vrado Samba Member
Posted: Thu Feb 17, 2005 5:16 pm Post subject: Gene Berg 5spd |
Where would you purchase a Gene Berg 5spd?? I did not see one listed on his web site. |
Miguel Arroyo Samba Member
Joined: April 02, 2004 Posts: 3122 Location: Miami Beach, Florida
Posted: Thu Feb 17, 2005 6:11 pm Post subject: |
It is a conversion and Glen Mr. 010 is a great source of information, PM him. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77087 Location: Sneaking up behind you
Posted: Thu Feb 17, 2005 8:22 pm Post subject: |
Gene Berg sells the parts, but done's sell complete transmissions. Mine was built by Gary Berg, but and shop should be able to build one. I'd stay with the major vendors like Der Transaxle, Rancho and many others.
Be prepared... it's not cheap. Besides the basic kit, shifter and crossmember you'll probibly want to change all the gear ratios and even the r/p.
A "turnkey" tranny probibly be $2500 to $3000. Add a ZF or Rhino case or aftermarket mainshaft and the price goes to $4500.
Basic kit and close 3rd and 4th (not included with kit)
Crossmember
Shifter
Tranny
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Thu Feb 17, 2005 10:30 pm Post subject: |
Glenn wrote: |
Be prepared... it's not cheap. A "turnkey" tranny probibly be $2500 to $3000. |
Try pricing a rebuilt automatic tranny for a late model car. With all those fancy electronic gizmos in today's high end cars, it'll make the Berg seem like a bargain. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Glenn Mr. 010
Posted: Fri Feb 18, 2005 5:52 am Post subject: |
[email protected] wrote: |
Glenn wrote: |
Try pricing a rebuilt automatic tranny for a late model car. With all those fancy electronic gizmos in today's high end cars, it'll make the Berg seem like a bargain. |
It cost me $2800 to have the 4 speed automatic rebuilt in my wife's 91 Passat. And that was wholesale since my friend owns a repair shop and I only paid what his tranny specialist charged. The retail price was $3500. _________________ Glenn
Member #1009
#BlueSquare
gobo57 Samba Member
Posted: Sun Feb 20, 2005 10:16 pm Post subject: berg 5 speed |
look up Painter's Grinding and give them a call. they had one for sale around 2 grand or so a couple of weeks ago. located in dener,co |
campacker Samba Member
Posted: Fri Sep 26, 2008 1:22 am Post subject: |
Sorry I couldn't resist draging this out of the dungeon. But hey that is what the search option if for. Is converting to 5 speed really worth the cost? What are the gains? those that have done it are you glad you did? |
Glenn Mr. 010
Posted: Fri Sep 26, 2008 4:01 am Post subject: |
campacker wrote: |
Is converting to 5 speed really worth the cost?? |
Yes
campacker wrote: |
What are the gains? |
Better acceleration
Better MPG
Higher cruising speed
campacker wrote: |
Yes and i'd do it again. _________________ Glenn
Member #1009
#BlueSquare
F-22A Samba Member
Posted: Fri Sep 26, 2008 8:16 am Post subject: |
So nice to see your reply Glenn. A Berg 5 will be going into my 55! |
paulsvw Samba Member
Joined: May 03, 2005 Posts: 746 Location: San Gabriel Valley
Posted: Fri Sep 26, 2008 12:20 pm Post subject: |
Here are afew pictures of mine, I just picked it up from Rancho a few months ago..
HENRY'S 51 Samba Member
Posted: Fri Sep 26, 2008 1:35 pm Post subject: dbk |
Nice Paul...! I'll have mines in 2 weeks..! I hope.. .. for my next car..! |
Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Fri Sep 26, 2008 6:46 pm Post subject: |
Berg 5 is the only way to go if you wanna have your cake and eat it too.
If you are putting it in an oval it will require body and pan mods, but nothing beyond someone with good fabricating skills, and patience. _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
F-22A Samba Member
Posted: Fri Sep 26, 2008 8:46 pm Post subject: Re: dbk |
DBK wrote: |
Next car...???!!! Henry, you pushing top cars out the door faster than VW did when they were new! |
F-22A Samba Member
Posted: Fri Sep 26, 2008 8:50 pm Post subject: |
Trevor P wrote: |
If you are putting it in an oval it will require body and pan mods |
Trevor, can you post any pics?
My bodywork/chassis guys tell me its clearancing on the frames horns and some reprofiling of the bodywork under the back seat.
They also tell me a Berg 5 doesn't use the front mount when being fitted to an Oval pan, just rear and mid. |
Posted: Fri Sep 26, 2008 11:51 pm Post subject: Re: dbk |
F-22A wrote: |
DBK wrote: |
STAY TUNED MY FRIEND.... |
Posted: Sat Sep 27, 2008 10:55 am Post subject: |
F-22A wrote: |
Trevor P wrote: |
You will have to box in an area under the back seat to clear the nose cone/int housing on the trans. This will also require slight modification of the seat bottom frame.
As for locating the B5 in the pan you will need to use a stock 61> trans with a T2 nose cone in place. Mount this just like you would if you were converting your oval to a late model trans. Bolt your Berg intermediate mount to this trans, and locate your mounting tabs to the frame horns and weld them in. Next you will need to remove the original front nose cone mounting from the pan all together cause it interferes with the B5 and is totally useless now. You will have to fabricate your own fore/aft mount that bolts to the front of the int. mount. You may also have to mod your int. mount to clear your frame horns, but I can't confirm this for sure cause mine is a custom aluminum mount a friend made for me that was copied off a Berg steel one. I ended up notching 1/2 moon cut outs to clear the frame horns.
You will also need to notch the torsion housing just inside and on the end of the right torsion bar. When you install the B5 you will notice that the hockey stick comes out just on the top edge of the orignal hole in the pan which requires you to notch this area (see first pic). It also means you need to run a different shift rod. I ended up using a T3 rod that I lightly curved to meet up with the late model coupler. The reason for this is that Bergs never designed the Berg 5 to fit in a car that originally had a split case trans (which has a lower hole in the pan for the hockey stick to come thru).
56 Wolfsburg PG/SG
70 911T
91 Westy |
Glenn Mr. 010
Posted: Sat Sep 27, 2008 11:39 am Post subject: |
This is why I love my late model.
It took just a few whacks with the business end of a ball peen hammer and my Berg 5 fit right in. _________________ Glenn
Member #1009
#BlueSquare
Bruce Samba Member
Joined: May 16, 2003 Posts: 17302 Location: Left coast, Canada
Posted: Thu Oct 02, 2008 11:36 pm Post subject: |
Glenn wrote: |
It took just a few whacks with the business end of a ball peen hammer and my Berg 5 fit right in. |
And my late model (built 6 months after Glenn's) needed the same pan clearancing as any early car. I think Glenn got lucky. _________________
Posted: Fri Oct 03, 2008 12:25 am Post subject: |
Bruce wrote: |
Glenn wrote: |
And my late model (built 6 months after Glenn's) needed the same pan clearancing as any early car. I think Glenn got lucky. |
Is it possible that the nose cone casting changed at some point resulting with more room for some and interferance for others (early production B5 vs later production)?
I doubt it, but you never know. _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
70 911T
91 Westy |
Bruce Samba Member
Posted: Fri Oct 03, 2008 11:40 pm Post subject: |
Mine's a later kit than Glenn's, so I doubt that's it.
Another mod I had to do was to open up the hole in the pan for the hockey stick and make it a LOT lower. This was necessary to get the gearbox in the exact same spot as the 4 speed. _________________
