: Wed May 24, 2006 10:48 am    Post subject: Reply with quote
we are also just finishing the Fisher dampers in a Serpentine version (so it is compatible with our Fan-Clutch System).
John
Aircooled.Net Inc.
Boonies
Boonies is offline
PostPosted: Wed May 24, 2006 3:29 pm    Post subject: Reply with quote
So a damper would have little use on a stock car, correct. What would be the advantage of the aluminum ones with the degree ring? Would being lighter be a negative thing?
Blaubus
Blaubus is offline
PostPosted: Wed May 24, 2006 8:29 pm    Post subject: Reply with quote
what you may have heard about aluminum pulleys is that they dont stay tight on the steel crank when heated. you dont have to ask car nuts whether or not this is true. aluminum expands more than steel when heated. NOT someones opinion, its natural law- which is something you count on, like the fact that the sun will rise and set tomorrow. an understanding of science is the onlything that cuts thru the BS of opinion. whats the upshot here? get the berg pulley. even the base model berg pulley will help to dampen crank harmonics, which helps even a stock engine- even stock engines have crank harmonics... and as a plus the belt groove wont wear excessively as compared to the aluminum types.
Boonies
Boonies is offline
PostPosted: Fri May 26, 2006 12:21 pm    Post subject: Reply with quote
how hot does aluminum have to get to start to expand? Seems like it would have to be rather hot...
Vayabroder
PostPosted: Fri May 26, 2006 12:30 pm    Post subject: Aluminum Reply with quote
Actually the expansion rate of aluminum is rather large; that means that upon heating it will expand more than any other metal subjected to the same temperature change.
Boonies
Boonies is offline
PostPosted: Fri May 26, 2006 1:19 pm    Post subject: Reply with quote
And this is a common thing to happen on an aircooled vw?
Page 1 of 5
