Where do I get a new stock Spindle??
Phshead
Phshead is offline
PostPosted: Sun Mar 24, 2024 11:43 am    Post subject: Where do I get a new stock Spindle?? Reply with quote
I have a 1969 single cab that the PO installed drop spindles on the front with willwood disc brakes and Fuchs wheels. I like everything but the drop. I just can’t seem to fine stock spindles anywhere. The options for drop spindles seem to be endless. Does anyone have recommendations for spindles with stock height that will work with the disc brakes and wheels?
69 Single Cab
dodger tom
Location: Central Coast, CA, but we're all still Ukrainian
dodger tom is offline
PostPosted: Sun Mar 24, 2024 12:07 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
i’d probably go for og, meaning contacting the various used-parts suppliers.
Phshead
Phshead is offline
PostPosted: Sun Mar 24, 2024 12:38 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
I just don’t get the fact that every supplier, jbugs, mid america, etc. has endless options for new drop spindles but no option for replacement stock spindles that accept disc brakes.
69 Single Cab
dodger tom
PostPosted: Sun Mar 24, 2024 12:43 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
oh, right. i forgot about the disc brake conversion.
Wildthings
Wildthings is offline
PostPosted: Sun Mar 24, 2024 1:19 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
Manufacturers produce what they can sell in sufficiently large quantities, what you are asking for is likely seldom asked for.
Phshead
Phshead is offline
PostPosted: Sun Mar 24, 2024 2:36 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
I’ll even take a stock spindle with drums.
69 Single Cab
Wildthings
PostPosted: Sun Mar 24, 2024 2:45 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
This hobby is often dependent on wrecking yards.
94touring
94touring is offline
PostPosted: Tue Mar 26, 2024 2:50 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
I snagged some NOS Brazilian spindles which use king pins still, are disc, though are a 5x112 lug pattern.
Phshead
Phshead is offline
PostPosted: Tue Mar 26, 2024 3:26 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
Where did you get those? Would that lug pattern fit the Fuchs?
69 Single Cab
94touring
PostPosted: Tue Mar 26, 2024 3:41 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
I got them from a guy off ebay in Egypt for $260 shipped. Have my old set as a spare now "just in case" I just looked at his parts, but he's out of any type 2 spindles. I saw a guy on the FB Brazilian page listing his service to buy and ship parts from Brazil if you're interested in his contact info. I've bought some items from Brazil and they do have a ton of used stock spindles. It's just going to be a 5x112 lug pattern that uses all late bay bearings, calipers, ect... although I want to say an early split window bearing grease seal. You can still buy the same spindles in the euro market brand new, but they're expensive last I looked. Not sure about your fuches. Aren't 69 buses a 205 pattern? There may be adapter plates from 112 to 205, but I've never looked onto it.
aeromech
aeromech is offline
PostPosted: Tue Mar 26, 2024 9:43 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
I may have a pair. If you want in can check tomorrow
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Alex6373
Alex6373 is offline
PostPosted: Thu Mar 28, 2024 5:58 pm    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
Egypt is full of type four busses , they are used for taxies , Cairo is full of them .
Phshead
Phshead is offline
PostPosted: Sun Mar 31, 2024 5:07 am    Post subject: Re: Where do I get a new stock Spindle?? Reply with quote
Fixed! I went the no-cost route and just lowered the rear. Leveled it out perfectly. Thanks to everyone for the suggestions.
69 Single Cab
