Radiator Placement on a 1971 Conversion to 1.6 TD Engine
avocado_tom
avocado_tom is offline
PostPosted: Fri Sep 02, 2011 10:27 am    Post subject: Radiator Placement on a 1971 Conversion to 1.6 TD Engine Reply with quote
I know it's been done before - converting Bays to water-cooled engines - but I was reading some of the other posts on radiator placement and I wanted to share some thoughts and hear other people's ideas.
I am about 80-90% done in converting my 1971 bus to a turbo diesel engine. The big thing about moving to water-cooled (obviously) is the radiator placement.
My biggest criteria for the conversion has been: I still want to be able to off-road and not risk loosing a radiator or a hose. This means I want my water lines protected and I don't want to loose ground clearance.
The problem with the '71 (as opposed to late bays) is that there are no holes in the frame rails to route 1.25" water hoses through. This means hoses going forward have to hang below the rails somehow. This may not be an issue - use strong pipes, make a cage around them, whatever - and you can feel good that they're going to be ok, and you're probably not losing much ground clearance.
But I wanted to avoid this - at least at first - so I put my radiator in my engine compartment. It may move later, but what I've found is that the rad from the '84 jetta I pulled the engine from just barely fits in the engine compartment. I have to see how much the fan is cycling - I'm going to install an indicator light - but for the time being it runs around town. If I get into any kind of spirited driving or prolonged hill climbing, however, it overheats.
Engine and Radiator, Installed
My temporary solution to this was to:
1. put a shroud on the back of the radiator to direct air downwards out of the engine compartment (probably doesn't help on the overheating but a good idea regardless) (you can see this in the picture above)
2. install an aux radiator in the belly, fitted with a scoop.
Why an "aux radiator"? Well, it's actually a Ford heater core and it uses the same diameter hose as my heater which is mounted in the belly (I lose about 1 1/2" to 2" of ground clearance at one point of the belly). And, the bonus is that the heater lines are only 5/8" Diameter and fit in the old heater ducting, so they're protected.
Aux Radiator Shroud/Belly Pan/Scoop 1
Aux Radiator Shroud/Belly Pan/Scoop 2
Heater in the Belly with protected lines
Belly Heater and Aux Radiator in situ
This "aux radiator" mounted downstream of the heater has seemed to take the edge off my water temperatures enough to allow me to drive in a more spirited fashion, although further testing is going to have to wait until I solve a low oil pressure problem with the engine that has cropped up again (a problem which I knew existed before I started the conversion).
I may move the radiator at some point, but I'm not quite there yet.
One other point of concern in doing that is keeping the head cool. Some info here posits that you want to have some sort of drum above the head height to keep the water flood high enough:
http://translate.google.com/translate?hl=en&sl...agina1.htm
This makes sense to me, but could be accomplished with a large (3 liter is suggested) coolant overflow drum. This could be mounted where I already have my coolant overflow or just bolted somewhere in the engine compartment.
Coolant overflow bottle
Thoughts? I liked what leadvillerpm did here: http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=80 and I know bluto has had good luck with his belly mounted rads (http://motorheads.net/vw/turbobus/page7.html) but as I said, I'm leery of losing ground clearance.
Some more tidbits on my conversion are here: http://www.vwdieselparts.com/forum/viewtopic.php?f=20&t=10174
And not enough pics are here:
http://www.flickr.com/photos/avocado_tom/sets/72157624446779933/with/5916472127/
Steve46038
Steve46038 is offline
PostPosted: Fri Sep 02, 2011 8:03 pm    Post subject: Reply with quote
I dont really know, but I think I saw a bus with a Pontiac Fiero radiator mounted on the roof in VW Bus Custom Handbook (Motorbooks Workshop) [Paperback] by Laurence Meredith.
Your list of requirements almost corners you into roof-mounted cooling.
However...I remember a Lexus concept car that ran rear radiators...I wonder if a rear-engine-hatch mounted radiator sucking air from the D-pillars with the assistance from some electric bigassfans could cool the beast???
