thrown_hammer Samba Member
Joined: September 07, 2004 Posts: 790 Location: Indiana
Posted: Thu Dec 29, 2005 3:23 pm Post subject: Tuning a single 40MM Kadron? |
I need some info on how to tune the Empi Single Kadron 40MM carb. Everything I have found is for the dual setup. Seems to be just mixture and idle. What is a good starting point for the mixture? The carb came set at 1-1/2 turns out.
For some reason the further in I adjust the mixture screw the better it gets. To the point that is all the way in. Even all the way in the car doesn't run great. It backfires and shoots fireballs out the stinger. (car is a Baja)
I talked to someone that has this carb setup and he just bolted his on and it ran great. I think I may have issues other than the carb. Anyone out there running this carb? _________________ 1974 Superbeetle Bright Orange
Keeper of the Titanium Monkey |
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Thu Dec 29, 2005 4:24 pm Post subject: |
I wouldn't be surprised if you had a faulty carb, it's made by EMPI..
I don't have any advice for tuning it as Single Kads are relatively new. It's always hit and miss with EMPI products.
For future reference EMPI is chinese for CRAP.
Good luck. |
david greiner Samba Member
Posted: Thu Dec 29, 2005 4:53 pm Post subject: |
Kadrons often have a problem with flooding over, that would account for you having to lean out the mixture screw. Check the needle and seat and the float level first. Dave
Proformancemotoring.com |
Frankenbeetle Samba Member
Joined: August 08, 2003 Posts: 825 Location: The Great NW, Home of PBR and roses
Posted: Thu Dec 29, 2005 5:51 pm Post subject: |
The tuning guide AJ put up would still apply to a single setup. The fuel pressure being to high, no vac advance, or the fuel squirt adjustment being out were my big problems when I first got into tuning my kads. _________________ Samba Whipping Boy of '07
Tram wrote: |
That explains it. Jihad supplies ain't cheap!
A.J.Sims Banned
Joined: December 11, 2003 Posts: 1016 Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
Posted: Thu Dec 29, 2005 5:56 pm Post subject: |
Check your fuel pressure.
They like lower than 2lbs. |
Posted: Thu Dec 29, 2005 7:08 pm Post subject: |
I have a stock fuel pump so whatever the stock pump puts out is what I have. Is that too much?
I have a 009 dizzy so no vac advance. I called Serranos where I bought the carb and they feel the solar flares are being caused by the accelerator pump coming in late.
Thank you for your advice and good luck wishes... I will look into the fuel pressure, fuel accumulator setting, and the float level. _________________ 1974 Superbeetle Bright Orange
A.J.Sims Banned
Posted: Thu Dec 29, 2005 7:23 pm Post subject: |
Stock pumps can put out up to 7lbs. Kads like 2lbs or less.
what is the timming set at? Total not at idle.
Visit the site for more info. This is wy we do all the work to these cabs B-4 you have to! |
vdubvr6 Samba Member
Joined: September 27, 2004 Posts: 180 Location: Abilene, TX.
Posted: Fri Dec 30, 2005 7:07 am Post subject: |
listen to A.J.! he knows what he's talking about and does awsome work too. i just got my Kads back last week and installed them and they work flawlessly! thanks A.J. _________________ i have nothing! nothing! nothing! for you! |
Posted: Fri Dec 30, 2005 7:44 am Post subject: |
A.J. I believe it is set at 29 degrees total advance and I think it is around 10 or 11 degrees at idle. I set it awhile ago but followed advice from guys on the Samba for setting timing with the 009. I am going to your site right now to poke around.
So I need a feulpressure regulator? Where can I get one that cranks down to 2lbs?
BTW I checked the accelerator pump and it is set right. _________________ 1974 Superbeetle Bright Orange
Posted: Fri Dec 30, 2005 7:52 am Post subject: |
30 to 32 degrees with a 009 is recommended. You might have to play with it though. Hop down to your local auto parts store and pick up a holley pressure regulator. Should be about 25, add on a good pressure gauge, oil filled if you can get it. That's my current setup and it's awesome. _________________ Samba Whipping Boy of '07
Tram wrote: |
Posted: Fri Dec 30, 2005 9:07 am Post subject: |
I picked up a Mr.Gasket pressure regulator but didn't get a gauge. I also got a set of NGK plugs. Shortly I am gonna put the regulator on, set it at 1.5 lbs, and change the plugs. I will have to borrow my friends timing light. I have the kind that has the spring and because of my plug wires I need the kind that clips on the plug wire. Should I just bump it up little by little with the timing or wait for the light? _________________ 1974 Superbeetle Bright Orange
Posted: Fri Dec 30, 2005 9:23 am Post subject: |
Take it back!!!!!!
