schlanks70vdub Samba Member
Posted: Sun Jun 06, 2004 11:39 am Post subject: Do you have to sacrifice comfort for looks??? |
Put an adjustable front on, now I feel ever crack and bump in the road and it feels like it's gonna shake my bug apart, and rides like crap. Would drop spindles help the ride and make it less bone shaking?? Or do all the bugs I see around that are slammed ride like crap..
Thanks |
SonikWagens Samba Member
Joined: May 08, 2004 Posts: 38 Location: Longmont, CO
Posted: Sun Jun 06, 2004 11:46 am Post subject: |
Drop Spindles make a world of difference! I also use a oil rather than gas style shock to keep that plush / non harsh ride. _________________ Matt Sheldon |
Ace Samba Member
Posted: Sun Jun 06, 2004 12:42 pm Post subject: |
You might want to look into getting caster shims too. You are changing suspension geometry when the front and rear are not at an equal level. Caster shims compensate for this when you drop the front. Spindles will help too. |
vdubrida70 Samba Member
Joined: March 20, 2004 Posts: 391 Location: Whittier, CA
Posted: Sun Jun 06, 2004 1:08 pm Post subject: |
yea i looking for some cheap dropped spindles for balljoint. if any one wants to seel some, im more than willing to buy a pair off of u. |
dub_crazee Samba Member
Joined: February 01, 2004 Posts: 314 Location: London, England
Posted: Sun Jun 06, 2004 1:20 pm Post subject: |
how much u lowered?? _________________ 69 Beetle
71 Bay
71 911 |
Posted: Sun Jun 06, 2004 4:23 pm Post subject: |
call me stupid, but before i lowered it I forgot to measure the ride height. I can tell you the front is about 4 inches from the ground now, pluse 145 up front so it is pretty low. I did by shims but haven't had the time to put them in. Thats next on my list.
About the spindles... Can I get ball joint spindles without going to disc breaks?? all i have seen are sold as a set..
Thanks for all the help.. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Sun Jun 06, 2004 4:31 pm Post subject: |
Mine ride great. I loswered it 3" with avis adjusters, single caster shims and Opel GT shorther shocks. Tires are 195/60-15. _________________ Glenn
Member #1009
#BlueSquare |
russell Samba Member
Joined: September 07, 2003 Posts: 601 Location: Satans Roses, Killafornia
Posted: Sun Jun 06, 2004 4:46 pm Post subject: |
gee thanx, i just bought an adjustable beam, do they all feel like this you guys for both b/j and l/p _________________ Click to view image
"Low_Slow: never trust a mexican engine"
Quote: |
DMNCLNR: i gave myself a boner |
RIP HBB (1984-2009) |
Posted: Sun Jun 06, 2004 7:38 pm Post subject: |
I think I'll try the shims and get some shocks... i know that it won't make it ride on air but I think it will be an improvement over how it is now until i get the spindles..
Question about the shims.. exactly where do they go.. I mean in between the two bottom bolts or outside of them
Thanks |
Posted: Sun Jun 06, 2004 9:40 pm Post subject: |
Yes you can get the spindles for either drum or disk. By not using the spindles you are sacrificing 2 - 2 1/2" of suspension travel. Normally the harshness you feel is the shock bottoming out due to the lack of travel by not using the spindles. _________________ Matt Sheldon |
JaredB Samba Member
Joined: March 27, 2004 Posts: 90 Location: The land of Liquid Sunshine WA.
Posted: Sun Jun 06, 2004 9:46 pm Post subject: |
The caster shims go between the frame head and the lower tube of the beam. here is a pic. Did you get longer bolts?
_________________ 1967 Sunroof. |
the dayzwalker Samba Member
Posted: Sun Jun 06, 2004 10:22 pm Post subject: |
if ur going really low, just get rid of your shocks all together...that will smoothen it out a lil
yes, drop spindles will make it less bumpy _________________ Dayzchopper -- www.volksrods.com |
olskool58 Samba Member
Posted: Sun Jun 06, 2004 10:46 pm Post subject: |
my car rides better than it did when it was stock-
adjustable narrowed beam, drop spindals and the cheapest on special weak a** oil shocks you can get- I think my whole set was less then $50 at autozone- _________________ 66 sundial
54 3 fold project
59 Baja monster project
63 ghia |
Posted: Mon Jun 07, 2004 5:42 am Post subject: |
Thanks to all for the advice.
I feel less depressed now that I know I have a better ride to look forward to and to also know I didn't screw up something in the process.
JaredB:: Thanks for that pic. It helps a ton, and yes I did get the longer bolts so I'm good to go. Now I just have to find the time to do it all. |
