what shocks to use with drop spindles
Page: 1, 2, 3  Next
scottyellow67
scottyellow67 is offline
PostPosted: Wed Feb 02, 2011 2:45 pm    Post subject: what shocks to use with drop spindles Reply with quote
I just installed CB Perf disc brake kite with drop spindles. What shocks are the recommended?
Nubby
Nubby is offline
PostPosted: Wed Feb 02, 2011 2:54 pm    Post subject: Reply with quote
I would go with an oil based shock not gas if you want a stock like feel to your ride. KYB....
TonysGarage
Banned
TonysGarage is offline
PostPosted: Wed Feb 02, 2011 3:01 pm    Post subject: Reply with quote
x2 on KYB
I dont take shortcuts, i put care and pride into all i do--for a fair price of course
scottyellow67
PostPosted: Wed Feb 02, 2011 3:08 pm    Post subject: Reply with quote
are there different lengths??? or just order the normal size for a 67 bug?
wildman1
wildman1 is offline
PostPosted: Wed Feb 02, 2011 4:07 pm    Post subject: Reply with quote
If your beam is stock, not lowered and all you added were the spindles to achieve desired drop, then you order standard length shocks for your year VW. KYB's are gas, the GR-2's are firm and should be last choice if soft ride is your goal. I suggest Kofap/Boge/Mexican type oil shocks for soft ride and again KYB GR-2's for a sportier suspension when needed.
Nubby
Nubby is offline
PostPosted: Wed Feb 02, 2011 10:33 pm    Post subject: Reply with quote
Are you running just dropped spindles with a stock beam?
Lettuce
Lettuce is offline
PostPosted: Wed Feb 02, 2011 11:05 pm    Post subject: Reply with quote
KYB makes both oil and gas shocks. The silver GR-2 are oil and the white GAS-A-JUST is a gas shock.
stock boge's are soft. GR-2 are a little stiffer. Gas-a-justs are more stiffer.
gimpy60
gimpy60 is offline
PostPosted: Thu Feb 03, 2011 5:10 am    Post subject: Reply with quote
KYB gr2 are gas, gr stands for gas ryder, you better do your homework more in depth. The silver are on road, the white gas-a-just are off road. Rolling Eyes
How the hell ya spost ta fix it, ya don't even know how it works boy
andk5591
andk5591 is offline
PostPosted: Thu Feb 03, 2011 2:21 pm    Post subject: Reply with quote
The GR-2 (Gas Ryder) is still technically an oil shock. I HAVE done my homework and I am not picking a fight by any means, but folks that say that they are rough riding either have never tried them or ran them with bias ply tires. I have them on my stock 65 all around, the front of our buggy and on the rear of our 61 (will be putting them on the front in the srping - have a dropped beam and ran cheapies to make sure they don't beak. ) I also have them all around on my VW woodie.
The GR2 gives a nice ride - slightly firmer than stock and handling is very good. There are a LOT of people that run them and there is a good reason. And dropped spindles, as mentioned above - require stock length shocks.
Gas Adjusts are a different story - I would NOT run them on the front of a street car, but I do run them on the rear of our buggy.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
gimpy60
gimpy60 is offline
PostPosted: Thu Feb 03, 2011 2:42 pm    Post subject: Reply with quote
No pissing match, there is oil & nitrogen in them, therefore they are gas charged shox. I think you will find this is true for all gas shox. I have never heard of a gr2 "technically" referred to as a oil shock. but what do I know? Rolling Eyes
scottyellow67
PostPosted: Thu Feb 03, 2011 5:59 pm    Post subject: Reply with quote
Yes, I am currently running a stck beam and drop spindles. I may want to go lower later. Which brings me to another question. What is the next phase of lowering with out replacing the beam???Is there one? Cool
andk5591
andk5591 is offline
PostPosted: Fri Feb 04, 2011 5:15 am    Post subject: Reply with quote
Beam adjusters are freaking amazing - I did a 2" narrowed adjustable CB Performance beam in my wifes 61 - adjusting height was so easy. But the question is how low can you go and not bottom out in our lovely PA potholes....... I am kicking myself in the butt for not doing an adjustable beam on my current project - I did dropped spindles and I would like another 3/4" or so........
