crawdizz Samba Member
Joined: June 07, 2012 Posts: 132 Location: washington
Posted: Wed Jun 27, 2012 7:00 pm Post subject: rear torsion adjustment for lift |
Anybody have a set by step vid of how to do this? or maybe just a good heads up, I have a 72 standard that needs a little height for my new tires. Do i adjust it on both sides (inside/outside of each bar) ? or just the inside splines on each side of the car? any tips on this would be great.. I have my protractor ready |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Jun 27, 2012 8:11 pm Post subject: |
Its been posted about a zillion times (HINT: in future try using search) .....
http://www.mydune-buggy.com/dl_files/reartorsionsetup.pdf
szuppo Samba Member
Joined: February 21, 2012 Posts: 51 Location: NE OHIO
Posted: Mon Jul 02, 2012 6:16 am Post subject: |
Question- If my spring plates are about 1/4" from hitting the lower stops on my IRS buggy. Am I at maximum height and would I be able to raise it anymore to address a severe negative camber issue I am having which is wearing out the inside of the tires? |
Posted: Mon Jul 02, 2012 7:11 am Post subject: |
At that position I would suspect the camber would be pretty much correct for tire wear.... But yes you can add more preload which puts more down pressure on suspension ....
IRS generally does not have much in camber issues unlike swingaxle because tires move pretty straight up and down (but yes there is a bit if a arc)... Have you use tools to measure camber when buggy is parked to see what actual state of camber rear wheels are in.... Tire wear may be something different then camber, it could also be from sever toe out of rear wheels....
szuppo Samba Member
Posted: Mon Jul 02, 2012 10:24 am Post subject: |
No, I have not used tools to measure it but I can stand directly behind the rail and see I have a lot of negative camber. |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Thu Jul 05, 2012 12:24 pm Post subject: |
A lifted IRS with stock parts will have some positive camber. If you're close to the stops and you have negative camber, then your trailing arm may be bent. Stock arms will bend pretty easy if they're not boxed. |
