Last Year for Swing Axles in Ghias
SCZ9-1-1
SCZ9-1-1 is offline
PostPosted: Thu Oct 29, 2009 7:30 pm    Post subject: Last Year for Swing Axles in Ghias Reply with quote
Type II guy here wondering if you stylin Ghia folks could answer or know when the last year Ghias had a swing axle before going to IRS? I think I have a Ghia transaxle in my bus. The number stamped on the side starts with "AO" which might indicate a Ghia transaxle.
Karmann_65
Karmann_65 is offline
PostPosted: Thu Oct 29, 2009 8:02 pm    Post subject: Reply with quote
An "AO" gearbox is indeed from a Ghia. "AO" is from a 1970 car.
This is mine....
Maybe someone else can chip in with when they changed from swing axle but I think this was one of the last.
View user's profile Send private message Send e-mail MSN Messenger Twitter Gallery Classifieds Feedback
rustfree1967bug
rustfree1967bug is offline
PostPosted: Thu Oct 29, 2009 8:23 pm    Post subject: Reply with quote
1968 should have been the last year just like beetles.
'70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI
Karmann_65
PostPosted: Thu Oct 29, 2009 8:55 pm    Post subject: Reply with quote
This is a list for Beetle gearbox codes "unless otherwise stated". I'd love to know if it's wrong. I removed this box presonally from a '70 Ghia for the better 4th gear ratio. Seems to indicate that '70 was the change over year for Ghias. ??
AA 1200 4.375 From Chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential
AE 1300 4.375 Limited Slip Differential
AF 1500 4.125 L.S. Differential >8/70; also some 1300 8/70>
AG 1200 4.375 Type 147 Fridolin
AH 1500/1600 4.125 IRS from 8/68 - 8/72
AK 1500/1600 3.875 Type 181
AL 1500-1600 3.875 Type 181 with LSD
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia with IRS from 8/70
AO 1600 4.125 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70 - 8/72
AR 1600 3.875 Karmann Ghia with LSD from 8/70
AS 1600(GT) 3.875 From 3/72
AT 1600 3.875 1303s and Cabrio from 3/72
AU 1600 3.875 1303s and Cabrio from 3/72 with LSD
BA 1300/1500 4.375 Semi Automatic form 8/68 - 8/70
BC 1300/1500 4.375 Semi Automatic form 8/68 - 8/70 with LSD
BE 1600 4.125 Semi Automatic form 8/68 - 8/70
BF 1600 4.125 Semi Automatic form 8/68 - 8/70 with LSD
BG 1300 4.125 Karmann Ghia Semi Automatic from 8/70
BH 1300 4.125 K. Ghian Semi Automatic with LSD
BJ 1300 4.375 Semi Automatic from 8/70
BK 1300 4.375 Semi Automatic from 8/70 with LSD
DA 1500/1600 4.125 Type 3 Swing-axle up to 8/68
DB 1500/1600 4.125 Type 3 Swing-axle up to 8/68 with LSD
DC 1500/1600 4.125 Type 3 IRS from 8/68
DD 1500/1600 4.125 Type 3 IRS from 8/68 with IRS
Gary
Person of Interest
Gary is offline
PostPosted: Fri Oct 30, 2009 6:27 am    Post subject: Reply with quote
No. 1968 was the first year for the Autostick, which was on the IRS.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Fri Oct 30, 2009 6:36 am    Post subject: Reply with quote
In the USA 68 was the last year for swingaxle, except as Gary noted the auto stick's in 68 are IRS.
The swingaxle was used for many years past 68 in other world markets in Beetles and some of the Ghia.
Since his 70 is in UK that might explain why his is a swingaxle.
sactojesse
sactojesse is offline
PostPosted: Fri Oct 30, 2009 9:46 am    Post subject: Reply with quote
No, model year 68 and later autostick beetles and ghias were IRS and model year 69 and later manual transmission beetles and ghias. See:
August 1968 is the beginning of model year 1969 for U.S. spec beetles and ghias. This denotes manual transmission beetles and ghias using the 4.125 ring and pinion.
August 1970 is the beginning of model year 1971 for U.S. This denotes the beginning of the 3.875 ring and pinion in IRS ghias. (U.S. IRS Beetles got the 3.875 ring and pinion later, beginning in the 1973 model year, hence the 8/72 end for the AH 4.125 IRS above.)
1966 Karmann-Ghia convertible
keifernet
PostPosted: Fri Oct 30, 2009 9:51 am    Post subject: Reply with quote
Aug 67- July 68 (68 year production) Ghias in the USA manual trans were swingaxle. Only 68 auto stick were IRS. I have owned 3 68's manual trans USA spec that were all swingaxle.
What I was saying/thinking is that some Euro or other non USA Ghia's may have been swingaxle. I know Beetles were.
sactojesse
PostPosted: Fri Oct 30, 2009 10:19 am    Post subject: Reply with quote
True. The U.S. was the first to get IRS beetles and ghias largely in response to Ralph Nader's "Small On Safety" attack on VWs and Corvairs.
SCZ9-1-1
SCZ9-1-1 is offline
PostPosted: Fri Oct 30, 2009 5:31 pm    Post subject: Reply with quote
thanks everyone. I think mine is a 68' from a ghia that someone put into my bus. It goes faster and I did have a tip of one of the shifting forks come out with the oil some years ago and it was bronze and I was told that the forks changed from steel to bronze in 68'.
rustfree1967bug
PostPosted: Fri Oct 30, 2009 7:33 pm    Post subject: Reply with quote
What do you mean NO? 1968 was the last year for swing axle in beetles and ghias. 1969 went irs. [/code]
'70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
_Pascal_
_Pascal_ is offline
PostPosted: Mon Jan 24, 2011 2:28 am    Post subject: Reply with quote
Hm things are not completely clear to me after reading this topic.
Should an american spec ghia convertible from 1969 with manual gearbox be IRS or swingaxle?
John Moxon Premium Member
John Moxon is offline
PostPosted: Mon Jan 24, 2011 3:44 am    Post subject: Reply with quote
1969 with manual gearbox US spec should be IRS.
John.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Jan 25, 2011 12:24 pm    Post subject: Reply with quote
Is your AO trans irs or swing? I had what I thought was an AO case and it ended up being a A0 (zero).
Friedpotatoes
Addicted4life
Friedpotatoes is offline
PostPosted: Wed Jan 26, 2011 11:48 pm    Post subject: Reply with quote
where does one go to find a list of gear box codes ? my 64 ghia has a code of 28 right above the part number 113301103?
56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green)
PostPosted: Thu Jan 27, 2011 1:56 am    Post subject: Reply with quote
Try here: http://www.midsouthvw.com/TechTips/tech_tip_TransaxleCode.htm
and here (scroll down to the very bottom of the page): http://www.vw-resource.com/transaxle.html
John.