And as far as the GRs being gas or not - I have to conceed - I could not find the documentation I found before. Big thing is that the GR is a conventional twin tube design and the Gas Adjust is mono tube - A Gas adjust WILL actually provide lift on a light car - like the front of a bug - but they work beautifully for something like the rear of our buggy, which is lowered slightly, so I want the shocks a little stiffer.
wildman1
wildman1 is offline
PostPosted: Fri Feb 04, 2011 7:09 am    Post subject: Reply with quote
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=SSH0008&cartid=
Taken from AirCooled.net of course. I could have copied many suppliers descriptions but we get the idea. As I mentioned in my response above, they are more firm than oil type shocks mentioned. If you have the time, contact KYB and get the technical info needed to satisfy your argument, I am sure many would like to know the truth by now! Until then, let's help a fellow enthusiast get his VW settled.
Wink
wildman1
wildman1 is offline
PostPosted: Fri Feb 04, 2011 7:19 am    Post subject: Reply with quote
By replacing, do you mean not unbolting the current beam from the pan, or not buying another beam all together? You can add adjusters to your current beam. The OEM oil shocks will settle approximately 1/2" lower than GR-2 gas shocks will. Exclamation
gimpy60
gimpy60 is offline
PostPosted: Fri Feb 04, 2011 12:23 pm    Post subject: Reply with quote
I am still trying to locate an oil only short shock. The kyb & now monroe-matic are just too stiff. I'm lowered around 3", have plenty of spring w/o any shox but ain't gonna drive it like that. Been toyin with the idea of extending the shock towers, not out of the question. If someone knows about a short oil shock, let us in on it, ok?
wildman1
wildman1 is offline
PostPosted: Fri Feb 04, 2011 2:24 pm    Post subject: Reply with quote
Bug Pak oil shock for lowered front ends! I forget the part #, but I had a set on my '67 (bj beam) with adjusters down to about 3.5"-4" drop, rode better than most. It was easy to forget the ride height setting with the Bug Pak shocks. Wink
scottyellow67
PostPosted: Fri Feb 04, 2011 6:22 pm    Post subject: Reply with quote
I CAN replace the beam if needed, but is there another way (other than the spindles I have now) to go lower with out putting in a different beam? How difficult is it to add beam adjusters? Ive heard some mention a "stock adjustable beam". How do I know if I have one of those?
I appreciate all the feedback Im learning more everyday.
wildman1
wildman1 is offline
PostPosted: Fri Feb 04, 2011 6:43 pm    Post subject: Reply with quote
A "stock adjustable beam" could only mean one thing these days....not narrowed. A beam is either stock or has adjusters, hence adjustable. What are your intentions with this Bug? If you plan to drive it anywhere and want to enjoy it and preserve it, then just spindles will do. If you plan to slam it and scrap the pavement just to look like all the others do, then you'll need an adjustable beam for that.
Personally I would get it rollling with the spindles and chosen shocks, drive it, let it settle after a few hundred miles and then decided what you want. Go for your needs, not what you see and like, two different things most of the time. Good Luck!
andk5591
andk5591 is offline
PostPosted: Fri Feb 04, 2011 7:22 pm    Post subject: Reply with quote
Couple thoughts - running a lower profile tire helps - I am running about 1.5" shorter fronts on our 61 and that gives me an additional 3/4" of lowering. And depending on the wheels you have, you may be able to use a reasonable width tire. I personally think a 145 is a little too narrow, but thats just me - I like to be able to steer. I have 185/60-15s on the front of the 61.
Something else that some do is just put a little weight in the front. Another things is to remove a couple spring leaves. Some of the kit car manufacturers used this to get the front height down and I recently talked with a couple folks that had done this with no issues - but you should research this more. I personally had never done it and probably wont.
I was going to do weld in adjusters, but till it was all said and done, a new CP narrowed (2") beam with adjusters wasnt that expensive.
A comment on the shorter KYBs for lowered applcations - depends on who you get them from, but one of the ones that is typically sold is also a replacement for a Chevy Blazer - In my opinion the valving would be way too stiff - BUT I have not used them, so I can't say firsthand. Maybe this is why some folks think they are too stiff.........
Someone else sells a KYB that requires mounting bolts adapters that sounded like a more appropriate shock, but I don't remember the particulars. I spent about an hour on the phone with KYB on this issue.....
scottyellow67
PostPosted: Sat Feb 05, 2011 4:32 pm    Post subject: Reply with quote
I ordered the KYB GR-2's today. Thanks for the help guys.
Page: 1, 2, 3  Next
