Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Thu Sep 26, 2013 3:05 pm Post subject: |
GI Joe wrote: |
Mine is a '65(IIRC) but it's certainly NOT a 16gal tank.(I don't think...). I am Not sure if the 16gal is taller all across,either way The filler neck may be shorter(it would still have to fit under a Bug hood, right?) My filler neck is a good ~6" tall... |
Here is a picture. It looks like it is the same height all the way across and the filler neck is just a stub. It does fit under a Bug hood, so it should under the Thing.
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Fri Sep 27, 2013 10:54 am Post subject: |
kubelmann wrote: |
Can you post pics. I love solving VW mysteries. Keeps the old memory/observation fluids going. |
Here are pics. The rear of the tank sits properly down in the opening while the front is shimmed up. The side filler pieces are ripped on a taper.
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Sep 27, 2013 11:58 am Post subject: |
Has the front end been wrecked on the right side? |
GI Joe Samba Member
Posted: Fri Sep 27, 2013 12:07 pm Post subject: |
Shoyrtt wrote: |
GI Joe wrote: |
Do they have a fuel float for this tank to monitor the level with the added capacity? _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
poptop Samba Member
Joined: February 27, 2003 Posts: 607 Location: jersey
Posted: Fri Sep 27, 2013 12:32 pm Post subject: |
Is there rehab for fuel sender _________________ So what I drive the short bus! |
Posted: Fri Sep 27, 2013 3:31 pm Post subject: |
Ron Domeck wrote: |
The tank doesn't fit anywhere across the front and there is no history of front end damage beyond a fairly minor ding. It is plain and simple just too big for the hole. |
Jonny Rock Samba Member
Joined: October 18, 2013 Posts: 52 Location: Tulsa, Oklahoma, USA
Posted: Mon Apr 21, 2014 2:44 pm Post subject: |
I would also like to install the oversize tank in my 73 Thing. Can any else elaborate on their experiences with this tank? I don't mind losing the stock spare location or the outside filler. I really hate the limited cruising range of my Thing though. It makes my Suzuki Samurai seem like a long range trekker. |
Posted: Mon May 05, 2014 3:20 pm Post subject: |
Well, I found a stock '67 Beetle tank in good condition, and I installed it in my Thing last night. I like it much, much better than the stock side fill. A simple tank design for a simple vehicle.
I was even able to put nearly 10 gallons in it last night. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Mon May 05, 2014 7:14 pm Post subject: |
Jonny Rock wrote: |
Make sure your hood latch and cable release are in good shape and operate effortlessly. A broken cable could be really bad news. . . |
Posted: Tue May 06, 2014 7:46 am Post subject: |
Yes, I actually adjusted them on Sunday as well.
As far as the filler being under the hood, it's no different than any other pre 67 VW. Again, it is something else the separates them from any other modern car. |