If you wanna offroad, may I suggest a Cherokee like mine? Its damn near unstoppable...
1978 Westy
1997 Jeep Cherokee 4x4
2008 Infiniti G37S 6MT
SGKent Premium Member
SGKent is offline
PostPosted: Fri Sep 02, 2011 8:16 pm    Post subject: Reply with quote
if you are going to off road, on the roof mounted in a cage for protection against low branches or on the front with bars built around it. Underneath would look prettier but getting high centered on a rock will leave you with more problems than just a high center. Less mud on it too.
George Carlin:
Skills@EuroCarsPlus:
78Kombi
78Kombi is offline
PostPosted: Fri Sep 02, 2011 8:22 pm    Post subject: Reply with quote
Im with Steve. Pat Cook (cooknbus) cut out the center of the rear engine lid and mounted the radiator there.. Clean and close to the engine. You are over engineering if you are trying to get the radiator in the front.
Joe
78 hightop 2.0 FI
Wildthings wrote:
no engine that I know of will run off of hype.
chazz79
chazz79 is offline
PostPosted: Fri Sep 02, 2011 9:37 pm    Post subject: Reply with quote
My bus will eventually end up baja styled like fastmc's. I built my radiator set up with this in mind and feel it's well protected in the belly of my bus. I'll get it 2 inches higher and toss some 235/75/15's under it and have all the clearance in the world for the log/fire roads I plan on hitting.
I have tried the side mount radiators, the airflow just isn't there. You're pulling heat off the engine via water transfer then re-bathing the engine in the heat you just removed. It's counter productive. They never designed that box back there to flow air without a fan spinning. It's just an oven you get to engineer around.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
RatCamper
RatCamper is offline
PostPosted: Sat Sep 03, 2011 2:10 pm    Post subject: Reply with quote
OP, let me ask you this. How hard are you trying to avoid doing any alterations to your bus? Depending on local laws and regulations you might be able to drill holes through the rear crossmember for your radiator pipes / hoses. Where I am which is unbelievably strict, I can but may have to weld on a reinforcement plate. If you find it is legal and choose to do so at some point get yourself a good holesaw and arbor, and plenty of lube. Just the holesaw and arbor set me back about $50 but it was a worthwhile investment for a clean, round hole through thick-ish steel.
My radiator hoses still run under the rear beam anyway so not much is gained there.
Really if you are worried about both airflow and ground clearance one of the most passable configurations without carving the front up is a roo bar mounted rad. Preferably mounted behind the bar and shielded with some kind of grille. The trouble with that setup is air bleeding unless you get creative and do something like get a radiator with a rad cap hole and get a blanking cap for it, and remove to bleed. There is one other drawback to that setup unless you shield the vent flap you'll have a nice hot airflow into the cabin.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
Bajatacoma
Bajatacoma is offline
PostPosted: Sat Sep 03, 2011 5:10 pm    Post subject: Reply with quote
I remember seeing one conversion where the person had mounted the radiator on the front and had fabricated it to look like a spare tire. IIRC he built a hoop around it and put one of those chrome cover things on the outside while the front was made of black painted expanded metal. From a distance you really couldn't tell it wasn't a spare and up close it was a clean install. Just a thought...
'78 Westy
Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
Hunter S Thompson
El_Güero
El_Güero is offline
PostPosted: Sat Sep 03, 2011 6:42 pm    Post subject: Reply with quote
my best friends bus has a similar conversion (1.8 jetta ) shown in the first picture with the expansion tank in the spare tire compartment, he bought the bus from someone who had boght it from a mechanic who did it, his experience so far sugest that the engine doesn´t overheat neither on highway or traffic driving, the only disturbing matter for some folks is the fact that he has a second set of air scoops rivetted right beneath the original ones, (both sides) that makes the radiator get sufficient air from outside so it can cool off, and the fan only comes in when the bus comes to a stop. Hes not to worried about looks and so far so good.
