mort_mort Samba Member
Joined: April 11, 2023 Posts: 13 Location: Watford, England, UK
Posted: Tue Jun 13, 2023 2:32 am Post subject: Karmann Ghia 1973 RHD - List of fixings (nuts 'n' Bolts etc) |
Hi All,
My first post and I apologise of this has been posted before!
Is there a definitive list of the majority of fixings needed for a 1973 RHD, KG? I am after the size, length (if needed) and pitch if possible.
As a lot of owners carrying out a resto have probably found, it is time consuming and expensive to order just when needed.
Many thanks for your help!
regards
mort_mort |
bomberbob Samba Member
Posted: Tue Jun 13, 2023 6:18 pm Post subject: Re: Karmann Ghia 1973 RHD - List of fixings (nuts 'n' Bolts etc) |
Are you referring to hardware? Nuts, bolts, screws, washers? I tried to save as many original pieces of mounting hardware as I could. If I had to replace severely rusted or broken bolts, I usually try to get stainless steel. I don't have a shopping list of what you would need if you are planning on replacing everything. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Wed Jun 14, 2023 3:24 am Post subject: Re: Karmann Ghia 1973 RHD - List of fixings (nuts 'n' Bolts etc) |
Yes, hardware - all of which you have mentioned. I would love to keep original hardware; the trouble is that previous restorers (!) have mutilated, changed etc past hardware (ie 2 different lengths of bolts for the bumper fixing) - so I don't know which is correct and replacing/ordering 'on the go' is a very time delaying way of doing it, not to mention expensive. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Jun 14, 2023 2:15 pm Post subject: Re: Karmann Ghia 1973 RHD - List of fixings (nuts 'n' Bolts etc) |
These books probably have everything you are looking for.
I would start with Bentley & Henry Elfrink manuals?
https://www.thesamba.com/vw/archives/books/ghia.php _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
