front blinker placement on this 61 bug
cvallone
cvallone is offline
PostPosted: Mon Nov 10, 2008 7:40 am    Post subject: front blinker placement on this 61 bug Reply with quote
Hey guys,
I have a used set of fenders on the front of my 61 rag that I am just about to get restoed. I just noticed yesterday that the holes on the tops of the front fenders are off from each other. The pass side has the holes closer to the front of the car while the drivers side is back more.
Where there changes throughout the years with this??
Please let me know,
Chris
My restos www.classicvwbugs.com
Restoring Beetles back to their historical beauty.
bill may
bill may is offline
PostPosted: Mon Nov 10, 2008 7:52 am    Post subject: Reply with quote
the early fenders (58-63) have the round holes closer to the fender welting than 64-67.. what is location of horn grilles? can you only fit 2 finger width between welting and horn grille? pictures would help.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
cvallone
cvallone is offline
PostPosted: Mon Nov 10, 2008 8:00 am    Post subject: Reply with quote
I will try to get some for ya,
Chris
DrDarby
DrDarby is offline
PostPosted: Mon Nov 10, 2008 10:22 am    Post subject: Reply with quote
58 - early '64 turn signals are farther forward by almost a turn signal legnth. When the lights got bigger in around Sept of '63 for the '64 model year the got pushed back. I just bought a '62 that has a '65 L/F fender. The car is all done but this bothered me and with a little measuring I re-drilled the holes needed and moved the signal uo to where it belongs. The gasket hides the '65 holes and I sealed the holes to the gasket with RTV sealant. To be exact I'm actually still 10mm too far to the rear but had to to cover the holes.
If I ever do any body work to this car I'll weld up the '65 holes.
The original '62 right front fender measured 4-1/2" from the headlight edge to the edge of the turn signal gasket.
Midwest Autosavers, Inc. Crystal Lake, IL
glutamodo Premium Member
The Android
glutamodo is online now
PostPosted: Mon Nov 10, 2008 11:12 am    Post subject: Reply with quote
Also, FYI - this is from a VW tech bulletin where it shows where the hole for the 58-63 type turn signal should be on the fender:
DrDarby
DrDarby is offline
PostPosted: Mon Nov 10, 2008 11:25 am    Post subject: Reply with quote
Perfect ! I had to do mine by sight as I neeeded to hide the other holes.
cvallone
cvallone is offline
PostPosted: Mon Nov 10, 2008 6:07 pm    Post subject: Reply with quote
Yep I figured it out, the passenger fender is a 64 fender and the drivers is pre64. So there we go, just told the body guy to fix it by filling the holes and putting new ones in where they belong.
cv