"Sé que en algún lugar sus dedos pelean con un tornillo" (Remembering Carlos Amat)
"Si quiero estar encabronado
hazte a un lado...cabrón!"
greenbus pilot
greenbus pilot is offline
PostPosted: Sat Sep 03, 2011 11:23 pm    Post subject: Reply with quote
This is so true. I had my stock Jetta radiator in the rear door area for many years. It gets NO fresh air and the fan ran constantly on the highway. It did barely cool, but I was uncomfortable with no added cooling margin. I also ducted 100% fresh air thru the rear radiator from the side, where I cut a hole.
I do not believe a rear radiator can cool enough, much less a radiator mounted entirely in the engine compartment. There is not enough airflow and you are pulling hot air off the engine.
I put my LARGER radiator under the floor a couple years ago. Never overheats, and the fans run about 10 seconds at most, while stationary.
Try driving your engine- mounted- radiator- equipped Bus all day long in 100 degree heat, and see what happens. I boiled ALL my coolant out and was almost stranded 1000 miles from home. Made it back by cutting a hole thru the side and running the heater full tilt all the way. I even put the same heater core under the floor before I went belly mounted, to try to supplement the radiator. My results were mixed.
Your Mileage May Vary. Contents may have settled during shipping. Closed course, Professional Driver. Do Not Attempt. May impair your ability to operate machinery. Razz
Sent from a white van down the street.
avocado_tom
PostPosted: Fri Oct 28, 2011 9:50 am    Post subject: Reply with quote
To mitigate this somewhat, I put some shrouding on the radiator so that hot air is directed down and out of the engine compartment. I'm not sure how much of a difference it makes when the fan isn't running, but I'm sure it makes a difference when the fan runs.
OOC, how are you pulling hot air off the engine? Shouldn't the air be drawn in from the scoop area? Or is this if you mounted it where the rear engine hatch is?
Thanks for the input.
Right now it's cold enough that with the heater core and the scoop, the thermostat isn't even opening on the radiator, and when it has the fan isn't coming on until I stop, and then only for a few seconds. But 50-65degF is a lot different than 100degF, and I haven't been doing too many sustained, long-highway runs.
We'll see how she does when I start doing that....
avocado_tom
PostPosted: Fri Oct 28, 2011 9:54 am    Post subject: Reply with quote
I could probably do it and get away with it, but I was trying to avoid it, both as a test for myself and in order to keep the bus fairly clean in case I decide to go back to air-cooled (doubtful, but hey, who knows).
True, although I think I'd go for belly-mounted first, with a decent air-scoop and a low-profile fan. I think the clearance I'd lose by running the 1.25" hoses is about the same as I'd lose with the radiator down there...
RatCamper
PostPosted: Fri Oct 28, 2011 3:13 pm    Post subject: Reply with quote
I haven't measured but I've probably lost at least 4" with the belly mount, and where I need it most too, between the front and back wheels.
Sorry, I don't remember what year your bus is. Drilling the hole for the rad hose kind of bothered me but the fact that my rear crossmember is full of holes for things that it never had helped my decision.
Also dependent on year model, fitting a fan may be interesting. My conversion was pulled from an earlier 1600 bay. The only thing I haven't had to modify so far would probably be the moustache bar. One of the more infuriating differences I found was the routing for the various conduits underneath. Where an earlier bay could accommodate the radiator and thermo fans without issue, mine couldn't. I could only fit one thermo fan in there because of the steel tubes. This will be revisited shortly as I plan on doing one more radiator pull to finish the thermo fans. I have to drain the coolant to do a hose reroute anyway so I'll get it all at once.
I'm currently blocking off the frame rail to floor gap and the extra holes in the rear crossmember with pool noodles which jam fit quite well, and will be making a bridging plate to stop airflow between the back of the rad and the rear crossmember. I know I've said it before but the devil is in the detail. things look done until I give them a good think over. By now I have completely changed the entire conversion making the "complete" setup pointless.
One good thing I've noticed is I can use it as a tug of sorts for dragging things around in the yard, including a ~1150kg caravan, heavy trailer and even dragged a pallet with a motor on it and it barely ever even turned on the thermo fan. So that's still air + lugging + load + small fan.
