Engine Cooling and Cabin Heating System Tutorial
Page: Previous  1, 2, 3, 4 ... 14, 15, 16  Next
kangaboy
kangaboy is offline
PostPosted: Wed Oct 20, 2010 3:00 pm    Post subject: Reply with quote
Just got to intstall my heater boxes yeterday and ran into a problem. i dont have the "little dealies" that connect the heater box to the rear apron tin (the ones that are on the stock muffler; i now have a merged header with single quiet pack), then to the fan shroud. I also bought a rear apron tin with no pre-heater cutouts, which is ok cause i have dual carbs now. I was just going to cut a few holes in the new tin for the hoses to run from my fan shroud to my heater boxes, but how should i connect them? Can i just run the hoses from the fan shroud to the inlet on the heater box? or will the exhaust burn up my tube?
bugninva
bugninva is offline
PostPosted: Wed Oct 20, 2010 3:34 pm    Post subject: Reply with quote
yes and yes.... the aluminum preheat hoses available at the local chainstores do well...clamp them.. the header will eventually burn through them if you have them against the tube, but they last awhile..
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
shortride
shortride is offline
PostPosted: Wed Oct 20, 2010 3:56 pm    Post subject: Reply with quote
This is very good information.
Thanks!
Pghpunkid
Pghpunkid is offline
PostPosted: Tue Oct 26, 2010 4:57 pm    Post subject: Reply with quote
Im trying fix my heat and had a few questions. Where does the heat actually come in the car? My car is missing a lot in the back seat area and am trying to get heat working before winter kicks in fully. I see the tube right behind the driver seat but is that a tube that is supposed to connect to something in the back?
My 1970 Beetle Project
I've gotta fever! And the only prescription is more VW Stuff!
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Wed Oct 27, 2010 6:28 pm    Post subject: Reply with quote
I came into the late Beetle forum looking specifically for a good description of the heating system.
Boy, did I find it!
Amazing write-up that will definitely help me this Saturday!
Thanks very much!
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Paul Windisch
Paul Windisch is offline
PostPosted: Thu Oct 28, 2010 9:35 am    Post subject: Reply with quote
OK, the heater channel comes in the REAR firewall under the back seat bottom. Then, there is a "Y" shaped metal junction that is full of little holes. That "Y" connects the channel from the rear, then one leg of the "Y" goes to the heater channel to the front of the car, and the other leg goes to the rear heater outlet, in the kick panel under the rear seat bottom at the FRONT of the rear seat. The "Y" is full of holes to reduce noise and is supposed to be wrapped with an insulating blanket.
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer
Paul Windisch
PostPosted: Thu Oct 28, 2010 9:41 am    Post subject: Reply with quote
Here is a pic of the "Y"'s. They are wrapped in the foil, so it is hard to distinguish their shape. Note the outlet hole for the rear in the kick panel, just above of the pliers.
Here is a pic with the insulating blanket removed, you can see it in the lower right corner of the pic, the black metal tube with all the little holes in it:
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Pghpunkid
PostPosted: Thu Oct 28, 2010 1:58 pm    Post subject: Reply with quote
Alright! That helps a lot. I have no heating components in the back off the heater boxes so once i get the heat controlling parts ill go from there. Thanks!
sweet
sweet is offline
PostPosted: Mon Nov 08, 2010 11:49 pm    Post subject: Reply with quote
My car kicks out enough heat to make me happy despite having rotten heater channels, drafty door seals, and the hoses under my hood disconnected.
I'm debating on modifying the "Y's" under my back seat to eliminate the runs through the heater channels. That way I'll be forcing all the hot air to enter from under the seat.
Borgdog
Borgdog is offline
PostPosted: Tue Nov 09, 2010 7:08 am    Post subject: Reply with quote
I guess that depends on whether you want to have any defrost or not. Living in the humid wet pacific northwest coast I need all the defogging ability I can get.
-Dan
'71 Standard Bug project/daily driver
"Ye shall know the Bastard, and the Bastard will set you free."
Paul Windisch
PostPosted: Tue Nov 09, 2010 7:23 am    Post subject: Reply with quote
Well, until he takes the body off to replace the rotted heater channels, he's not going to have defrost anyway, so as a temporary measure, yes, run some tubing to keep yourself warm. Just bring a towel with you so you can wipe off the fog from the inside of the windshield.
