djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Wed Oct 30, 2013 1:03 pm Post subject: |
Very cool idea. I have put it on my Tool Do List |
Rwoodshvac Samba Member
Posted: Wed Oct 30, 2013 6:10 pm Post subject: |
I like that tool do list now that's funny _________________ 57 Ragtop Semaphore Sedan
48 Aluminum Case drilled tapped, Full Flow Filter
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
Speedwell Ratio Rockers 1.25
Dual Valve Springs w/Lash Caps
Blackline Racing Lifter Inserts, Manton Push Rods
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Okrasa Oil Cooler |
Posted: Wed Oct 30, 2013 6:35 pm Post subject: |
Another photo
Picture of pushrod spark plug tool . The insert can be pushed in with an arbor press or a vise. It is a perfect press fit . _________________ 57 Ragtop Semaphore Sedan
Porsche 356 B Rods
Gene Burg Sump
Posted: Wed Oct 30, 2013 9:52 pm Post subject: |
Rwoodshvac wrote: |
I like that tool do list now that's funny |
I'll be performing all week. Please come again |
tinlizard Samba Member
Joined: June 28, 2010 Posts: 74 Location: Murfreesboro, TN
Posted: Fri Nov 22, 2013 7:34 am Post subject: |
Terrific thread! Many helpful insights, and some good ideas.
If it's not too much trouble, would you mind posting your final jet/Venturi setup? _________________ 68 Beetle Vert
70 Single Cab
79 Transporter |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
VWLooseNuts Samba Member
mcdoc2000 Samba Member
Posted: Sat Nov 11, 2017 1:56 am Post subject: Re: 1957 Euro Semaphore/Ragtop Vintage Speed Project |
Great build, any video of the engine running? I'd love to hear it. |
noshunter Samba Member
Posted: Mon Dec 11, 2023 1:15 pm Post subject: Re: 1957 Euro Semaphore/Ragtop Vintage Speed Project |
Here is this engine today, put it in my 54 oval with Italian 44 idf's and an A1 Sebring.
Ted2 Samba Member
Posted: Wed Dec 13, 2023 5:53 am Post subject: Re: 1957 Euro Semaphore/Ragtop Vintage Speed Project |
Good morning,
Where did you find the fittings for your fuel lines? I still need to make mine.
Thanks |