I was using one of those damned things for a month or so and they do NOT regulate the way they claim. The Holley regulator should be the same price, hell, at the Schucks down the street from me the Holley was 10 bucks cheaper than the Mr Gasket piece of crap.
If you get the Holley regulator(1-4 pounds) just screw it all the way out and then back in 5 or 6 full turns, that's roughly 2 pounds to 2.5 pounds. _________________ Samba Whipping Boy of '07
Tram wrote: |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Fri Dec 30, 2005 10:03 am Post subject: |
...or if you're a cheap $#%@ like myself use a vacuum/pressure gauge to determine your fuel pump pressure and shorten your pump pushrod until you're 1.5 to 2 psi. No extra gauge required permanently in the fuel system, (ie. one less point of failure.)
My stock pump was putting out 4.5 lbs before I shortened the pushrod by about 4mm. Just my $0.02 plus tax. |
Posted: Fri Dec 30, 2005 12:06 pm Post subject: |
Too late I already installed it. Figures, this Baja has been a jinx ever since I drove it home. Anyhoo...I checked the compression every cylinder is over 100. i put in the NGK plugs and installed a pressure regulator. If all this doesn't do it what is my next step? _________________ 1974 Superbeetle Bright Orange
Posted: Fri Dec 30, 2005 2:51 pm Post subject: |
Haven't had a chance to drive it yet but the solar flares have calmed down a little. I can still crank the mixture screw all the way in and it runs. If I try to turn it out like lowbugget.com suggests(to get the highest idle) it starts to stumble and want to die. The fuel pressure regulator is set at 1.5 lbs. I haven't messed with the timing yet. _________________ 1974 Superbeetle Bright Orange
A.J.Sims Banned
Posted: Fri Dec 30, 2005 4:15 pm Post subject: |
your fuel pres reg is not working. If the motor will run with the mix screw in than you are geting fuel from over flow.
Set from 30-34* try 34* if it pings drop it 1* and so on. |
rbourne3 Samba Member
Posted: Fri Dec 30, 2005 5:18 pm Post subject: |
Mark wrote: |
1 or 2 extra gaskets will knock it down a pound or two and it's easier to undo than shortening the rod. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Fri Dec 30, 2005 5:49 pm Post subject: |
Those dial gauages are junk and just add a restriction to your fuel line. A Holley low pressure regulator is much better, but if using a stock pump get a gauge and shim the pump until you get 2psi (As stated above ). _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
Mark Samba Member
Posted: Fri Dec 30, 2005 6:08 pm Post subject: |
rbourne3 wrote: |
Mark wrote: |
You would need a buttload of gaskets to amount to over 4mm length taken off the pushrod to get the 1.5 to 2 lbs pressure! In fact, I added no less than three gaskets & the difference was a mere 0.2 psi, (I'm anal, I log everything I do with the car in case I screw up I have a paper trail.)  |
Posted: Mon Jan 02, 2006 8:18 am Post subject: |
I am going to put in a vacuum advance dizzy as soon as my friend remembers to bring in the timing light but I may try to advance the 009 first and see if that helps.
For now I am stuck with the regulator I have. I am looking locally for a pressure gauge that will work with ¼” fuel line.
I have put a few miles on the Baja the last couple days. No more solar flares, idles fine. The only issues are the mixture screw anomally and it wants to fall on it’s face right when I take off from a dead stop. If I rev it up it goes just fine. If I try to take off normal it either just dies or goes into wild convulsions and bucks like crazy. If I push the clutch in and give it some gas to get past “the dead zone” it runs fine.
Thanks for all the replies. I am sure with everyone's help I can get this thing dialed in. _________________ 1974 Superbeetle Bright Orange