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Paul Windisch
PostPosted: Tue Nov 09, 2010 7:35 am    Post subject: Reply with quote
By the way, as a little follow up, I have been cruising fairly comfortably with a drafty dashboard, and I just figured out that my heat exchangers are still the OE VWoM exchangers that DO NOT have the heat sink fins in them, just a tube inside the box, so to be comfortable with these exchangers and a body that is not quite sealed right says a lot about the heater. So far, it's gotten down to about 25 degrees ambient temp, and I'm warm enough. Once the body is sealed and I get some German H/E, I will probably have to turn the heat off after a short distance. Very Happy
1984 Mexican Beetle
-1914cc
-Engle W110 cam
sweet
sweet is offline
PostPosted: Tue Nov 09, 2010 4:12 pm    Post subject: Reply with quote
Ahhh screw the defrost, thus far wiping it with a rag hasn't killed me and its been disconnected since I bought it. I'm on the west side of PA and the windshield has rarely fogged up.
Even with the rot in the channels there's still warm enough air coming out to keep my left leg warm. I just don't like the idea that the hot air in the channels is probably picking up cold air on its way through.
But like Paul said, I can't properly fix that until I pull my body off and considering this topic is about heat for the winter that won't be happening for a few more months.
Who knows, maybe it will work better. I'll post before and after results here if anyone else is curious how it works out.
Excellent write up Paul.
hotrodgary
hotrodgary is offline
PostPosted: Thu Nov 11, 2010 9:36 am    Post subject: Reply with quote
Excellent write up!!!
It gave me an much better understanding of it!!
Only thing that wasn't discussed is how to check/test your thermostat? If its off the engine can you just check it with heat and see if it moves?
-Gary
62 Chevy II
66 Chevelle SS
29 Ford 5 Window Hi-Boy
Volksrod Project
Paul Windisch
PostPosted: Thu Nov 11, 2010 10:13 am    Post subject: Reply with quote
What I did to check mine: Install the thermostat in the bracket off the car, this way when it expands, it will not over-expand and damage the bellows. The thermostat should be marked with a temperature, it is in Celsius (usually 65-70* C, which converts to 149-158* F). This means it should expand within this temp range. Get a meat thermometer, put a pot of water on the stove and submerse the thermostat (mounted in the bracket) in the water and turn the heat on. Then monitor the temp with the thermometer, and the bellows should expand somewhere between 149 and 158*. When you are done, just turn the heat off and let the water return to ambient temp, or close to it, before removing the thermostat, so it doesn't get cold shocked. If your thermostat is expanded when it is cold (like when the engine hasn't been run for a few hours), then it is no good.
EDIT: I suppose you could check it with a heat gun on the car, just to see if it moves, but it would be somewhat difficult to monitor the temp at which it opens. A hair dryer will generally NOT get hot enough to expand the bellows.
1984 Mexican Beetle
-1914cc
-Engle W110 cam
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Fri Nov 12, 2010 5:21 pm    Post subject: Reply with quote
Got my levers in the mail and will install them tomorrow.
Does this orientation look correct?
Left and right:
Left
Right
Eric
Paul Windisch
PostPosted: Sat Nov 13, 2010 6:29 am    Post subject: Reply with quote
Looks like that's correct. Very Happy
1984 Mexican Beetle
-1914cc
-Engle W110 cam
rlutterb
rlutterb is offline
PostPosted: Sat Nov 13, 2010 10:04 am    Post subject: Reply with quote
I have often used an extra fan under the rear seat to give the system a boost..........available at JC Whitney (I know, we all hate them) but a bit pricy. I have an extra I just bought at a swap meet for 20 bucks.
Here my set up......
I ran the switch to an open spot on the dash and used an extra defroster switch to power it. That extra boost is nice.
1973 Super Beetle
1978 Ford F-250
2020 GMC Sierra
pcox2124
pcox2124 is offline
PostPosted: Fri Nov 26, 2010 9:38 pm    Post subject: Reply with quote
So, I'm still trying to figure out the whole heater system. I have a 71 Std with an oil bath filter and an afterstock Bug Pack exhuast. My biggest question is what happens to the hoses once they exit the engine bay...do the heater boxes come through the holes in the bay? Does anyone have any wide shot pics underneath the car so I can see how it is all mapped out.
This forum has been very helpful.
pcox2124
pcox2124 is offline
PostPosted: Fri Nov 26, 2010 9:53 pm    Post subject: Reply with quote
Well....nevermind...found a good video on Youtube...haha
Page 3 of 16
