Kreuger1 Samba Member
Joined: November 29, 2007 Posts: 41 Location: South East Oklahoma
Posted: Mon Dec 06, 2010 1:52 pm Post subject: Fuel Injection / Carb Question |
First, I searched. I may be a noob, but I'm not a stupid noob. Searched "carb replacement", and read most of fifteen threads. I dont like posting if I can find my answers by searching, but I havent been able to. Read lots on how the Progressive isnt the best choice. Here is what I have. Bought a 77 westy from an estate sale. Previous owner had the motor pulled and rebuilt, then died. ALL the FI stuff is in a big box, all tangled and such. I am not smart enough to put it all back like it was. Its okay, I know and have made peace with it. Untangling and re-installing FI and all those vaccum lines that I have never worked with and did not take out is not something I can do.
Having said that, IF you had a FI bus and had to buy a set of carbs, which would you get? I got this westy very very cheap, so spending money on a good set of carbs isn't an issue for me. I am looking for reliablity first, power second. I will continue to search and read threads this afternoon. Would like to get something pretty quickly.
Any advice helps.
Thank you,
Tom |
Randy in Maine Samba Member
Posted: Mon Dec 06, 2010 2:32 pm Post subject: |
The cheapest option would be to put all of the FI back to where it came from and use that. If you can bake a cake from a rcookbook, you can set up the FI.
Dual carbs would be the next best option and you want to see something like Weber 40 IDF on the boxes along with intakes, linkages, and a rotary fuel pump running off a relay. About a grand to get that stuff new and properly set up for your application. Dual 2 barrel carbs work best.
Cheaper would be dual 1 barrel carbs. There is a reason they are cheaper though.
A center mounted single carb does not work well for a type 4 as there is really no good way to get good heat to the carb to keep the fuel:air mixture in suspension. So that would be my forth and least desirable option. |
Posted: Mon Dec 06, 2010 2:47 pm Post subject: |
| The only thing hard about reinstalling the fuel injection is figuring out which case bolts hold what in place. A few good pictures should get you there pretty quick. It is hard to actually install most of the wires wrong as they will only line up a few ways. Just be as neat as possible putting everything in place and make sure you replace all the rubber hoses and boots as you go. |
germansupplyscott Samba Member
Posted: Mon Dec 06, 2010 4:07 pm Post subject: Re: Fuel Injection / Carb Question |
| Kreuger1 wrote: |
| I am not smart enough to put it all back like it was. |
you might surprise yourself.  _________________ SL |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42882 Location: at the beach
Posted: Mon Dec 06, 2010 4:13 pm Post subject: |
Since the motor is apparently not fully assembled - there may be more surprises. Better get a Bentley manual, get comfortable with a digital camere and uploading here.
I woud go with the FI. In many areas 1977 is still smogged and a carb will get flunked. This will be especially true as more states stiffen their smog regs. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 06, 2010 5:47 pm Post subject: Re: Fuel Injection / Carb Question |
| Kreuger1 wrote: |
| Untangling and re-installing FI and all those vaccum lines that I have never worked with and did not take out is not something I can do. |
Well the I hope you're an expert at reading plugs and changing jets because no carb kit works out of the box, you must adapt and tune it to your bus, that could take months and you'll have a box full of expensive jets left over when you're done. It's likely you'll have to do some minor tweaking with each change of season as well and if they don't have preheat of some sort winter driving will just suck.
Or you could untangle the mess and bolt on a system that is already optimized for your bus in any climate and situation. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Dec 06, 2010 5:56 pm Post subject: |
Guess I should try to explain. My biggest fear is that I will re-install this FI system to find out that one or more crucial parts aren't working. I can replace all the fuel/vaccum hoses easily, obviously. Its the other little parts. So my choices are install the FI kit (If I can puzzle it out) as is, then when it doesn't run, troubleshoot it and start replacing the whole thing bit by bit, or buy all new stuff and install it. Or buy a set of carbs.
Randy, thank you for the info. Brand preference? I was thinking along the lines of a set of dual carbs, over the singles. As I said, its not really the money. I bought the bus for a song. |
Posted: Mon Dec 06, 2010 6:28 pm Post subject: |
Even if you have to replace 3/4 of the FI (highly unlikely) it'll cost you less than $100 by shopping the classifieds, what's a good set of carbs cost? $1000?, pretty big gap there. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23338 Location: Oklahoma City
Posted: Tue Dec 07, 2010 4:47 am Post subject: |
| Kreuger1 wrote: |
Why would you start replacing parts one by one?.....just buy a damn $20 volt meter and test the parts before you install them. Testing parts by swapping in new ones is a GM methodology. Its not that big of a deal. Go for it! You will be fine! Ray |
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1397 Location: Arizona
Posted: Tue Dec 07, 2010 7:56 am Post subject: |
There seems to be a consensus here. I love my '78 FI, and although I've not had to work on it yet (let alone install the whole deal), I've learned enough from reading these threads, that if it was goofed up, and I had to, I'd tackle it in a heartbeat.
Heck, I might just go out and R&R it anyways!
You're not really getting what you asked for, are you? That's the way it works around here sometimes...
