wolfswest Samba Member
Joined: July 05, 2005 Posts: 44 Location: stekene, Belgium
Posted: Wed Nov 03, 2010 4:35 am Post subject: again, offset for wheels... |
Hi Guys,
I was wondering if I could mount following wheels on my early notchback. I'm european, so I will talk in cm's and mm's, if the USA guys want it in inches, please let me know.
BBT sells wide 5 steel sprintstar wheels: 5.5 ET 25 and 4.5 ET 15
The stock type3 wheel is 4.5 with an ET of 46. in the back I have a clearance of a few cm's so If I'm correct with the ET 25 the wheel will be 2cm's further then stock?
What about the extra inch? (5.5 instead of 4.5) where does the extra inch go? just in the backside of the wheel or in the front? or half/half? I hope you guys know what I mean... I'm affraid it goes half/half, so that's another extra 1.27cm further, so that's a total of 33mm and I'm affraid that's a no go if you want to mount 185 tires...
thx,
Dem |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1900 Location: Feeling, Minnesota
Posted: Wed Nov 03, 2010 4:58 am Post subject: Re: again, offset for wheels... |
| wolfswest wrote: |
Hi Guys,
thx,
Dem |
The offset is measured from the centerline of the wheel regardless of width,
so the 5.5" ET25 will be 33.7mm further out than a stock 4.5" ET46 wheel and the 4.5" ET15 will be 31mm further out. _________________ 1968 Regatta Blue Squareback
1967 Granada Red Squareback
1971 Rattle-Can Red Westfalia Camper |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18052 Location: Eugene, OR
Posted: Wed Nov 03, 2010 5:03 am Post subject: |
I am not really up on sprintstar wheels or ET's etc, but I might advise just buying 4 of the 4.5 wheels to be safe on a notchback. Everybody wants to lower their cars eventually it seems and you might be asking for trouble with the 5.5 wheels. I've found ET 34 & ET 41 steel wheels on squarebacks I've bought. You have to wire wheel off the paint on the knobs between the lug bolts to be sure which ET wheels you actually have on your notch. The d dimension on this VW chart below is the ET (offset).
http://classicvw.org/gallery2/d/9347-1/wheel+offset.jpg _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Nov 03, 2010 5:38 am Post subject: |
Yeah, but if Bsquare his calculations' are correct and I think he's correct, the difference between 4.5 and 5.5 is just 2 mm ??
why oh why is it so hard to find a decent wheel for or beloved rides???  |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4053 Location: Deep In My Own Psyche
Posted: Wed Nov 03, 2010 9:34 am Post subject: |
http://www.rimsntires.com/specs.jsp
| Quote: |
Wheels:....Wheel 1 ........Wheel 2
Wheel size 15x4.5 ET 46..........15x4.5 ET 15
BackSpace 115 mm (4.5'') .........84 mm (3.3'')
Rim Lip ......31 mm (1.2'') wider
Package will stick out 31 mm (1.2'') farther.
| Quote: |
Wheels:......Wheel 1 ........Wheel 2
Wheel size 15x4.5 ET 46.........15x5.5 ET 25
BackSpace 115 mm (4.5'') .......107 mm (4.2'')
Rim Lip ......34 mm (1.3'') wider
Package will stick out 21 mm (0.8'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. |
i always do major calculations with wheels and tires
try this link out
it will answer all your question
and the difference between the two
is .4" to the inside _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
| Me of Course wrote: |
| Extremity is relative to how far your willing to jump |
| Ward Cleaver wrote: |
| You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Wed Nov 03, 2010 10:12 am Post subject: |
| sharkskinman wrote: |
| Quote: |
| Quote: |
try this link out
is .4" to the inside |
I'm not sure about this, I can not believe that the extra inch doesn't do anything with the rim lip... I think the the 5,5 ET 25 will stick out 33 a 34 mm instead of 21mm... |
Posted: Wed Nov 03, 2010 10:46 am Post subject: |
you can be not sure about whatever
but if you look at the link and put in the measurements
you will see that i am correct
i dont say this lightly
i have been a Wheel Whore since i can remember
check and take a look
stock to 4.5" ET15
stock to 5.5" ET25
4.5" ET15 -- 5.5" ET25
PS4 "NKOGNEATO"
Last edited by sharkskinman on Wed Nov 03, 2010 11:07 am; edited 1 time in total |
Posted: Wed Nov 03, 2010 11:06 am Post subject: |
what do they mean with rim lip? the front of the rim?
because in your calculation the rim lip (for the 5,5 vs the 4,5) is 34 mm.
