Joined: March 19, 2020 Posts: 26 Location: BLYTHEVILLE, AR
Posted: Tue Apr 23, 2024 7:02 am Post subject: superb beetle rear drum brakes |
Hi, my name is Odale,
I have a '73 Super Beetle (that has a checkered past)
I need someone to give me some more help (ideas) as to how I might fix my rear brake-drum problem.
I have done a new brake job on the 'Super'; i.e., new shoes, new springs, spreader-bar is on the e-brake correctly, adjusters are lubed with anti-seize. I was advised by a member that I had to get the adjusters to align up with the shoe bottom. "Thanks"! Still, I can't get the drum to go on. It appears that the shoes are still expanding too much. Ps., I have also installed new hold-down-springs.
HELP!!!
SOMEBODY who has had this problem please respond ASAP.
My email is <[email protected]> |
Joined: August 31, 2013 Posts: 12878 Location: North Carolina
Posted: Tue Apr 23, 2024 7:16 am Post subject: Re: superb beetle rear drum brakes |
Check to see if you have the adjusters in correctly, they have an arced wedge shape in the slot. If they are upside down, they will cause the shoes to ride too far out & also bind while braking.
This thinner side should be facing upwards.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1396 Location: Wichita, KS
Posted: Tue Apr 23, 2024 7:18 am Post subject: Re: superb beetle rear drum brakes |
Please post pictures of your new brake setup. If possible, include some closeups of where the brake shoes contact the adjusters (at bottom), the cylinder (at top), etc. With those, we might be able to spot something amiss, or otherwise help you with suggestions. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Tue Apr 23, 2024 7:26 am Post subject: Re: superb beetle rear drum brakes |
Thanks for the tip. I will try it immediately to see if the drum will go on.
Thank you so much for responding so soon.
Odale.
I will also report my progress back to you |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31419 Location: Hot Arizona
