cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Tue Jan 15, 2013 8:32 pm Post subject: |
looky here:
The spring is shown, to get better throttle return put the spring bracket in the hole to the right, to pull across. do this on both carbs, works a treat! _________________ 1972 1302
HPMX 40's & 019 |
RocketA Samba Member
Posted: Wed Jan 16, 2013 4:31 am Post subject: Re: Dual carb quick question |
mynameisnick wrote: |
Hello the samba,
I got some dual carbs and have them almost all set up. I need to know if you put 2 different fuel hoses from the fuel pump for each carb. Or do you do it another way? If someone can help me out. I would be thankful. |
I remember your first posts a month or so ago. You were the guy with all the polls. You might think I'm a jerk but this car is gonna haunt you unless you have your friend who is good with old cars around you all the time
Think about it. Your first posts on this forum were about the car not running right in the rain or the cold. You asked if dual carbs would cure the problem and someone said no so you bought electronic ignition. Then you posted about your broken electronic ignition, your broken distributor and all that jazz
http://www.thesamba.com/vw/forum/search.php?search_id=usertopics&user=306273
Now you got the dual carbs and you still got problems.
I'm no maestro and I f**k things up all the time by overthinking or under thinking. You got to go about things systematically and intelligently and thoughtfully or you're just gonna be running in circles The way you post about "dual carbs" as if they were all the same tells me that you're just not thinking things through.
Plus you shouldn't put new carbs on an engine you aren't sure of or didn't have running right!! If you keep buying parts to cure or get around problems you'll be broke and still have a broken car!!! You'll wind up selling the car and you won't get your money back.
Guys who sell their cars quickly or hide them in the garage for a few years before selling them are the guys who gave up because they thought working on "old VW's" was easy. They were right. It is easy. But you have to be systematic. Otherwise you do a bunch of random easy things that don't fix your problem |
mynameisnick Samba Member
Joined: September 14, 2012 Posts: 245 Location: United States
Posted: Wed Jan 16, 2013 4:33 pm Post subject: carbs |
I know it was the carb freezing and how I know is because the heat risers were clogged when I removed the manifold. The car runs great, just had some problems with carb freezing. Also a old vw engine is going to need some fixes. I also didn't know what the poll ment at the time so I would put random stuff in it. Now I know and am learning about my car. The electronic ignition helped get better timing. My dual carbs are just weird because they are not set up right. Because I am only 16 and new to this, I didn't set them up correctly so my friend is going to get them all going for me. |
Posted: Wed Jan 16, 2013 5:22 pm Post subject: RocketA |
RocketA , That photo is very helpful and it did fix my problem. Now I got 2 more things then I am done. I need to get the throttle cable set up and what do I do with heat riser holes. Do you cover them with something? |
Posted: Wed Jan 16, 2013 5:44 pm Post subject: |
Heat riser block off plates, gaskets, nuts and bolts came with the kit, bolt em on. _________________ 1972 1302
HPMX 40's & 019 |
Posted: Wed Jan 16, 2013 5:56 pm Post subject: heat risers |
Ok I did that and it was no problem. Its sounding great. All now is throttle cord and maybe a little idle mixture tweaking which I might wait for my friend to do that. |
Posted: Thu Jan 17, 2013 7:12 pm Post subject: Great news |
Great news!!! The carbs are all set up and running great. Thanks to all that helped me. |
Posted: Thu Jan 17, 2013 7:20 pm Post subject: |
post a picture of your setup _________________ 1972 1302
HPMX 40's & 019 |
Posted: Thu Jan 17, 2013 8:05 pm Post subject: ok |
Ok well it's dark out right now so I will post a picture tomorrow after noon. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15989 Location: North Florida, USA
Posted: Sat Jan 19, 2013 9:16 am Post subject: Re: picture |
Now I need to know how much the carb's throttle should be when gas is all the way down. Is this too much or not enough?
At full throttle, the throttle butterfly should be exactly parallel with the flow of air-fuel through the carb throat. If it is not open all the way you have unused performance.
Be careful in that some carbs that do not have a stop for the WOT position can be opened beyond WOT and the butterfly can start to close again.
Whether you limit the motion via the cable adjustment or the linkage, you want the throttle plates parallel with the airflow at WOT/pedal to the floor. _________________ AshMan40
Posted: Sat Jan 19, 2013 11:51 am Post subject: reving |
When I rev the engine up a lot, I get a little bit of popping. Is that normal on dual carbs or does that mean it needs a little bit more adjusting? |
JRKman Samba Member
Joined: June 21, 2011 Posts: 291 Location: Portland, OR
Posted: Sat Jan 19, 2013 11:52 am Post subject: |
Could be vacuum leak, too lean of a mixture, incorrect timing, or incorrectly adjusted valves.
-Josh |
Posted: Sat Jan 19, 2013 11:56 am Post subject: ok |
Ok well I will buy some carb cleaner for vacuum leaks and adjust valves soon. Also for timing it stays the same right. I have a 009 dizzy and I use 7 degrees before TDC and about 35-36 degrees when rpms rise. |
JRKman Samba Member
Posted: Sat Jan 19, 2013 12:04 pm Post subject: |
Needs to be max of 32 degrees. 35-36 is too much and could be your problem. |
Posted: Sat Jan 19, 2013 1:02 pm Post subject: ok |
Ok well thats probably my problem haha |
Posted: Sat Jan 19, 2013 7:47 pm Post subject: problems |
Ok well I timed it and did a valve adjustment. I am getting worse power and terrible gas mileage. I have done everything I can do for months and I think I just need to get it checked by a professional because I have tried everything that can be causing low power and bad gas mileage problems. |
Posted: Sat Jan 19, 2013 7:56 pm Post subject: |
Ya barely just got the thing running and your already giving up? where are you? there's plenty of clubs, shops, friends, VW freaks around to help out.
Don't quit now, Dad has already spent the money, whattaya gonna do? go on tumblr and complain? _________________ 1972 1302
HPMX 40's & 019 |
Posted: Sat Jan 19, 2013 8:03 pm Post subject: Give up |
I am not giving up. Its just as an un experience teen, I should have gotten it checked by a mechanic when I first got it. I work on it Pretty much every weekend and after school. I just am frustrated that it this is happening. I do not know of any vw clubs around. I will keep researching like I always do and try to solve the problem. I am located in Santa Clarita, California. |
Posted: Sat Feb 02, 2013 1:03 pm Post subject: mechanic |
the mechanic figured out some problems with sparking and spark plug wires too. I have better performance and gas mileage now. Thanks for the help and I hope my dual carbs will stay good for a while or so. So far no problems. |