So my thought would be it sticks out 34 mm.
don't get me wrong, I'm just trying to figure out how the program works, I really appreciate your help and the link you've posted!!  |
Posted: Wed Nov 03, 2010 11:14 am Post subject: |
and i didnt even think about this
WE are talking about offset of the new wheels compared to stock
YOU are looking at WIDE 5!
are the T3 Stock Wide 5 offset ET46??
and altho the overall width is 1"(25mm) wider
the offset being Higher on the wider wheel
it makes it a little difficult to get it visually untill you see it
Please take a look at the link i posted!  _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Wed Nov 03, 2010 12:31 pm Post subject: |
i could be wrong but aren't 5x205 t3 ET41.5? not that 4.5mm makes a big difference...ken... _________________ ITMC
Secret Service |
Posted: Wed Nov 03, 2010 12:58 pm Post subject: |
| luckystiff wrote: |
| i could be wrong but aren't 5x205 t3 ET41.5? not that 4.5mm makes a big difference...ken... |
yeah, but a half cm can make or brake the concept! who can confirm this?  |
Posted: Wed Nov 03, 2010 1:10 pm Post subject: |
A lot of good information/pictures in this Tire/Wheel/Suspension thread below, but in the end it's your car to Set-Up!
http://www.thesamba.com/vw/forum/viewtopic.php?t=247735 _________________ 69 FI/AT square Daily Driver
Posted: Wed Nov 03, 2010 2:01 pm Post subject: |
the diff between ET41.5 and ET 46 is WAY Different when doing wheels and tires
if i was 4.5mm off my wheel/tires wouldnt fit
i could stand to loose 4.5mm on the outside on the Driver Front
then it would Never rub _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
Posted: Wed Nov 03, 2010 2:50 pm Post subject: |
4.5mm = .177" so less than a quarter inch. if your breaking down to those fractions you can also get anal and figure running a narrower treadwidth tire can save you just as much. say going from a tire with a 165mm tread width to a tire with a 145mm tread width you cut 20mm. but you have to split that difference and you really only gain 10mm of clearance per side or .39" of clearance. it's not the wheel that actually rubs it's the tire so if you can shave a little room back on the tire as well then you are gaining some of you lost room back so to speak. so if the early wide5 type3 are indeed et41.5 and you use a 145/65/15 you are only talking about half or so of the increase listed above. so about 5/8" outward from stock. i have never taken a measurement but with the 5.5" flat4 fuchs with 145/65/15 on the front of my square lowered 3 notches i can stick my fist sideways between the fender and tire with no problem. so even if those wheels stick out an inch more than this combo you should still have a decent turning radius...ken.... _________________ ITMC
Secret Service |
Posted: Fri Nov 05, 2010 10:42 am Post subject: |
| luckystiff wrote: |
| 4.5mm = .177" so less than a quarter inch. if your breaking down to those fractions you can also get anal and figure running a narrower treadwidth tire can save you just as much. say going from a tire with a 165mm tread width to a tire with a 145mm tread width you cut 20mm. but you have to split that difference and you really only gain 10mm of clearance per side or .39" of clearance. it's not the wheel that actually rubs it's the tire so if you can shave a little room back on the tire as well then you are gaining some of you lost room back so to speak. so if the early wide5 type3 are indeed et41.5 and you use a 145/65/15 you are only talking about half or so of the increase listed above. so about 5/8" outward from stock. i have never taken a measurement but with the 5.5" flat4 fuchs with 145/65/15 on the front of my square lowered 3 notches i can stick my fist sideways between the fender and tire with no problem. so even if those wheels stick out an inch more than this combo you should still have a decent turning radius...ken.... |
that's right Ken, flat 4 4,5 and 5,5 fuchs have the same offset then type3 wheels! Yeah, you can save a lot with other tires, but I want the fattest tires as possible in the back!  |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Fri Nov 05, 2010 11:16 am Post subject: |
Here AGAIN is how VW and the Germans calculate the ET offset.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
grethi Samba Member
Posted: Sun Nov 07, 2010 11:28 pm Post subject: |
| wolfswest wrote: |
Is that the 5 spokes, 4 spokes, or both? _________________ My mind not only wanders, sometimes it leaves completely.
'69 square |
Posted: Mon Nov 08, 2010 4:21 am Post subject: |
| both, the baby fuchs and fuchs have both outstanding ET values for a type 3... don't know the numbers but I know people who run them with 205/70/15 tires on them, stock long axles, no problems... |