Back over to your issue. It's very sad that you can't get it done in time. I get that. Said I'd have my bay back on the road for Valla something like 7 years running and failed Sad But I think you'll have it all sorted by Christmas as long as you are methodical, and don't let it get to you.
Keep up the good work. You have made excellent progress so far.
greenbus pilot
PostPosted: Fri Oct 28, 2011 8:40 pm    Post subject: Reply with quote
Quote:OOC, how are you pulling hot air off the engine? Shouldn't the air be drawn in from the scoop area? Or is this if you mounted it where the rear engine hatch is?
The worst overheating was before I ducted around the radiator, and it was just mounted in the engine door opening, pulling out through the back with the fan. It ran pretty hot all the time. The fan ran constantly on the highway because the exhaust is directly in front of it. It simply boils the coolant after a few hours. Been there. Done that. Almost rented a tow truck to get home about 1000 miles away, so I cut a flap in the drivers side, where the marker light is. Running the heater all day I was able to just keep it from boiling. When I got home I designed ducting to shield the radiator from the engine heat and pull from that flap I cut and the vents above. This was better but not perfect. I went to the belly mount later; those Aussies have it figured out pretty well....!
RatCamper
PostPosted: Sat Oct 29, 2011 12:59 pm    Post subject: Reply with quote
...those Aussies have it figured out pretty well....!
It comes from decades of trial and error. Conversions have been around here for a very long time.
I know it's not really Australia-centric but one thing I have noticed is in summer before I even start a car the temperature needle is already in the operating range, so as you can imagine deficiencies are felt fast on those days.
avocado_tom
PostPosted: Sat Jan 12, 2013 7:55 pm    Post subject: Running just fine... Reply with quote
There are more details here, but suffice to say I took my first extended run in my bus without any major overheating issues.
Here's my setup:
- stock radiator and fan in the engine compartment
- 96 plate mesa-cooler from thermostatically oil filter sandwich adaptor
- small Ford heater core inline with the heater coolant flow and mounted under the bus with a scoop*
What changed and is helping me:
- mesa cooler is new
- ambient temps are low (50-60 degF)
- sealed the area around the radiator so no air could bypass it
Other notes:
- not sure how often the fan is coming on yet
- H2O temps stayed at or below 180degF for majority of trip
- kept my foot out of it: cruised mostly at 55 to 57 mph
- don't think the Ford heater core gets much flow after the t-stat opens[/url]
avocado_tom
PostPosted: Mon Jun 26, 2017 12:49 pm    Post subject: Diesel Conversion Parts (was Radiator Placement on a TD Conv.) Reply with quote
All,
I'm giving up on my 1.6 VW Turbo-Diesel conversion project.
Anyone need parts for converting an early bay (or any ACVW) to a water-cooled VW - diesel or otherwise?
I have lots, including an mustache bar engine mount that has been modified for the water cooled engine.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jun 26, 2017 1:21 pm    Post subject: Re: Radiator Placement on a 1971 Conversion to 1.6 TD Engine Reply with quote
wow, 6 years later and throwing in the towel? may I ask why?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
avocado_tom
PostPosted: Mon Jun 26, 2017 1:31 pm    Post subject: Re: Radiator Placement on a 1971 Conversion to 1.6 TD Engine Reply with quote
Short answer is that I have too many projects and too little time. Trying to simplify my life and get to the point where I'm spending more time driving my cars and less time futzing with them.
greenbus pilot
PostPosted: Mon Jun 26, 2017 4:34 pm    Post subject: Re: Radiator Placement on a 1971 Conversion to 1.6 TD Engine Reply with quote
......and I also concur on this. I have not even driven my Bus this year yet,. But I will....
..........someday...... Wink
hang in there.
avocado_tom
PostPosted: Mon Jun 26, 2017 6:43 pm    Post subject: Re: Radiator Placement on a 1971 Conversion to 1.6 TD Engine Reply with quote
Thanks Greenbus Pilot! You too! Razz
