bug66 Samba Member
Joined: February 25, 2010 Posts: 110 Location: OSLO, NORWAY
Posted: Thu Feb 25, 2010 10:46 am Post subject: Headlight relay problem! Wrking on it for 1 week :( |
I'm uprgrading my 67 beetle from 6 to 12volts. (european car)
but I'm stuck with a headlight relay thats don't work. The original is a 6 pin relay, and I've got 4 old relays to test out. part number is 411941583B, same as DNI 0127.
I've conected as follows:
30 - current from fusebox
S - tiny brown/white from flasherstick at the wheel
56a- highbeam
56b- lowbeam
56 - from lightswitch at dash
tried all 4 relays, but the flasher will not work. I'm either stuck on low oe high beam...
the last old connection is a tiny red which is together with 30...
could somebody please help out ???
bug66
Norway |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36319 Location: Conejo Valley, CA
Posted: Thu Feb 25, 2010 11:36 am Post subject: |
May be the wrong relay.
Keep in mind Euro relays are either different, or wired differently than USA cars. Euros had terminal 30 always hot so you could flash the high beams with the headlights off, as when passing (or in place of a horn if an idiot cuts in front of you!). USA models didn't connect 30 to a hot lead, they jumpered it to 56. This let the relay switch from high to low beam as it should, but you could NOT flash the high beams when the headlights are switched off.
Replacing the 30-56 jumper and instead wiring 30 to "always hot" terminal restores this function. I did this on my '71 USA Type 3 to get a flasher function. Use a wire thick enough to take headlight main current. Also, it is typically not fused, so wire it up carefully to avoid shorts.
Check out this link:
http://www.oldvolkshome.com/headrelay.pdf |
bug66 Samba Member
Posted: Thu Feb 25, 2010 11:52 am Post subject: |
perfect link. i'll try to loop i wire from 30 to 56
perfect link btw been looking for something like that |
KTPhil  Samba Member
Posted: Thu Feb 25, 2010 12:00 pm Post subject: |
Also, check that the wires from your turn signal button are connected correctly. The solid brown must be grounded.
For testing the relay, you can bypass this and just ground terminal S at the relay. That's all the button does-- it temporarily grounds the brown/white wire as long as you hold down the button. |
bug66 Samba Member
Posted: Thu Feb 25, 2010 12:05 pm Post subject: |
i'll be testing tomorrow  |
