Posted: Mon Nov 18, 2002 12:50 pm Post subject: Floor pan color? |
With new floor pans installed, and all the necessary bodywork being done to my Thing, I'm starting to think about getting her painted.
My question is: what exactly is the stock interior floor pan color for a Thing? Is it black, or were they painted to match the color of the car (i.e., white, yellow, or orange)?
Based on everything I've seen, I'm guessing the original color is black. If so, does anyone know if it's a flat, semi-gloss, or glossy black?
I'm going for a show-quality restoration here, so I want to get as close to stock as possible. Thanks. |
Joined: August 07, 2002 Posts: 53 Location: Houston, Texas
Posted: Thu Nov 21, 2002 8:39 pm Post subject: Floor pan color? |
thing pans were semi gloss
thing bodies were semi gloss too.
if you paintyour car high gloss it will not be original. |
Posted: Fri Nov 22, 2002 11:01 am Post subject: Floor pan color? |
The paint used on the floor pans was coded RAL 9005. Its not a VW color but rather a commercially used designation
Mike |
Posted: Fri Nov 22, 2002 2:42 pm Post subject: Floor pan color? |
So, what I just heard elsewhere is that the whole interior of the car (including the floors) should be one color, and it should match the exterior color of the car. I gather that this should also be a semi-gloss job, but I'm confused about the different non-VW paint code (RAL 9005) for floor pans - is this the paint used on pans as they are manufactured (i.e., the color before they are installed?)
Thanks |
coad Samba Scapegoat
Posted: Fri Nov 22, 2002 4:55 pm Post subject: Floor pan color? |
No. The floor does NOT match the interior. It should be black and semi gloss. Actually, I grew up with the little crayola box so my color sense is pretty crude, but I think it should be a black with a hint of dark green in it (kinda milky looking if that makes sense). I'm pretty sure its the same as the factory coating on bug floorpans --maybe someone over there has a color code? |
Posted: Sat Jan 25, 2003 10:46 am Post subject: Floor pan color? |
I have no color code, but also i know for sure that the pan has to be black, since i own two things.aircooled greetings from holland. |
lastsafari Samba Member
Posted: Thu Feb 27, 2003 12:34 am Post subject: Floor pan color? |
all Things floor pans were painted Azurite semi gloss black prior to assambling regarless of body color. This includes Acapulcos. |
dborell Samba Member
Posted: Mon Nov 29, 2004 11:49 am Post subject: Re: Floor pan color? |
lastsafari wrote: |
Is this the same color as RAL 9005 that was previously posted? |
kubelmann Samba Member
Posted: Sun Jan 02, 2005 11:06 pm Post subject: |
Yes, to expand on what Safari posted, all VWs of that era were painted with the same paint prior to having the body bolted in place. The paint is Azurite semi gloss black or at the car paint store RAL 9005. One of my current 73 Things has original paint on the bottom side of its pan. I also have a 73 bug parts car that has sections of the pan that still retains it factory paint and it is the identical color of my Thing's underside. K-mann |
7T3Thing Samba Member
Joined: March 30, 2014 Posts: 28 Location: Upstate New York
Posted: Fri Apr 18, 2014 6:53 pm Post subject: |
So, the interior side is semi-gloss black, was the exterior side black as well, or body color?
Want to be as close to original as possible.
Thanks,
Dave _________________ Working with my son on his 1973 Thing |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Apr 18, 2014 7:13 pm Post subject: |
Yes, the whole pan inside and out. |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Sat Apr 19, 2014 5:40 am Post subject: |
if you want your resto to last, I reccomend por 15ing the pans the useing their simi gloss black top coat, if done right your pans will never rust! |
