engine tin
darg
darg is offline
PostPosted: Sun Apr 26, 2015 5:00 pm    Post subject: engine tin Reply with quote
I have bought a 70 type 1 engine B6 recently . 73 engine messed up. The engine has a cooling tin, I think that is what they call it , that goes between the jugs and the pushrods. It goes from front to back of the engine. My question is , there is no cool tin . Do I need these also. If I do where exactly do they go? It seems like there is no space to put them The tin I am referring to is 3-1/2 X 4" If I need then along with the cooling tin, does someone have a picture of installation ? It would a pain in the neck to install them.
I thank you for replys
darg Question
Dwayne1m
Dwayne1m is offline
PostPosted: Sun Apr 26, 2015 5:24 pm    Post subject: Reply with quote
If you are talking about the tin pieces that I think you are talking about, yes you need them. They just snap in place on the cylinder/head studs. Bad part is you have to remove the pushrod tubes to get them in. I learned that the hard way.
http://vwparts.aircooled.net/Lower-Cylinder-Air-Deflector-Plate-Upright-Engine-p/311-119-317a.htm
darg
darg is offline
PostPosted: Sun Apr 26, 2015 5:31 pm    Post subject: tin Reply with quote
Thanks for the reply. Do you have a picture of exactly where they should go? Seams to be very little space from the jugs to the head .
darg
Dwayne1m
Dwayne1m is offline
PostPosted: Sun Apr 26, 2015 5:58 pm    Post subject: Reply with quote
I don't have a pic but they just snap in between the cylinders. They go right up against the cylinders. They will go on only one way. Just make sure they are snapped in on both ends. Their job is to direct the air flow around the bottom of the cylinders. Without them the air flow would go inbetween the cylinders and the bottoms of the cylinders would not have any air blown over them. The "taller" end goes towards the heads, while the shorter end goes towards the case. These tins do not make any contact with the head. They are strictly for the cylinder. They but up against the case for the most part so they don't reach the head.
Here is a video to help.
https://www.youtube.com/watch?v=n6BhdHHN64s&list=PL6CC452A5EDECEEF6
sb001
sb001 is offline
PostPosted: Sun Apr 26, 2015 7:36 pm    Post subject: Reply with quote
Hi darg,
I don't have a picture of the actual tins in place, but they are #5 in this diagram, and snap on the underneath side between the 2 jugs on each side
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
darg
darg is offline
PostPosted: Mon Apr 27, 2015 3:58 am    Post subject: tin Reply with quote
Thanks guys for the help and replays . I have a one piece of tin that is under the jugs now. It is called the cyl. cooling tin. according to the adds selling this tin. It has a turned up tab about 2" that goes upward on both ends of the jugs. It has appp. a 2" hole that lets air go between the jug fins for each jug. A solid piece that is between the two jugs. This tin is between the push rod tubs and jugs. It is against the case on one side and the other side goes to the outer side of the jugs that are bolted to the head Hope this all makes sense. This piece of tin looks like a factory installed piece. Hope this piece takes the place of the small clip on tin. With the tin already installed there is no open space between the pair of jugs. The one that I am referring to look some what like the ones being sold on E Bay. except the ones being sold look like a two piece tin . called cool tin or cooling tin.
thanks
darg Question
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Apr 27, 2015 5:37 am    Post subject: Reply with quote
Are these the ones ? If so they are type 3 tin and if you have the small ones under the cylinders, you don't need these.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
volkswagen_bug
volkswagen_bug is offline
PostPosted: Mon Apr 27, 2015 5:42 am    Post subject: Reply with quote
sb001 wrote:
Hi darg,
That picture is going in my folder. Thanks for the upload, sb001.
1958 Volkswagen Bug w/ 1200 Single Port
darg
darg is offline
PostPosted: Mon Apr 27, 2015 2:07 pm    Post subject: tin Reply with quote
Thanks for the reply,s
Rick, the ones shown are the ones, as far as I can tell there are no small tin installed. Being these are type 3 cooling tins, should they be fine?
thanks again
darg Question
60ragtop
60ragtop is offline
PostPosted: Mon Apr 27, 2015 2:21 pm    Post subject: Reply with quote
some use them in the place of the small ones that go under the cylinders, they are marketed as cool tin. you should be OK
Rick
darg
darg is offline
PostPosted: Mon Apr 27, 2015 3:17 pm    Post subject: tin Reply with quote
Thanks Rick , that is good news. I will run the type 3 tin. Razz Razz I have the engine just about ready to install.
darg
jrmicrobits
jrmicrobits is offline
PostPosted: Thu Mar 17, 2016 6:46 pm    Post subject: Re: engine tin Reply with quote
Sb001 do you have the legend that goes with that diagram of all the tinwork? Thanks
andrewvwclassic
andrewvwclassic is offline
PostPosted: Thu Mar 17, 2016 7:10 pm    Post subject: Re: engine tin Reply with quote
1970 was a stransitional year. your head studs are 10mm the super cool tins will need to be modified to fit your engine. I would not use them anyway get a stock replacement they fit better and should work fine.
Lingwendil
Lingwendil is offline
PostPosted: Thu Mar 17, 2016 9:34 pm    Post subject: Re: engine tin Reply with quote
Tins 9, 5(x2), 6, 10 are the proper tins to install under your cylinders with the engine assembled. I wouldn't run the type three "cool" tins unless it was all I had and I need to drive the thing to work tomorrow. My ex had a set on her bug and there was a huge difference (35°!) in the oil temp going to the correct tin.
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
andrewvwclassic
PostPosted: Thu Mar 17, 2016 9:42 pm    Post subject: Re: engine tin Reply with quote
I am not suprised the type 3 runs hotter but is a less complicated version of a bug engine.
