KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Sun Mar 27, 2016 1:36 pm Post subject: Different Fan Hub for 38 amp Generator? |
Hi, Im tinning up a stock single port for a 68 Bus, only mod was converting to doghouse shroud and offset cooler ( all german tin )
Using a 38 amp Generator that is correct for a T2 with the correct dished backing plate pieces. With the only style of fan hub I have here when the fan is attached you can see the almost half inch gap between the fan and the backing plate. ( I belive this hub is off a regular old beetle setup )
So to the question... is there a specific fan hub for 38 amp Generators?
Thanks in advance.
here is few pictures of what im dealing with
Joined: January 01, 2007 Posts: 16893 Location: sticksville, ct.
Posted: Sun Mar 27, 2016 2:20 pm Post subject: Re: Different Fan Hub for 38 amp Genorator? |
yes, it's all 38A only, including the cast pulley and bell washer doodad (the one the nut presses against) fan is run of the mill dual port
http://www.thesamba.com/vw/forum/viewtopic.php?t=359632&highlight=38+amp+tin _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
KROC Samba Member
Posted: Sun Mar 27, 2016 3:13 pm Post subject: Re: Different Fan Hub for 38 amp Genorator? |
Thanks! now I need to find the 211 hub!
much appreciate the link.
Darren |
Brian Samba Moderator
jason Samba Member
Posted: Mon Mar 28, 2016 6:35 am Post subject: Re: Different Fan Hub for 38 amp Genorator? |
Cut it down |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
jason Samba Member
Posted: Mon Mar 28, 2016 2:34 pm Post subject: Re: Different Fan Hub for 38 amp Genorator? |
I meant cut down the long one, not the correct one he needs. I just did one and had no issue. |
Posted: Mon Mar 28, 2016 5:42 pm Post subject: Re: Different Fan Hub for 38 amp Genorator? |
Cut down how?, I'm confused. The Beetle one has the flange part way up the shank, the bus one has it right at the bottom, there's not enough meat on the flange to shorten it that far. They are both the same length, it's just the location of the flange that's different. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Tue Mar 29, 2016 3:57 am Post subject: Re: Different Fan Hub for 38 amp Genorator? |
KROC wrote: |
Darren |
I probably have a few of them. I will check later today. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
KROC Samba Member
Posted: Tue Mar 29, 2016 8:23 am Post subject: Re: Different Fan Hub for 38 amp Genorator? |
jbbugs wrote: |
KROC wrote: |
Darren |
I probably have a few of them. I will check later today. |
Thanks for the effort, We managed t get one yesterday. Not many of those suckers around!
Cheers Darren |
