Red light on
Yorvo
Yorvo is offline
PostPosted: Mon Apr 13, 2015 2:39 pm    Post subject: Red light on Reply with quote
I just changed the fuel pump on my 65 and now the red light is staying on bright after I start it. I knocked the coil wire loose while changing the pump but I've put it back and have checked all other wires. Everything seems connected. The battery may have worn down a bit trying to start it. Could any of this be related or is it all a coincidence? Any suggestions?
Thanks!!
rcroane Premium Member
rcroane is offline
PostPosted: Mon Apr 13, 2015 4:20 pm    Post subject: Reply with quote
Other symptoms? Is is idling ok? What type of fuel pump did you install? Did you check the pressure? Many of the aftermarket fuel pumps put out way too much pressure.
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Apr 13, 2015 6:41 pm    Post subject: Reply with quote
Check the wiring from your alt or gen to battery.
In Stereo, Where Available!
Yorvo
Yorvo is offline
PostPosted: Mon Apr 13, 2015 7:46 pm    Post subject: Reply with quote
I haven't checked pressure. That makes sense. I changed the oil thinking some gas may have got into it when the old fuel pump blew. (also an aftermarket). But it didn't change the light being on. It's a constant on after I start it. No flickering. The wiring appears to be hooked up.
Eric&Barb
PostPosted: Tue Apr 14, 2015 4:12 pm    Post subject: Reply with quote
Red light for your year of bug should be the generator. Green light is oil pressure.....
Lots more info you need to know in the Owner's Manual you can access thru the "Technical" button at upper right of this webpage.
rcroane is offline
PostPosted: Tue Apr 14, 2015 6:32 pm    Post subject: Reply with quote
Eric&Barb....I think he was referring to the fuel pump pressure that I asked about in my earlier post.
Eric&Barb
PostPosted: Tue Apr 14, 2015 9:12 pm    Post subject: Reply with quote
Still sounds like OP is talking about the red light...
Aynthm
Aynthm is offline
PostPosted: Tue Apr 14, 2015 11:18 pm    Post subject: Reply with quote
Which coil wire did you knock loose?
Yorvo
Yorvo is offline
PostPosted: Wed Apr 15, 2015 10:03 am    Post subject: Reply with quote
Thanks guys. I knocked the wire from the distributer to the coil. All the wires seem to be back in place. My "How To Keep A Volkswagon Alive" book said the red light was also for oil in my year. My mechanic suggested checking the oil for the gas. I'm thinking it's the voltage regulator or the generator or the wiring to. I checked the battery and it lost a bit of charge. Thought it might have been from cranking it over from the fuel pump issues. I charged it and the light is still on. I drove it around the block a couple times and it lost charge again. The battery is new.
I picked up a multimeter last night and I'll start checking when I get some time.
mukluk
mukluk is offline
PostPosted: Wed Apr 15, 2015 10:17 am    Post subject: Reply with quote
For clarification's sake, is the red light you're referencing to the left or to the right of your turn signal indicator in the speedometer?
Eric&Barb
PostPosted: Wed Apr 15, 2015 10:24 am    Post subject: Reply with quote
Take off the wire from the oil pressure sender, make sure it is not grounding out and turn on the ignition switch to "Run" position. One of the two lights will be out, that one will be the oil or should be if wired correctly.
Idiot's manual is nice but has a lot of wrong info or easy for beginner to mix up later info with info for early VW.
Get the Bentley reprint of the VW dealer workshop manual:
http://www.amazon.com/Volkswagen-1200-Workshop-Man...hop+manual
You can find good used ones for a lot less if need be.
Yorvo
Yorvo is offline
PostPosted: Fri Apr 17, 2015 9:00 am    Post subject: Reply with quote
Thanks! Yeah, I pulled the wire from the oil sensor. Yep, wrong light. I changed oil for nothing. Haha. I tested the battery under load with a multimeter. It's not taking a charge. So now it's time to go through and find the problem.
Harleyelf
Harleyelf is offline
PostPosted: Fri Apr 17, 2015 9:50 am    Post subject: Reply with quote
See if the wire is pinched to ground somewhere. The key is that it happened suddenly after you worked on it. Go back and re-trace your steps; it's probably something you touched.
Both lights get power from the key and ground out to light up when the circuit involved is not in a running state. Oil light grounds when you have low pressure and generator light grounds when charging voltage is less than battery voltage. Might you have dislodged a generator wire?
Yorvo
Yorvo is offline
PostPosted: Fri Apr 17, 2015 10:28 am    Post subject: Reply with quote
It has to be something I did. Because it's a steady bright on. All of the sudden. Everything seems connected. I'll inspect the wires better.
rcroane is offline
PostPosted: Fri Apr 17, 2015 10:31 am    Post subject: Reply with quote
Maybe post a few pictures of your engine so we can possibly spot a wire out of place?
Aynthm
Aynthm is offline
PostPosted: Fri Apr 17, 2015 10:34 pm    Post subject: Reply with quote
Yorvo
Yorvo is offline
PostPosted: Sat Apr 18, 2015 8:57 am    Post subject: Reply with quote
This is what I've got.
Aynthm
Aynthm is offline
PostPosted: Sat Apr 18, 2015 1:20 pm    Post subject: Reply with quote
someone is going to have fun with this one, i dont have time right now. sorry.
mukluk
mukluk is offline
PostPosted: Sat Apr 18, 2015 1:45 pm    Post subject: Reply with quote
Other than being filthy and having a rather interesting throttle return spring setup, things seem to be generally in order. I'd start by cleaning and reconnecting all the wires on the voltage regulator, followed by checking to make sure the generator is actually working, brushes in good shape, etc.
mukluk
mukluk is offline
PostPosted: Sat Apr 18, 2015 1:47 pm    Post subject: Reply with quote
Oh, and the metal tube for your distributor vacuum advance is installed upside down.
