Wire wheel before epoxy?
Yannvanh
Yannvanh is offline
PostPosted: Mon Nov 27, 2023 5:53 am    Post subject: Wire wheel before epoxy? Reply with quote
Hello,
Currently restoring a 66 vw bus:
https://www.thesamba.com/vw/forum/viewtopic.php?t=777735
I am sanding all of my doors before epoxy primer and i wire wheeled all the rust off, do i still need te sand it with 80 grit before epoxy or is it good as is?
Thanks!
'66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help!
67ctbug
67ctbug is offline
PostPosted: Mon Nov 27, 2023 5:17 pm    Post subject: Re: Wire wheel before epoxy? Reply with quote
I would run over the easier to get areas with a DA just to even the scratch out, it will probably stick fine.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
viiking
viiking is offline
PostPosted: Tue Nov 28, 2023 3:43 pm    Post subject: Re: Wire wheel before epoxy? Reply with quote
I've always roughed up any surface that has been wire wheeled. I just feel that wire wheeling polishes the surface a bit too much.
Evil_Fiz
Evil_Fiz is offline
PostPosted: Thu Feb 29, 2024 2:03 pm    Post subject: Re: Wire wheel before epoxy? Reply with quote
This, and most epoxy brands recommend 80# on a DA.
Hit the metal with 80# using a DA sander or by hand, blow it off with compressed air, clean it thoroughly with wax & grease remover until the cloth comes up clean, then hit it with 2-3 wet coats of epoxy. The first coat of epoxy should be lighter to prevent cratering and provide a good bond to the metal. And don't use any acid treatment if you plan to use epoxy.
I did an adhesion test and found that epoxy stuck well to smooth metal. You can read about it here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=789397&sid=84958a4c935cbe6cdd1c647db93ca48b
Regardless, I would not do that in the real world.
Emil
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
