Molly1973 Samba Member
Posted: Thu Jul 12, 2012 8:24 am Post subject: 1973 VW Super Beetle - Pictures |
Here she is ($4000 - 500 miles on engine and transmission...new tires...new interior):
dubllyou Samba Member
Joined: May 24, 2012 Posts: 1251 Location: Jack & Cee Motors
Posted: Thu Jul 12, 2012 9:14 am Post subject: |
Looks nice! Do you know what those front seats are out of? They seem to fit good and look pretty comfy.. _________________ Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote: |
You cannot polish a turd, but you can roll it in glitter. |
bandi Samba Member
Joined: August 24, 2005 Posts: 1068 Location: Campbellford, Ontario, Canada
Posted: Thu Jul 12, 2012 9:24 am Post subject: |
Just get that fuel filter out of the engine compartment _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Thu Jul 12, 2012 9:26 am Post subject: |
Really nice start! Dump that 009 distributor and get an SVDA and you will be very happy. Also get rid of the gas filter in the engine compartment. You don't want your new baby to catch fire. I typically run mine were it comes out of the wishbone and above the CV joint. _________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Thu Jul 12, 2012 9:56 am Post subject: |
no half moon vents and a 60s style radio antenna? you got a semi-back dated super franken-bug! getting rid of the vents is a good thing though, as cancerous rot starts there, yours was probably repaired already and eliminated. car looks sweet though, can't get one like that around these parts for that price! _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 834 Location: Grand Forks, ND
Posted: Thu Jul 12, 2012 10:01 am Post subject: |
Did you do the interior? I would like to know how the headliner was done. I want to do something similar to mine. |
Posted: Thu Jul 12, 2012 10:05 am Post subject: |
Thank you for the compliments! The interior was completely done by the previous owner, so I don't know where the seats came from or how the headliner was done. Sorry about that!
Can you show me a picture of where you put the fuel filter? I am not very technica (009 distributor vs. SVDA - not sure what you mean or what the difference is?l. |
Posted: Thu Jul 12, 2012 10:19 am Post subject: |
The 009 distributor was originally intended for stationary motors used in industrial applications and is mechanical advance only. It doesn't work as well as the one that was originally in your car. SVDA stands for Single Vacuum Dual Advance and has vacuum as well as mechanical advance mechanisms = better performance under general driving conditions. The best place for the fuel filter is OUT of the engine compartment. Some people put it up front where the fuel line exits the gas tank under the car, others put it in front of the motor by the left axle where the fuel line exits the bodywork. More important is that the fuel lines and all connections are inspected regularly. (The best place for the filter as far as keeping crud out of the carb is "last in line" or right before the carb...."catch 22") _________________ Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote: |
Posted: Thu Jul 12, 2012 10:32 am Post subject: |
Thank you for the explanation on that. I like the idea of having the fuel filter right behind the engine compartment, as you stated. Ideas on where I can pick up the appropriate fuel lines as I will need new ones to make the change, right? |
oldPSUguy Samba Member
Joined: May 21, 2012 Posts: 217 Location: Vancouver WA
Posted: Thu Jul 12, 2012 11:02 am Post subject: |
Looks like a nice straight driver. My VW mechanic says that keeping the fuel filter replaced periodically, and the lines close to it inspected, is most important. Your car has had trim removed and vents removed but is still essentially stock. Think twice about customizing recommendations. Original beetles are getting hard to come by. |
71superAS Samba Member
Joined: February 02, 2012 Posts: 223 Location: New York
Posted: Thu Jul 12, 2012 12:35 pm Post subject: |
dubllyou wrote: |
The 009 distributor was originally intended for stationary motors used in industrial applications and is mechanical advance only. It doesn't work as well as the one that was originally in your car. SVDA stands for Single Vacuum Dual Advance and has vacuum as well as mechanical advance mechanisms = better performance under general driving conditions. The best place for the fuel filter is OUT of the engine compartment. Some people put it up front where the fuel line exits the gas tank under the car, others put it in front of the motor by the left axle where the fuel line exits the bodywork. More important is that the fuel lines and all connections are inspected regularly. (The best place for the filter as far as keeping crud out of the carb is "last in line" or right before the carb...."catch 22") |
Mehhhhhhhhhh. Aside from the fire risks of the fuel filter in the engine bay, I don't like the idea of sending debris into my fuel pump. That's how you kill them.
That's why I moved mine, more than fire risk. Also installled some NOS german braided fuel line. _________________ Ahoy! |
TjdTaylor Samba Member
Joined: July 04, 2011 Posts: 1727 Location: Niagara Falls, Ontario
Posted: Thu Jul 12, 2012 1:26 pm Post subject: |
71superAS wrote: |
dubllyou wrote: |
That's why I moved mine, more than fire risk. Also installled some NOS german braided fuel line. |
yeah, when i bough the car, mine was between the pump and the carb, obviously in the engine compartment so i moved it behind the firewall and i definately like it there alot better. Looks neater inside the engine and dont need to worrk about fuell pump/fires. If you are REALLY worried about particals, put one underneath the tank and before the firewall. _________________ 1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote: |
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows |
Posted: Thu Jul 12, 2012 1:28 pm Post subject: |
also, is it a documented 500 or is that what the PO says? Never trust a PO. They are probably going to be full of shit cause they wana get rid of the car. _________________ 1974 SuperBeetle Build
Jamies74sb wrote: |
RDbugger Samba Member
Joined: January 10, 2012 Posts: 157 Location: Sydney,Australia
Posted: Thu Jul 12, 2012 1:38 pm Post subject: |
Looks in superb condition just drive it as is then do a restore a couple years or more down the line.
togatony Samba Member
Joined: December 29, 2011 Posts: 42 Location: Kansas City, MO
Posted: Thu Jul 12, 2012 3:25 pm Post subject: |
dubllyou wrote: |
Looks nice! Do you know what those front seats are out of? They seem to fit good and look pretty comfy.. |
I agree, those seats look awesome! If you know or anyone else knows what those seats are out of please post! |
GatorJZ Samba Member
Posted: Fri Jul 13, 2012 5:31 am Post subject: |
71superAS wrote: |
Doesn't play well with ethanol. _________________ 1973 Sports Bug (Super) |
Posted: Fri Jul 13, 2012 5:53 am Post subject: |
GatorJZ wrote: |
71superAS wrote: |
Doesn't play well with ethanol. |
i use an additive that takes away the ethanol. Just acouple cap fulls at each fillup. _________________ 1974 SuperBeetle Build
Jamies74sb wrote: |
Posted: Fri Jul 13, 2012 6:49 am Post subject: |
GatorJZ wrote: |
71superAS wrote: |
I use additives, too, but I will keep an eye on it. I came into a pretty obscene length of it, like 20 feet. Enough to last me years, haha. _________________ Ahoy! |
Posted: Fri Jul 13, 2012 1:44 pm Post subject: |
It isn't a documented 500 miles...he just said 'roughly'...and the odometer had stopped working, so I had that repaired. I believe the seats say 'Veracruz' on them...if that helps. |
wbrown45 Samba Member
Posted: Fri Jul 13, 2012 2:46 pm Post subject: |
Very nice! Have fun driving this summer. I would also suggest carrying a fire extinguisher for the worst case scenarios. _________________ OK Thang |
