FAT KUDA Samba Member
Joined: July 31, 2005 Posts: 45 Location: Northern Cali/ Bay Area
Posted: Wed Sep 14, 2005 11:41 am Post subject: 5 speed tranny? |
Hey folks, woould it b a good/bad 2 drop a 5 speed tranny in, if good what kind or what capatible? Just looking 4 the pro/cons of it. _________________ 1969 Squareback
1967 bug |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76963 Location: Sneaking up behind you
Posted: Wed Sep 14, 2005 12:02 pm Post subject: |
Your options are aPorsche 901 5 speed or a Berg 5 speed.
This has been discussed many time recently, so do a search and you'll find plenty of info.
I have a Berg 5 in my 74 Beetle and love it. _________________ Glenn
Member #1009
#BlueSquare |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Wed Sep 14, 2005 2:03 pm Post subject: Re: 5 speed tranny? |
FAT KUDA wrote: |
Hey folks, woould it b a good/bad 2 drop a 5 speed tranny in, if good what kind or what capatible? Just looking 4 the pro/cons of it. |
Waste of time and money. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Sep 14, 2005 2:04 pm Post subject: Re: 5 speed tranny? |
krusher wrote: |
FAT KUDA wrote: |
yes, but why is what he wants to know... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Glenn Mr. 010
Posted: Wed Sep 14, 2005 3:14 pm Post subject: Re: 5 speed tranny? |
krusher wrote: |
FAT KUDA wrote: |
Please explain... i'd like to know also. _________________ Glenn
Member #1009
#BlueSquare |
attatt Samba Member
Posted: Wed Sep 14, 2005 3:44 pm Post subject: |
I've never pulled a VW apart and looked at the gears. Probably would be better of rebuilding the tranny versus putting in a 5 spd unless you have upgraded to a monster motor and really need an extra gear to make your car driveable |
Glenn Mr. 010
Posted: Wed Sep 14, 2005 4:23 pm Post subject: |
No monster motor needed.
I wanted a true close ratio 4 speed, but with one, you can't cruise on the interstate.
With my 5 speed i've got 3.80/2.06/1.58/1.21/0.82 and a 3.875 r/p. I can rip up the street and cruise all day at 75mph.
But they are not cheap... a custom turnkey Berg 5 is $3000 plus options. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 14, 2005 6:32 pm Post subject: |
see like glenn that is how id like to cruz. but i would like 2 know "Y" waste of time and money. i intend to drive, i dont believe in building a car to sit in the garage, thats like buying a plasma tv and dont use it so it wont break, just want to enjoy my toy. _________________ 1969 Squareback
1967 bug |
Posted: Thu Sep 15, 2005 12:23 am Post subject: Re: 5 speed tranny? |
blankmange wrote: |
krusher wrote: |
FAT KUDA wrote: |
yes, but why is what he wants to know... |
Ok I was Tired when I gave my short answer so I wil elaborate.
It more depends on what you want out of your car Kuda. It would help if youpost what you think your gonna get froma 5 speed and then we can say wether you will get it or not.
Vw made some good choices with the type3, you have a 4th gear ratio that is similar to many cars 5th, its good for 70/75 crusing all day.
So if you go to a 5 speed your pros are closer ratios, and mabye even a taller 5th. (remember a taller high gear will demand more of the engine at the same speed)
cons, time and expense for what i think are little gains for a daily driver.
I know Glenn has a nice set up but ask him how much it coast for the engine and gearbox. Do you wanna spend that kinda money? |
rokcrln Samba Member
Joined: August 07, 2005 Posts: 162 Location: Winters ca. 95694
Posted: Thu Sep 15, 2005 4:41 am Post subject: |
For me the money factor was not a factor. What I mean by this is I wanted the 5spd because the freeway's I live near are 70mph and 75mph and on both if you are not doing 80+ your a$$ is getting run over. I also wanted the close ratio and better syncro's then a stock t3 tranny. I ended up going with the 901 and once I install it with the porsche shifter and all I feel it should work out real nice with my motor plans. So to go all new VW 5spd you are in the 3K ball park or if you go with the 901 you can do it for about half or less but their is a good amount of fab worh involved.
Kevin _________________ 64 Sun Roof Notch S
71 Chevy PU, bagged,body dropped,LT1
71 Ford Bronco stock 59K miles
05 Tube frame rockcrawler
04 Mini Cooper S |
Glenn Mr. 010
Posted: Thu Sep 15, 2005 6:15 am Post subject: Re: 5 speed tranny? |
krusher wrote: |
Exactly... it all depends on what you want.
First off a turnkey Berg 5 will cost between $3000 and $5000 depending on how you have it build. If you just get a core, install the kit and have new 3rd, 4th and 5th gears, then $3000. If you add some HD parts... $3500. Add a Rhino case... $4000. Add a ZF LSD... $5000
Now I wanted a close 4 speed and high highway speed cruising. So i wend with a 1.58 3rd and a 1.21 4th. For 5th gear i went with a Bus 0.82 4th. Yes... i can cruise all day at 47mph, but at 50 my engine is turning a bit slow and i don't like keeping it there for very long.
It also depends where your car is along it's project. My car was at the end of it's rebuild. It was painted, the interior was in, the engine was done. All I had to do was install the 4 speed and the engine and it was done. But it was already September and I decided that if I was ever going to have one built that was the time.
So for me it was the final touch... not one of the 1st things i'd do.
Is a 5 speed something you should do? I can't say, but I love mine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 15, 2005 7:30 am Post subject: |
Thanks guys, like rok i live by fast freeways, so thats why. i will try to b more specific in the future, but u all helped out. thanks.. _________________ 1969 Squareback
1967 bug |
Posted: Thu Sep 15, 2005 9:27 am Post subject: |
FAT KUDA wrote: |
Thanks guys, like rok i live by fast freeways, so thats why. i will try to b more specific in the future, but u all helped out. thanks.. |
I spent 3 months in the usa last spring, did 6000 miles in a 70 bus doing 50-65mph I never had a problem on the freeways. |
Glenn Mr. 010
Posted: Thu Sep 15, 2005 9:34 am Post subject: |
krusher wrote: |
FAT KUDA wrote: |
I drove my 74 Beetle 3 times across the USA and for 450,000 with a stock 4 speed. I also never had a problem.
But if you want to go street racing and be able to cruise on the interstate... nothing beats a 5 speed.
No one ever said that you need a 5 speed. The question is "Do you want a 5 speed". _________________ Glenn
Member #1009
#BlueSquare |