Best of luck, and keep us posted. _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours? |
Posted: Tue Dec 07, 2010 9:33 am Post subject: |
I am not a carb guy in the slightest. That grand for a new set up is one you should keep in your pocket. What do you say we get the FI system set up on there and if it all goes bad, you can still sell the whole FI set up and then go to carbs?
All of the FI stuff really pretty much mounts to the 8mm through bolts on the top of the engine. If the engine is out of this thing and sort of undressed, can you take a photo of the top of it? We can direct you on where the stuff mounts.
Over by the #3 cylinder is a 10mm x 1.0mm hole that the Temp Sensor II goes in. It sort of looks like this, but without the spacer shown....
We are looking to see if the heads have been replaced with non-FI heads that would not have that hole.
Also with some of that dough that you saved on buying carbs, remove the injectors and send them off for cleaning and calibration. Do the cold start valve while you are at it. I use this guy myself and he will do them all for ~ $100. www.cruzinperformance.com They will come back all cleaned and painted and with new seals and the short hoses.
Perhaps you could sort out all of the FI stuff you have and we could identify it for you? Post some pictures. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17717 Location: San Diego, California
Posted: Tue Dec 07, 2010 10:21 am Post subject: |
I don't consider myself to be a fuel injection guy. Almost all of my experience with air cooled VW's has been with carburetors. That said, I agree with the other guys to reinstall the FI gear on your bus. There is a ton of help here for you on TheSamba and these guys can't wait to jump in and give you pointers and advice. Like was said earlier, the FI equipment for you bus can be fully checked for functionality by just using a simple multimeter that costs less than $50. This passed weekend I was involved helping a guy reinstall this gear on his 1979 bus engine which had been removed to fix the heads. It was pretty easy.
There's a reason why all modern cars are fuel injected. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
cjjunkie Samba Member
Joined: February 05, 2009 Posts: 89 Location: michigan
Posted: Tue Dec 07, 2010 10:22 am Post subject: |
well, on the other side of the issue and much to the beratement of others, i have had a progressive from a pinto for 6 years now, zero problems. slow acceleration, i have had it up to 70mph once and only once, now i cruise at about 57 on the speedo(55 on the road) rebuild kit when i sourced it was like $30. averaging 23 mpg in a 76 westphalia.
I was presented with a situation similar to yours when shopping. this was the cheapest, fastest and easiest fix.
if i had to do it over again i might go with dual 40's, read a fair ammount on here about them, i was always scared of sychronizing and tuning them, but I am fairly confident it wouldnt be that bad, and worth the bit of added acceleration if i were ever to be courteous to other drivers and "step" on the pedal.
from what I have read, and tinkering with my vanagon, the vw fuel injection system seems fairly simple. i doubt with the good results the cab has given me i'd switch, but i would definatley entertain the idea of experimenting with a setup on a parts motor to see if i can get it going.
Fuel injection has proven itself, but i'm happy living in the past.... |
59walkthru Samba Member
Posted: Tue Dec 07, 2010 4:07 pm Post subject: |
reliability and power = FI.
carbs are going to cost three times what replacing all the FI components would and then setting up the carbs is going to cost you quite a bit too, weather you do it yourself or farm it out to a shop.(those little jets are not cheap @$80 a set, you'll want two sets for duels) Just Put the FI back in and be done with it, you've got all the help you need right here. like bd said it's hard to do it wrong there are no two plugs that could get mixed up. my FI has been running trouble free for over 15 years in three different busses. here a good place to start.
http://www.thesamba.com/vw/forum/viewtopic.php?t=281850 _________________ SGKent wrote:
take a photo of the shaft in the bore so we can see it, and one of your tool. |
choadtx Samba Member
Joined: March 18, 2009 Posts: 68 Location: Dallas, Tx
Posted: Wed Dec 08, 2010 12:32 am Post subject: |
| Kreuger, I live in Sherman and have a 78' FI bus. I pass Durant all the time. I wouldn't mind one bit to stop in and have you take a look at my setup and take some pics.... |
Posted: Wed Dec 08, 2010 9:39 am Post subject: |
Okay. Perhaps I need to look back at the FI set up afterall. I ordered a Bentley, should be here tomorrow. Its fairly intimidating to look at in a box. I'll lay it out tonight and see exactly what I'm working with.
Thank you for the info.
Choad, I may have to take you up on that. I talked with a guy named Kirk in Sherman with a FI bus, but his isn't running right now. Might be nice to look at yours. |
Posted: Wed Dec 08, 2010 11:12 am Post subject: |
| Kreuger1 wrote: |
| Okay. Perhaps I need to look back at the FI set up afterall. I ordered a Bentley, should be here tomorrow. Its fairly intimidating to look at in a box. I'll lay it out tonight and see exactly what I'm working with. |
If you can take a couple of good clear photos of it when you have it all laid out, and post them here, it could be helpful. It is intimidating at first, but become familiar with it, and FI is not that big a deal. Especially when you have the guys on The Samba crawling through it with you.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Make sure you've reduced your photos in size to around 500 pixels before loading into the Samba gallery. After you do it once, it's a cinch! _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Posted: Wed Dec 08, 2010 6:57 pm Post subject: |
| Crap, I wished I would've known. I have an extra Bently.. Yea, Kirk's isn't running too well. They usually meet up on the first tuesday of the month for the local VW club. It's lots of fun, you should definately check it out... |
