ajl1971 Samba Member
Joined: December 09, 2010 Posts: 89 Location: New York
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Sat May 12, 2012 4:12 pm Post subject: |
Smaller filter i use a vw rabbit filter(smaller diameter) |
Posted: Sat May 12, 2012 4:19 pm Post subject: |
spanky324 wrote: |
Im actually using Mahle OC-28 and still.
Do you happen to know the code for the one you use so I can try to get it ?
Thanks |
Nubby Samba Member
Joined: August 28, 2010 Posts: 605 Location: Down by the river
Posted: Sat May 12, 2012 5:32 pm Post subject: |
Can you relocate the filter? My A1 fits no problem but my filter is off to the side? |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3594 Location: viroqua wi.
Posted: Sat May 12, 2012 5:48 pm Post subject: |
It's a pump filter, no full flow, no relocate. |
Nubby Samba Member
Posted: Sat May 12, 2012 8:12 pm Post subject: |
I would go with Vintage Speed if you can. |
Posted: Sat May 12, 2012 9:55 pm Post subject: |
bsairhead wrote: |
You are right, I cant relocate the oil filter. |
Posted: Sat May 12, 2012 9:56 pm Post subject: |
Nubby wrote: |
I already spent the money on this one. |
Nubby Samba Member
Posted: Sat May 12, 2012 10:42 pm Post subject: |
He adjusted mine. I sent it back and he fixed it. Give Tiger a call. Very good reputation. |
Posted: Sun May 13, 2012 4:32 am Post subject: |
I use the Wix equivalent to ph2870a Fram |
Posted: Sun May 13, 2012 5:55 am Post subject: |
Nubby wrote: |
That is great to know, I left him a vm last friday, I will try to call him again on Monday. Thanks I did not know he could do that.
I will let you know. |
Posted: Sun May 13, 2012 6:00 am Post subject: |
spanky324 wrote: |
Which one, for some reason my setup is very tight, I use Wix 51515, did not work, OC-25 which is the smaller, OC-49, none of them work. The pipe that curves going to the J-pipe is the one in the way. Another guy suggested to use the one for a Rabbit but Im waiting for him to reply to see if I can get it locally. |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Sun May 13, 2012 7:15 am Post subject: sidewinder |
.The oil filter will bake in that location regardless of how small the filter is!Do a remote location for the filter . Leave the A-1 as is it will work great. CB sells a Maxi in out pump that you can then mount a remote filter to and even a remote cooler as well. This will serve you better in my humble opinion than the filter pump.The header costs a whole lot more than both the filter pump and the maxi pad _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Posted: Sun May 13, 2012 10:28 am Post subject: Re: sidewinder |
If you run a filter pump you need the Flanged version of the Sidewinder, which puts the 1/3 J-tubes in the STOCK location. The inboard location is stupid (IMO), it not only interferes with filter pumps, but also the stock thermostat, and Sled Tins. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Sun May 13, 2012 4:43 pm Post subject: |
Which way is better, Do a remote location for the filter or get the flange that John is talking about. Any pictures ? |
Posted: Sun May 13, 2012 5:32 pm Post subject: Re: sidewinder |
Cptn. Calzone wrote: |
.The oil filter will bake in that location regardless of how small the filter is!Do a remote location for the filter . Leave the A-1 as is it will work great. CB sells a Maxi in out pump that you can then mount a remote filter to and even a remote cooler as well. This will serve you better in my humble opinion than the filter pump.The header costs a whole lot more than both the filter pump and the maxi pad |
Hi, is this what you are referring to ?
http://www.cbperformance.com/catalog.asp?ProductID=1875 |
Posted: Sun May 13, 2012 5:45 pm Post subject: |
John, Im willing to try it however I happen to have a Mahle OC-25
http://motorsports8.tripod.com/id36.html and it wont clear either,its 3.5 long, unless the one you are suggesting is smaller. The clearence is notnthe diameter of the oil filter its the length. |
Posted: Sun May 13, 2012 6:30 pm Post subject: oil |
Yes the CB pump posted is the one. Not a bad alternative considering where you are at this stage of the game. Just take off the anodized cover and make sure the inner oil passages are not restricted or have any metal boogers . This will end the search for a small filter that still will get cooked by the header.You will have filtration, and clearence. _________________ 71 westfalia
Posted: Sun May 13, 2012 6:35 pm Post subject: Re: oil |
Yes the CB pump posted is the one. Not a bad alternative considering where you are at this stage of the game. Just take off the anodized cover and make sure the inner oil passages are not restricted or have any metal boogers . This will end the search for a small filter that still will get cooked by the header.You will have filtration, and clearence. |
Do you know who has one ? CB are out of stock but I will call Daniel tomorrow just in case the inventory is off. |
