How do you install a 64-67 front door check?
sandtrooper747
sandtrooper747 is offline
PostPosted: Thu Mar 02, 2017 4:08 pm    Post subject: How do you install a 64-67 front door check? Reply with quote
I have the door check with the metal rod and rollers. How do I get the rod in between the rollers though?
[email protected]
velvetgreen@hotmail.com is offline
PostPosted: Thu Mar 02, 2017 5:14 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
stick a large flat screwdriver in there, turn it sideways, and shove the rod in kinda underneath it , pull out screwdriver, shove it in the rest of the way.
Clara Premium Member
Clara is offline
PostPosted: Fri Mar 03, 2017 9:44 am    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
Lube all the moving parts. Lube where the rollers roll on the door check. This prop puts stress on the lower hinge, which often gets cracked.
Properly lubing it helps keep it easier to closer the door without stressing the hinge. Grease is good.
sandtrooper747
PostPosted: Mon Mar 06, 2017 5:07 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
It worked! Thanks! Very Happy
70bus Premium Member
70bus is offline
PostPosted: Thu Mar 21, 2024 2:25 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
sandtrooper747 was lucky; my rollers simply pop apart when the screwdriver trick is used. The rollers sit in a cage with the two halves joined by a tab-and-finger arrangement; if I spread the rollers far enough to get the check bar in, the tabs pop out of the fingers (and the whole mess has to come out and be reassembled again). Curious what others might have done to get around the issue.
Craig K
70 Neunsitzer
65 Pritschenwagen
"If Von Dutch was alive, he'd walk in there with a pistol and shoot these people."
-Robert Williams
70bus is offline
PostPosted: Fri Mar 22, 2024 9:50 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
After much fun, one went on only if the top fingers came apart, and the other might have gone on with roller assembly intact ( garage is too narrow to open door enough to tell).
So, next stupid question: which way does the door check bend; does it follow the curve of the door skin I.e. curve towards inside, or against door skin and point away from cab?
The oacdp scan is too lo-res to tell, but in my original manual it appears to curve towards the skin from the door. Just double checking (pardon the pun).
Because of course I probably put them on backwards…
Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams
Clara is offline
PostPosted: Mon Mar 25, 2024 8:20 am    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=4831694&highlight=#4831694
Lube it up. In a 67 I used to have, the door was cracked by the lower hinge. The door was stuck when I got the bus.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9055237&highlight=#9055237
BarryL Premium Member
BarryL is offline
PostPosted: Mon Mar 25, 2024 6:17 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
Away towards the outside world.
70bus is offline
PostPosted: Mon Mar 25, 2024 7:38 pm    Post subject: Re: How do you install a 64-67 front door check? Reply with quote
There was at least one post mentioning following the curve of door, and the photos were inconclusive. Parts manual was definitive of course
The scans on thesamba are helpful, but it was worth the investment for the high-res originals in this manual for stuff like this.
Opened enough to show curve direction, and why it needs to go that way. Garage too narrow to show it better :P
Craig K
70 Neunsitzer
65 Pritschenwagen
-Robert Williams
