jbowse2 Samba Member
Joined: August 13, 2008 Posts: 15 Location: SE Nebraska
Posted: Sun Oct 04, 2009 8:00 pm Post subject: Fuel pump rod question |
OK, Long story. Bought a 74 Super for my daughter to drive, leaked oil like nothing else out of the rear main seal, removed engine and replaced gaskets and seals, did not open the case, but did install an oil pump/oil filter combo. Finally got it back together after a year of get-a-round-too-it, fuel pump was shooting fuel everywhere.
I did replace the fuel pump spacer due to being broken off at the bottom when I had the engine out. New spacer slightly (1/16" or so) shorter than the original. I did measure the pump rod stroke, and adjusted as necessary with gaskets as per Bentley.
Went for a test drive with the new pump, came back and had oil all over the engine compartment, looked and saw the fuel pump spacer broken where it faces the alternator mount. Disassembled and found this
this is a picture of the new fuel pump installed with out the broken spacer
this is the old fuel pump on the left, had to disassemble it for removal due to not wanting to remove alternator. The original fuel pump spacer is also shown with the broken tip, is it reusable?
these are the books I have to guide me in making this car run
My Questions
What caused the pump rod to bend?
How do I get the broken chunks of the spacer out of the engine?
Did I screw up something by having this happen?
Do I dare try and straighten the rod or am I better off replacing it?
Thanks in advance, Jim |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Sun Oct 04, 2009 8:07 pm Post subject: |
I don't think you can just not run a spacer, there is not enough travel and it is bending the fuel pump pushrod, it is still pumping fuel and driving because it is bending the fuel rod until it WILL work, but it will not work for long, the flange guides the fuel pump pushrod.
are you running a pacer or not, your post is difficult to interpret. when you changed fuel pump and spacer types, did you change fuel pump pushrods? there are two different lengths. |
Posted: Sun Oct 04, 2009 8:15 pm Post subject: |
| I just have the pump sitting there right now with out the spacer, waiting for parts. I did not know there were two different lengths for the fuel pump rod. Could that make a difference with the new/different design fuel pump? |
Posted: Sun Oct 04, 2009 8:31 pm Post subject: |
there are fuel pump rods for alternator and generator cases. They are not expensive, like $1 used. I would buy 2 new ones (one of each kind), and a new spacer fuel pump flange, see which one is NOT the size you were using before, and try that one.
no 100% chance of success, but it's worth a shot and not too expensive. Search the classifieds. there are all the parts you are looking for use at a very fair price. in my opinion. |
Yellowbeard Samba Member
Joined: March 07, 2006 Posts: 2288 Location: At large again...
Posted: Mon Oct 05, 2009 5:22 am Post subject: |
You were using a long pushrod with a short pushrod-style fuel pump. It'll bend the pushrod/break the spacer every time. And usually kill the new pump. Your old pump was shooting fuel all over because the outlet fitting pulled out of the housing. It appears to be an American-made 40hp-style replacement. They're bad for this.
Replace your spacer and get the correct pushrod for whichever pump you choose to run. Buy a quality pump. I know a guy who sells 'em...  _________________
| Lohe wrote: |
Thanks. Thread went from me not being able to understand what Ipis was saying because English is obviously not his first language to me not being able to understand it because English is my first language  |
Fuel pumps galore:
http://www.thesamba.com/vw/classifieds/detail.php?id=845378 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6318 Location: 37.5N 77.1W
Posted: Mon Oct 05, 2009 6:18 am Post subject: |
| Quote: |
| using a long pushrod with a short pushrod-style fuel pump |
Look at the bottom of the fuel pump. If the lever is pretty much flush with the mounting flange, use the short rod. If the lever is recessed about 3/8, use the longer rod. |
Posted: Mon Oct 05, 2009 6:37 am Post subject: |
| runamoc wrote: |
| Quote: |
He doesn't need to. I recognize both pumps. _________________
| Lohe wrote: |
Fuel pumps galore:
Posted: Mon Oct 05, 2009 8:56 am Post subject: |
| Yellowbeard wrote: |
| runamoc wrote: |
| Quote: |
He doesn't need to. I recognize both pumps. |
While I quite sure there is nothing I can tell you about fuel pumps you don't already know, the 'point' was more for the lurkers who might be thinking..."Gee, I don't want to mess up my engine like jbowse2 did. I wonder how you can tell if my replacement pump is correct for the rod I have or which rod to use for this swap meet pump I got?" That's all.  |
Posted: Mon Oct 05, 2009 9:09 am Post subject: |
| runamoc wrote: |
Good idea.
| Lohe wrote: |
Fuel pumps galore:
gimpy60 Samba Member
Joined: May 09, 2007 Posts: 668 Location: Just down the road
Posted: Mon Oct 05, 2009 1:13 pm Post subject: |
generator pump stands straight up//////long rod (4 1/4") alternator pump leans over to miss alt/////////short rod (3 15/15") simple. Gen. application needs 13 mm. from spacer,,,alt will be around 7mm. sticking up . these measurements are taken at full lift.........these parts ARE NOT INTERCHANGEABLE. _________________ How the hell ya spost ta fix it, ya don't even know how it works boy |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16733 Location: North Florida, USA
Posted: Mon Oct 05, 2009 4:19 pm Post subject: |
| gimpy60 wrote: |
| generator pump stands straight up//////long rod (4 1/4") alternator pump leans over to miss alt/////////short rod (3 15/15") simple. Gen. application needs 13 mm. from spacer,,,alt will be around 7mm. sticking up . these measurements are taken at full lift.........these parts ARE NOT INTERCHANGEABLE. |
There is a generator fuel pump available that is slanted to clear alternators. It uses the early style push rods (long).
Also, a recent article in Hot VWs pointed out that some aftermarket pushrods are longer than the factory spec so it is always a good idea to measure rod length or how much the rod extends above the spacer. _________________ AshMan40
Posted: Mon Oct 05, 2009 6:59 pm Post subject: |
Thanks for the info, I will check my fuel pump for destruction and find me a new push rod and spacer.
Is there a good way to get the broken pieces of the old spacer out of the engine? |
Posted: Mon Oct 05, 2009 7:46 pm Post subject: |
| jbowse2 wrote: |
Take off the oil strainer screen and reach your hand in. You might get lucky. _________________
| Lohe wrote: |
Fuel pumps galore:
